Old 01-03-2010, 10:04 PM   #616
oze
Have you seen this?: http://www.rctech.net/forum/6789190-post9381.html
It is in the other RS topic on page 262
oze is offline   Reply With Quote
Old 01-11-2010, 03:04 AM   #617
mharlow's Avatar
Trader Rating: 27 (100%+)
I have just installed my tekin rs pro into my 12R5 and I have a problem. I'm running a Novak booster with a 10.5 motor. When I pull full throttle the car will car but then when I try to take off again it stops for about 2 to 3 seconds before taking off again even though the ESC is flashing full throttle. This does not happen in Dual Mode. The spectrum receiver still seems to be getting power as the light stays on however it looks like blue light on the Novak booster dims a bit when the car stops.
Any help would be appreciated.
mharlow is offline   Reply With Quote
Old 01-11-2010, 03:34 AM   #618
cannon's Avatar
Trader Rating: 35 (100%+)
Get rid of the booster
The guys not using boosters dont seem to have any problems. A Rx pack does the trick
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 01-11-2010, 05:07 AM   #619
theisgroup's Avatar
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 01-11-2010, 05:08 AM   #620
H I
H I's Avatar
Trader Rating: 18 (100%+)
I've been running Novak booster with RS pro and don't have problem.
I don't use lipo cut off on speedy and leave speedy switch off.
H I is offline   Reply With Quote
Old 01-11-2010, 07:32 AM   #621
wingman2's Avatar
I have heard a few people now say that booster's can't cope with voltage drop under acceleration, and that those people have run RX packs with no probs. Personally, I have always run a RX pack and never had a problem with it. Just put a bit of blue tak or something over the switch of the ESC so that it can't be turned on and you should be fine.
wingman2 is offline   Reply With Quote
Old 01-11-2010, 08:07 AM   #622
Does anyone know what speedcontrol Brad Johnson was running in 13.5 12th scale BEFORE he made the switch to the tekin for the mains at the Novak race?
march to my own is offline   Reply With Quote
Old 01-12-2010, 01:01 PM   #623
BuddhaTech's Avatar
Default Help!
I have not had a chance to race or test and won't get a chance before heading to the Snowbirds. Nothing like showing up cold! Any suggestions for a Tekin RS in a WGT car? I have X12 and Novak 13.5 to run on TP 1S LiPo's. This turbo ESC stuff has me a little perplexed. I had the car running very well with an SXX and the Ballistic motor on 4cells. Just need a place to start as far as roll out and ESC settings for 1s. I have a Novak Booster as well.
Thanks!
Mike Evans
____________________________________
Buddha Tech Race Services ~ Build-Prep-Tune
buddhatechraceservices @ gmail . com
BuddhaTech is offline   Reply With Quote
Old 01-12-2010, 05:54 PM   #624
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
ok now im confused, i thought you had to leve BOTH switches on, i actuall cut off my switch from esc, and soldered both wires togther?i am running 203 software...but im not using the novak, as ive heard problems, i am using the TQ racing booster...
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 01-12-2010, 06:13 PM   #625
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Switch on = Voltage cut off protection working
Swtich off = Voltage cut off NOT working.
If you have a N____K booster and are experiencing brown outs, try adding 10 to the push control. Others claim this helps.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-12-2010, 08:36 PM   #626
haywood's Avatar
Trader Rating: 49 (100%+)
Thanks!
You will need to find a different booster because running V203 my 1/12th scale would brown out like twice during the eight minute race.I would try the TQ booster.
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is online now   Reply With Quote
Old 01-12-2010, 08:38 PM   #627
haywood's Avatar
BD
Old 01-15-2010, 08:43 AM   #628
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
Can someone please post a v203 setup for 1s 17.5 12th scale on a 70x40 track?
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 01-15-2010, 08:51 AM   #629
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
1s 17.5, v203
Jon good place to start would be.
Motor at 0, or N.
Boost at 40, RPM 5600-700 ( bottom number pick the lowest)
Turbo Max, ramp profile 1, delay .7
roll around a 75MM
This is a good starting point, drag, push, throttle profile all to preferance.
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 01-17-2010, 10:55 AM   #630
what battery preferences do you guys have for the main pack? anything specific for stock vs. mod vs. low turn mod?
benben10 is offline   Reply With Quote
