Tekin RS/RS PRO on 1s Lipo Q&A
#946
Hey guys...
When switching from Nimh to Lipo, did you guys have to gear it lower??? My car was drastically slower, and the punch was gone when I tried the Lipo... It was so slow that I practically could not drive it without crashing.
I switched back to Nimh and it was all back to normal... Does this mean with Lipo I should get a faster motor???
Thanks for your help guys.
#948
Hey guys...
#949
I decided to jump into the WGT class and have a question on running the 1S lipo's. I read earlier in the thread that people were running without boosters(i think mostly tekins race team during testing), but a lot of you guys are recommending them. Does the RS work without a booster or is it a must have? or, is it dependent on the servo/transponder/receiver being used?
here are the electronics i will be using.
Vector X-12 Stock Spec 13.5T Brushless Motor
RS ESC, Forward and Reverse for Brushless Motors
2.4 GHz FASST R614FF Receiver for 4PKS
Savox SC-1251MG Low Profile Digital Metal Gear Servo
5400mAh 65C 3.7v Lipo Battery Pack
RC4 Hybrid Personal Transponder
#950
Tekin will require a booster, or rec pack.
LRP SXXSS, SXX v2 have it built in
#951
Is there a preferred software version to run on the Tekin RS for my 12R5.1s on 1S? One will be running a Ballistic 13.5 and the other will be running a DUO2 17.5 or Ballistic 17.5. I was just curious if there is a preferred version to run these on 1S or if I should just download the latest software version.
Also, all of the electronics are brand new. Should I hook the ESC to my PC and update the software before soldering the motor and plugging everything in for the first time? Should I hook up a 2S lipo this first time to program them, or use my 1S lipos (one with TQ booster, other will run seperate LiFE pack).
Sorry if this has already been answered. I tried to search this thread but my searches are either too specific to bring up anything or too broad that a million posts come up and I can't find the answers I am looking for.
#953
#954
Would you reccomend just updating both of them before soldering anything up? Is there a preferred version I should run or just download the latest version?
Thanks for the help!! These are my first Tekin ESCs since the old Tekin Speed Star brushed ESCs (which I still use after 10 years) so I am excited to try out the new ESCs with some good brushless motors.
Also, I am going back and forth on which motor to use for the second 5.1. I already have the Ballistic 13.5 for one of them but I haven't decided on the 17.5 yet. Is there one you would reccomend for my other 5.1? I do have a new X12 17.5 although I was planning on using this in my new Touring car unless this would be a better choice for my 1/12 scale. I also have a DUO2 17.5 but it is already installed in my backup touring car so I am not sure if I want to pull it for this project or just get another motor. I am the only one running 1/12 scale on our local track so I can run anything I want.
#955
Also, I am going back and forth on which motor to use for the second 5.1. I already have the Ballistic 13.5 for one of them but I haven't decided on the 17.5 yet. Is there one you would reccomend for my other 5.1? I do have a new X12 17.5 although I was planning on using this in my new Touring car unless this would be a better choice for my 1/12 scale. I also have a DUO2 17.5 but it is already installed in my backup touring car so I am not sure if I want to pull it for this project.
As for motors, check with the quick guys at your local track, they should be able help you out with a setup to get you up to speed quickly.
#956
Unfortunately I am the only one running 1/12 scale at our club so there isn't much help there. I am building a few cars to try and get some of the other guys interested, but everyone else runs 17.5 Touring cars. The majority of them run Ballistic motors with a few LRPs mixed in and 1 DUO2. I am hoping that as they see my 1/12s getting faster and better, I can spark some interest in the other guys and get a new class started. Lately I have been running 2 5.1s on 2S lipos with brushed 27t motors. They are pretty fast and working great, but the setups are pretty odd and I think there is still some room for improvement. I have 2 more 5.1s so I want to set them up with proper 1S brushless setups to see how they compare. If we do start a class, I would imagine we would use the 1S brushless setups.
It is a fairly small track http://www.youtube.com/watch?v=JCHlWMou1Bw
#957
Pm me if you want the full set up but it is similar to one on Tekins site but changed to suit the layout.
Hope this helps.
#958
Hello,
My question: Can I cut on/off switch, solder wires together and leave on/off function to RCdynamics booster's switch? I am wondering if Hotwire would work after this? I need the cutoff funtion to stay active.
#959
You don't need the on/off switch or power to the ESC to use hotwire. There should not be a problem. I ran my 12th scale just as you said except with a novak booster.
#960
Ok, probally the most asked question but i'm new to 12th scale. Using 17.5 x12 tekin rs and novak booster. After 4 min or soo boost is gone and I can drive full throttle the whole track... Sucks Donkey D's. Is this fixable?
