Tekin RS/RS PRO on 1s Lipo Q&A >
Old 10-12-2009, 12:07 PM
  #421
Trader Rating: 21 (100%+)
Originally Posted by rcwck View Post
Purchased RS Pro last year. I tried 198 software but get this message that settings are not within parameters of my esc. How do you determine what software version is compatible with your esc? Or what parameters to use with a certain esc?
198 says that. I don't remember the answer but it was nothing to worry about. You should update to 200. Email Randy Pike for 200. Also check on: http://www.rctech.net/forum/electric...-sensored.html.
You will find the answer there too.
lidebt2 is offline
Old 10-13-2009, 06:45 AM
  #422
rcwck's Avatar
^^^^^Done, thanks
rcwck is offline
Old 10-13-2009, 02:34 PM
  #423
Trader Rating: 17 (100%+)
I need a little help in trying to figure out what wrong with my RS and 1cell setup. Using know good novak 17.5, fully charged SMC 20c, and ver. 198 + 200; the motor will not move with 1c box checked. It will move using a two cell battery. If I uncheck 1c box it will turn only with thottle over 1/2 and act like bad sensor in motor using one cell, all ok with two including seeing leds for sensors working. Could it be a bad capacitor maybe?
billb60 is offline
Old 10-13-2009, 03:16 PM
  #424
R/C Tech Elite Member
Mac The Knife's Avatar
Trader Rating: 33 (100%+)
Are you using a receiver pack?
Mac The Knife is offline
Old 10-13-2009, 03:54 PM
  #425
chris moore's Avatar
Trader Rating: 93 (99%+)
If your not using a rec pack or booster it will not work.
chris moore is offline
Old 10-13-2009, 03:56 PM
  #426
Sounds like you need a booster or RX pack. My speed controls wont work unless they see a higher voltage from the RX. The servo will work, but no speed until you hook up a booster or RX pack. Supposedly the speed control thinks the battery is going dead so it only sends power to the RX to save the battery.
slotracer577 is offline
Old 10-13-2009, 04:27 PM
  #427
Did you turn off the voltage cutoff or adjust it to 3V with the hotwire?
AreCee is offline
Old 10-13-2009, 06:01 PM
  #428
Oops I knew I forgot something. I'm waiting for the novak booster to come in. I'll try to wire up the two cell as receiver pack to bench test with. Thanks all
billb60 is offline
Old 10-14-2009, 03:24 AM
  #429
mangoman's Avatar
You can wire up a 2s as a receiver pack however it is recommend not to do it. You be better off grabbing an old 4 cell nimh pack and wiring it up :P
People have reported they have run fine with 2s receiver packs, but you are meant to have a voltage regulator which steps the 2s back down to 6.0V however for light testing it SHOULD be ok.
mangoman is offline
Old 10-14-2009, 04:35 AM
  #430
All works now with 2c pack on bench test. Now just waiting for Novak or TQ boosters to come off back order at my local store.(support you local hobby shop/track).
Will any company be bring out higher turn brushless motors so we can go back to 2cell racing for slower classes i.e. new TOUR oval classes? Or is the 12th scale's smaller chassis setting the trend; meaning 12th scale more popular then oval?
billb60 is offline
Old 10-14-2009, 04:45 AM
  #431
I am pretty sure that there's not much more room inside a 540-sized brushless motor for more than the 21.5 wind. As soon as ESC manufacturers figure out how to economically package a voltage regulator into the ESC without it ballooning in size, 1s LiPo gets super easy. As it is now ,it's not terribly complicated, we're just used to higher voltage at the moment. That's not even mentioning the weight savings of running the lighter 1s LiPo's: less tire wear, less breakage when making contact with the boards etc etc... If we need something slower than 21.5/1s LiPo then there's always 360-sized motors but that would require a new pod design and probably a few other design changes...
adam lancia is offline
Old 10-14-2009, 05:37 AM
  #432
OK I see the the one cell and esc working. I guess someone has to make a low voltage transponder(or a run self powered one) and servo.
billb60 is offline
Old 10-14-2009, 06:35 AM
  #433
liljohn1064's Avatar
MRTs work perfectly down to 3V.
liljohn1064 is offline
Old 10-14-2009, 11:59 AM
  #434
mangoman's Avatar
We use hobbywing motors in our tamiya minis in australia. I think they are 380 size motors but they have a fins around the motor to bulk it up to a 540 size motor so it fits in the car normally.
mangoman is offline
Old 10-14-2009, 12:38 PM
  #435
I believe that he was referring to the mounting holes on the 380 motor requiring a new or modified mounting plate on the motor pod. So even with fins it won't bolt to a 1/12 scale rear pod.
AreCee is offline
