Tekin RS/RS PRO on 1s Lipo Q&A >
Old 02-25-2010, 04:33 AM
  #781
Default Possible to replace a receiver lead?
Slightly off topic ... I have a Tekin RS running 1S in a 1/12 scale, and it seems the black wire lead to my receiver must have overheated, as the rubber insulation has cooked off at several places along the lead. I haven't yet taken it apart to replace the lead, but I'm guessing it is a direct solder onto the board which may be tricky to do. Has anyone had to do this? Difficulty scale? My alternative is to heat shrink the entire lead. Thoughts?
(By the way, my theory as to how this happened is that it was caused by a weak solder joint to my deans connector (held together by the heat shrink, and the solder joint to the booster). I'm thinking the ESC was running the motor mostly off the receiver lead. I was having a hard time figuring out why my car was so slow and turbo boost didn't work ... thought I had cooked the battery, replaced that, then thought I had cooked the motor, so I put in a different motor, and all along it was a bad solder joint!)
JohnPrz is offline
Old 02-25-2010, 05:53 AM
  #782
Tech Legend
Cain's Avatar
Trader Rating: 268 (100%+)
thanks for the info. I got the TQ Booster.
Cain is offline
Old 02-25-2010, 08:57 AM
  #783
mangoman's Avatar
I highly doubt the receiver would draw enuff current to be able to melt the insulation. To me it is more likely you were soldering something and the wire brushed the soldering iron
mangoman is offline
Old 02-25-2010, 01:42 PM
  #784
It's the entire length of the wire ... bare wire next to brittle pieces of insulation next to bare wire all the way up the lead. I know what it looks like when you cook the insulation off a wire ... done it before when I was doing some experimentation with an old lipo that was headed for the trash.
JohnPrz is offline
Old 02-25-2010, 02:23 PM
  #785
Here's a picture.
Attached Thumbnails Tekin RS/RS PRO on 1s Lipo Q&A-pict0024.jpg
JohnPrz is offline
Old 02-25-2010, 06:13 PM
  #786
Trader Rating: 5 (86%+)
Default setup..
Originally Posted by Swen View Post
Yes, it's Duo 1. It's a 40x70 track, 1s. I ran it last weekend in the middle hole, no turbo, profile 4, 45 timing. I tqed by a lap and won. Everyone said it was very fast and it felt that way too. I was rolled out at 2.558.
what rpm start and end....
obi wun is offline
Old 02-25-2010, 06:22 PM
  #787
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
7500 and the lowest one it gives you.
Jon Carlson is offline
Old 02-25-2010, 06:25 PM
  #788
Default setup
is 7500 the start..if so whats the end...
obi wun is offline
Old 02-25-2010, 06:27 PM
  #789
Regional Moderator
No, 7500 is the end. The start is the lowest option it gives you when it calculates the RPM.
Old 03-22-2010, 09:51 PM
  #790
1
Trader Rating: 30 (100%+)
Has anyone got a killer set-up for RS-Pro with latest firmware.
Running a 10.5 Duo.
Small tight track.
69t 48p Spur
Rear tires at 46mm / 1.81 inch
I need more guts from this motor. Help would be very much appreciated.
1 is offline
Old 03-24-2010, 10:19 AM
  #791
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
what milliamp battery are most using now,i have seen a little more use with 203 over 200 but not much just curios cause I'm going to be getting a 1/12 in a few weeks and need to buy a battery
20 SMOKE is offline
Old 03-24-2010, 10:23 AM
  #792
incase you dont want to read all bajillion pages of this, i think i saw ppl able to suck down as much as 3500mah in a 5 min run, but i dont think there are many choices of battery other than 5000-5600 mah. i have read that you should stay away from the reedy 1s battery because the weight is uneven left to right and unbalances your car. otherwise i thinker there are alot of SMC and thunderpower lovers out there.
oh and ty for bringing back this thread. i had wondered what happend to it.
benben10 is offline
Old 03-24-2010, 11:40 AM
  #793
theisgroup's Avatar
in stock on our last layout I was sucking 3300mah adn 3900mah in 13.5, but on our current layout I have come down to 2900mah in stock and 3500mah in 13.5
theisgroup is offline
Old 03-24-2010, 12:54 PM
  #794
what all does the 1s lipo check box do? does it just turn off the BEC? would that mean we could use the RSpro for high voltage applications and with a RX pack and have everything work?
i was in the drag racing seen for a little while and was curious.
benben10 is offline
Old 03-24-2010, 02:43 PM
  #795
20 SMOKE's Avatar
1 cell check box is for the lipo cut off
20 SMOKE is offline
