Old 01-19-2010, 03:47 PM   #676
TrevCoult's Avatar
Originally Posted by oeoeo327 View Post
+1 on the TQ booster - no problems whatsoever, regardless of the firmware being used.
Does anyone know if there's a US distributor importing the RC Dynamics booster? I might want to try one of those since the voltage output is a little higher, and I can't use a 2S LiPo receiver pack since my receiver won't handle the extra voltage w/o a regulator.
No US distributor as yet. The easiest way to get one is to email Mark Jordan direct at the address supplied on his web site (address is in my earlier post). Price and postage to USA are also on his web site.
The problems with boosters seem to be with particular combinations of electronics rather than one individual component. The RC Dynamics booster is the only one I have found to work with my combination of a Tekin RS (203), JR Z3650 servo and KO 408S receiver.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 01-19-2010, 04:18 PM   #677
oeoeo327's Avatar
Trader Rating: 74 (100%+)
Thanks for the info TrevCoult - I'll look into procuring one...
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 01-19-2010, 06:24 PM   #678
ben73's Avatar
Trader Rating: 40 (100%+)
Originally Posted by Clegg View Post
Also realize that unless there is some stablility in battery spec for 1/12th racers will keep away. We are just rounding the corner on people accepting 1S LiPo, and boosters/packs. I think its a solid setup.
I have a $4.00 HobbyCity booster (same thing as the TQcells...) that has worked great with my Tekin and Novak GTB before it for roughly 2 points series now (about 7 months of racing).
I have used my hobbycity booster for months now with my LRP setup. I have just converted tekin and purchased the RS Pro.
Can you confirm that the hobbycity booster works with the Pro and the latest firmware
I'd rather not use a rx pack and have to bother charging it also.
thanks
ben73 is offline   Reply With Quote
Old 01-19-2010, 08:36 PM   #679
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
Confirmed works great
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 01-24-2010, 03:31 PM   #680
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default start point v203
Hi all..wanting to try V203 in my 1/12,,,Using vegas software at the moment..
Can some one help?
Tekin redline 10.5/RS-Pro.....4900/3.7v/50c lipo..
currently using 67mm rollout timming set to 5deg+..
Car is fast. motor is about 40-50deg C...
Mike.
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 01-24-2010, 03:53 PM   #681
TrevCoult's Avatar
Can some one help?
Mike.
Try the setup from my post here.
http://www.rctech.net/forum/6864726-post10722.html
Trev
Schumacher Racing
Old 01-24-2010, 07:08 PM   #682
tallyrc's Avatar
not sure if the ice charger predates the Li-Fe packs or not (cause they are not listed in their specs) but does anybody know if the ice can charge life packs? thanks.. has anybody run a lipo rx pack without a regulator or is it required?
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 01-24-2010, 07:55 PM   #683
Mechanic-man's Avatar
hi guys im new to racing 1/12th scale i have a 1s lipo a novak esc and motor and novak booster i just bought a tekin rs and download the hotwire vegas
2.0 will the novak booster work ok with the software or not? thanxs
Mechanic-man is offline   Reply With Quote
Old 01-24-2010, 08:02 PM   #684
tallyrc's Avatar
i run the novak booster and it tends to shut down on me durring runs...
Old 01-24-2010, 08:24 PM   #685
Where did you get the Li-Fe receiver pack?
RoyU is offline   Reply With Quote
Old 01-24-2010, 08:28 PM   #686
Trader Rating: 23 (100%+)
Trinity makes this one......http://www.teamepiconline.com/shop/i...p?item=TEP2006
SteveL is offline   Reply With Quote
Old 01-24-2010, 08:33 PM   #687
Still Bill's Avatar
Epic/Trinity makes a small li-fe 6.6V pack with 220 mahr with an on/off switch connected. Perfect for pan car. Team EPIC / Trinity Part#: TEP 2006.
Price is $24.50 from Nexus Racing. Only place I had found one so far.
Works great as long as you have a li-fe capable charger.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 01-24-2010, 08:34 PM   #688
Originally Posted by SteveL View Post
The Team Epic site shows its out of stock "mid November". That's the pack I wanted to get
Old 01-24-2010, 08:35 PM   #689
I'll check out Nexus Racing, thanks
Old 01-24-2010, 08:44 PM   #690
Regional Moderator
CarbonJoe's Avatar
OK, here is a weird problem...
1/12 scale, Tekin RS Pro V203, 1s LiPo, voltage booster 17.5 Duo 1 motor. Zero degree timing on motor, max boost, max turbo, 0.3 delay, default start and end RPM, no voltage cutoff, neutral 10, brake strength 100, drag brake 5, rollout 3.10 inches.
Car runs great for about 5 minutes, then falls on it's face badly, slower by around 3 seconds per lap (10.5 fast lap, to 13.5 seconds at the end). Motor is only 106 degrees after entire 8 minutes. ESC was cold, so no chance of it overheating. Case, as well as posts weren't even warm.
Swap out motor to brand new 17.5 Duo 2, try different battery, different voltage booster. Same thing. Motor is only 115 degrees after 8 minutes. Not losing control (like if regulator was dropping out).
Otherwise, car was very fast. Leading race, had a lap up over 3rd place, but he was able to make it up, pass me, and finished 1 lap up over me. I can see dropping off a few tenths, but not 30%.
Any ideas?
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
