Old 11-28-2009, 05:10 AM   #541
fire929's Avatar
Default Not Working
Originally Posted by LOW ET View Post
I cannot get it to work.
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 11-28-2009, 05:25 AM   #542
LOW ET's Avatar
Trader Rating: 97 (100%+)
try here, http://www.rctech.net/forum/electric...sored-556.html
post #8339
LOW ET is offline   Reply With Quote
Old 11-28-2009, 05:29 AM   #543
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
http://redirectingat.com/?id=42X1295...Hotwire200.zip
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 11-28-2009, 07:45 AM   #544
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
No issues running a 4.5 on a rs with 1cell. Have been running no problem all season in 12th.... It is nice that you can keep rollout low. Add the turbo and have the straight speed and be able to run out hard. Only a 4 or 5 on turbo. 4 or 5 on boost and motor on zero. Adjust the gearing to match the track. Very drivable and all the doped you need to run at the edge on high bite. If you are getting the speedo hot you are over geared or way over timing te motor.......
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 12-01-2009, 03:29 PM   #545
can i ask what sort of rollout i need for a 5.5 motor ish
cheers
jas1 is offline   Reply With Quote
Old 12-02-2009, 12:32 PM   #546
Can someone post their rollout and hotwire setup for 1/12 scale 10.5 from the Halloween race?
TIA
Carter
darcydawg is offline   Reply With Quote
Old 12-02-2009, 01:32 PM   #547
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
TIA
Carter
0 motor timing
15 boost
15 turbo
.6 delay
45-80
1.66" tires
-Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 12-02-2009, 02:05 PM   #548
That's 75mm/rev - are you sure that's for 10.5? Looks more like a 13.5 ratio to me - can you confirm? Thanks.
SlowerOne is offline   Reply With Quote
Old 12-02-2009, 03:08 PM   #549
sg1
sg1's Avatar
It's confirmed
In 13.5 I was at a 50 pinion.
It sounds high, but there isn't much total timing.
I ran 50-84 at my local track with ver. 200, max boost, 0 motor, 0 turbo with very good success. Only .3 drop off after 8 minutes.
You can bump the motor timing up and turbo with the 10.5 and drop the gear to 40-80, but it dropped off more at the end.
-Wayne
Old 12-02-2009, 04:05 PM   #550
Thanks Wayne. That's in the ball park of what I been trying. I've tried going to mid 80's for rollout but lost too much punch.
Regards,
Carter
Old 12-03-2009, 10:25 AM   #551
Originally Posted by sg1 View Post
0 motor timing
15 boost
15 turbo
.6 delay
45-80
1.66" tires
-Wayne
A few more questions. What throttle profile are you using? Are you using any drag brake?
Thanks,
Carter
Old 12-03-2009, 10:44 AM   #552
sg1
sg1's Avatar
Thanks,
Carter
#3 profile
I start with 0 drag break, I had 10 at the Holloween Classic.
-Wayne
Old 12-03-2009, 05:08 PM   #553
LOW ET's Avatar
anyone have a 13.5 wgt setup for a track like this, 90'X40'
using v200 software, 1s lipo, lrp x11 or x12 13.5 (stock timing) and 53.5mm tires. gearing and esc profile would be great.
what setups were the tekin guys running in 13.5 wgt at the classic and indoor champs?
Old 12-06-2009, 07:08 PM   #554
xtrememadness's Avatar
Send a message via AIM to xtrememadness
hey guys when checking the 1s box do you leave the voltage cutoff off or set to a custom setting. thanx
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 12-06-2009, 07:58 PM   #555
hanulec's Avatar
Trader Rating: 27 (100%+)
hey Craig - I've been leaving the 1s box unchecked and running with a receiver pack.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
