Tekin RS/RS PRO on 1s Lipo Q&A >
Old 08-19-2010, 09:32 AM
  #886
Team Tekin
Randy_Pike's Avatar
Glad to help Bill. Your car looked good on the track. I'll have to get my WGT going and throw down with you.
Randy_Pike is offline
Old 08-24-2010, 06:05 PM
  #887
I'm not sure if I saw it in this thread or in the RS thread but...I remember seeing someone who had wired their LiPo RX pack into the servo lead of their RS so that it would use the BEC in the RS to regulate voltage to the RX and only use the 1 switch. Someone from Tekin said it would work at the time but wanted to evaluate it more. Did this turn out to be something bad to do or was it OK? The only issue I remember hearing about was the voltage cut off wouldn't work which isn't much of an issue for me as I'll be running 17.5 and 13.5 both limited profile in 1/12th and WGT so I won't be anywhere near low voltage at the end of a run.
InspGadgt is offline
Old 08-24-2010, 06:10 PM
  #888
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
I seen that,jim was the one talking about it
20 SMOKE is offline
Old 08-24-2010, 08:33 PM
  #889
Still Bill's Avatar
Trader Rating: 16 (100%+)
Randy, You gave me some food for thought about my high/low rev settings brought over from carpet.
Now I have to figure out how to make the car go at the IIC with no boost or turbo...
Bill
Still Bill is offline
Old 08-24-2010, 09:02 PM
  #890
avs
avs's Avatar
post 32
http://www.rctech.net/forum/electric...ml#post7091098
avs is offline
Old 08-25-2010, 08:16 AM
  #891
Team Tekin
Randy_Pike's Avatar
Bill, crank the timing up in the motor, select timing profile 1, find your rollout...
Old 08-25-2010, 11:38 AM
  #892
Thanks AVS that's what I was looking for...just hadn't got that far back yet after a couple hours of searching.
Old 08-25-2010, 12:30 PM
  #893
Julius's Avatar
Randy,
Any comments on this? I'd really like to use it as it saves all the issues with regulators etc. and the weight of a LiFe or 2s Lipo. I'd run a 1s lipo in series with the switch.
I can see you're not going to make this a "normal" setup but I'd like to get an "unofficial" nod before wireing my RS-pro like this.
Julius is offline
Old 08-25-2010, 01:48 PM
  #894
20 SMOKE's Avatar
why not use the booster and save the weight,unless this will be in a wgt
20 SMOKE is offline
Old 08-25-2010, 01:58 PM
  #895
Team Tekin
Randy_Pike's Avatar
It works, nuff said.
We still prefer to see the life packs,etc.
Old 08-25-2010, 02:20 PM
  #896
Are you planning on being at IIC again this year Randy?
Old 08-25-2010, 06:31 PM
  #897
Still Bill's Avatar
That I knew...LOL
Old 08-26-2010, 05:30 AM
  #898
Mike Mandio's Avatar
I run a TQ booster in 10.5 WGT on a large track (235 ft. back straight) with no issues. We run 6 minute heats.
Mike Mandio is offline
Old 08-28-2010, 09:30 AM
  #899
20 SMOKE's Avatar
i just got done doing the rx lipo mod,work great.testing tomorrow
20 SMOKE is offline
Old 08-28-2010, 09:42 AM
  #900
Team Tekin
Randy_Pike's Avatar
Yes I will be at IIC. Flying in first thing tuesday morning.
