Tekin RS/RS PRO on 1s Lipo Q&A >
Old 02-15-2010, 02:39 PM
  #766
I have tried Off, 2, 3, and CV(shows 3000 at top of bar). Still nothing, its seems like the speedo is not getting enough power to turn on.
XCELL is offline
Old 02-15-2010, 02:48 PM
  #767
Regional Moderator
CarbonJoe's Avatar
What voltage is coming out of the Novak booster? Is the 1s LiPo box checked in Hotwire? Is your ESC switch on or off? Is the Novak booster wired to the B+ and B- posts on the ESC (and with the correct polarity)? These are basic suggestions, but better to cover all of the bases.
CarbonJoe is offline
Old 02-15-2010, 02:58 PM
  #768
I have everything is set-up right, speedo switch off/ booster on wired correctly to the positive and negative. I have tried several scenarios and double-checked all the connections.
XCELL is offline
Old 02-15-2010, 03:27 PM
  #769
Just rechecked everything and found a loose wire the receiver, we are good to go. Thanks for trying to help me out CarbonJoe I appreciated it.
XCELL is offline
Old 02-15-2010, 04:06 PM
  #770
chris moore's Avatar
Trader Rating: 93 (99%+)
Patrick, are you running V203? If so you will need a rec batt; when Jason was trying the booster last time at CH it just would'nt work correctly on V203. He switched back to V200 for the main.
chris moore is offline
Old 02-15-2010, 04:09 PM
  #771
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
Anyone have a good setup for WGT running 13.5 Duo?
Jon Carlson is offline
Old 02-24-2010, 02:11 PM
  #772
Tech Legend
Cain's Avatar
Trader Rating: 269 (100%+)
so what is the current accepted method for 1S lipo usage on a Tekin RS with the latest software?
Cain is offline
Old 02-24-2010, 03:00 PM
  #773
I'm using a booster rather than an rx pack, and running 30 boost with 10 turbo, gearing is roughly where we were with nimh cells a year ago (~60mm/rev on an X12 10.5)
boost and turbo and delays/rpm ranges would vary depending on motor/track size
chris_dono is offline
Old 02-24-2010, 05:04 PM
  #774
kawirider's Avatar
Trader Rating: 14 (100%+)
i run that same motor sven. i run the motor timing in the middle, i set boost to 55, no turbo, and about a 65mm rollout. our track has about a 90 foot straight and a pretty techincal infield.
kawirider is offline
Old 02-24-2010, 06:33 PM
  #775
Still Bill's Avatar
Trader Rating: 16 (100%+)
How big is your track? Is that a Duo 1? With 1S?
Still Bill is offline
Old 02-24-2010, 07:11 PM
  #776
Regional Moderator
Yes, it's Duo 1. It's a 40x70 track, 1s. I ran it last weekend in the middle hole, no turbo, profile 4, 45 timing. I tqed by a lap and won. Everyone said it was very fast and it felt that way too. I was rolled out at 2.558.
Old 02-24-2010, 07:37 PM
  #777
Still Bill's Avatar
Sorry. My brain is all metric for rollouts...
Please give me your spur, pinion and tire sizes (metric); so, I can calculate.
Bill
Old 02-24-2010, 08:08 PM
  #778
Bill
Bill just multiply by 25.4 to get millimeters.
AreCee is offline
Old 02-24-2010, 08:10 PM
  #779
That's an average rollout for that size track. The one I race at is a bit longer and a bit narrower and I'm at the same rollout of 65mm.
AreCee is offline
Old 02-25-2010, 04:14 AM
  #780
k_bojar's Avatar
Trader Rating: 30 (100%+)
at my local track (Horsham, PA) there's a pretty much even mix of 2s receiver packs and the boosters...
personally I run the booster and haven't had a single issue with the car...plus the booster (other then the novak) are significally smaller then the receiver packs and makes balancing/mounting electronics a little easier
k_bojar is offline
