Tekin RS/RS PRO on 1s Lipo Q&A
#316
The RX pack isn't going to back feed and give the motor more power.
I feel it's faster only because it will prevent ANY power from being taken away from the motor. If you run a booster there is a small amount of power being used for the receiver and servo, while minor it's a difference especially in mod where they're pushing it as it is.
If I had the choice I'd go rx pack simply to keep my servo and receiver at a higher voltage for optimal performance.
#317
hey randy,
I can't thanks you enough for all the help before and during the IIC. I wish I had a chance to thank you in person, but I was sooo beat saturday that i was just trying to get all my crap together to send back to texas. I am sure I will talk to you soon. but thanks again for all the help. only wish I could have done more for ya and tekin at the iic
yang
yang
#318
Took my 1S 13.5 to the track to show Clegg how it was set up. Ended up racing. I can say that with a quality pack, I had no problems with a booster. My gearing and timing might be off, but I didn't have time to mess with it. My laps got faster as the traction came up in each heat and the main. Again, 3.7V taken out in parallel should have almost no noticeable affect on the ESC. It might load the battery a little current wise, but it isn't taking anything away from the motor. The mA the receiver and servo need are minute compared the amps the motor draws.
#319
Moderator
Yeh unfortunately I didnt get to play with your WGT car much, but it looked very smooth and easy to drive... my car was an absolute nut case tonight.
#320
With regards to the comments about a receiver pack or booster for mod. I dont know what the tekin is rated to but my understanding is that you have other escs rated to around 100-150A
I assume the RS Pro would easily match this so 300mA draw is pretty small compared to this.
I also note that the IIC setups of Mike Dumas and Donny Lia were running the current limiter at 84.
But im a pretty ordinary driver....
#321
They were running Mod motors, running in dual mode, using the RS Pro and were pulling huge amps. I'd like to know how many mAh were needed to recharge their packs. I think there may have been fear they didn't have enough juice to last the full race and still power the electronics.
#322
Its really quite simple, even if its called a booster, you can't make something out of nothing. You can fool the electronics into thinking the voltage is there to operate and even with the smallest amount of current draw you begin to tax the electronics to stay operating, and not efficiently. That doesn't matter if its with a mod or a 17.5 motor, the demand of the unit, although it sort of works, is not the best method. Mr Pike already stated that a rxr pack is the better method, like it or not, sometimes you can't fight the technology.
Had nothing to do with run time.
#323
#324
I understand what you saying, but I think you'll find that with a 1s there will be more people going to the rxr pack versus the booster. Since we are concerned not only with keeping the "on" voltage to smarts of the sc, and taking into account trying to maintain a good speed on the steering servo, not having any kind of drop off at the rxr, so it has to re-search for dropped signal, and probably keeping a fan running on the motor to, I think that no matter, the booster won't do the best job.
Step up and step down convertors just aren't the same as raw available power such as what a rxr pack can supply.
At the IIC even the stock guys, the fast ones, used external rxr packs over boosters,
but if you have something working for you, go for it.
#325
I dont really know electronics, but from what i can see of the boosters they have caps on them which my understanding should theoretically maintain the voltage to the receiver and servo (assuming they are of sufficient capacity).
One of the guys i know, i think was toping up his receiver pack after each run or each second run (which i dont want to bother having to do). In fact im thinking about getting 4 lipos if they work so i can charge the night before and not have to worry about it on the day :P
I also saw in one of the british sites that one guy commented he ran a 4t and only used 2500mah at a rollout of 27mm. While another commented he ran a 5.5 and 36mm with a booster and used between 3000-3200mah. I was pretty astounded and asked it was 5 minute racing.
Both were running a tekin
#326
Hey guys,
What sort of rollout are people running on the RS with 1S Lipo and a 10.5 motor ?
I've got the speedo set to boost 20 and turbo max at the moment on a Nosram Storm motor.
Chris
Chris
#327
#330
pan cars we always talk roll out. the difference is that some use metric and some use standard. the 3.04 is in inches
