Tekin RS/RS PRO on 1s Lipo Q&A >
Old 09-14-2009, 02:42 PM
  #286
chris moore's Avatar
Trader Rating: 93 (99%+)
[QUOTE=Clegg;6343514what rollout change would I see going from a GTB based ESC to a Tekin... does it go up or down?
And after reading most of this thread I am still a bit confused as to how you have the ESC/booster/powerswitch all configured. If I read right - the booster should be run off the battery directly and plugged into the Rx. The ESC should have its connector with all 3 wires plugged into the Rx and the switch be off on the ESC? or the red wire out of the ESC connection to the RX and the switch be on the ESC?[/QUOTE]
Figure a 6 to ten tooth drop on the pinion depending on the track
Do not connect the booster to the main battery, it connects to the + and - esc posts and then plugs into the receiver. As long as you have v200 of the software you can turn on the esc switch to enable the lipo cutoff, but its really not needed. In an 8min race with a 13.5 I use 1800 to 2200mah depending on the track and how I'm driveing. So unless your going to run back to back heats without charging or running mod you'll never hit the cutoff. As mentioned you can wire in a seperate on/off switch I have not just for simplicty, that means that when I plug in the main pack everything is hot so I just make sure I have the radio on before I plug in the main pack. Heres a pic of it in my db12r
chris moore is offline
Old 09-15-2009, 05:01 AM
  #287
GWH74's Avatar
Here is a picture of my BMI.
You can see the booster between the receiver and the battery.
At this stage this has only been tested on a couple of runs with the receiver turned off.
And need to find a smaller switch
Attached Thumbnails Tekin RS/RS PRO on 1s Lipo Q&A-top.jpg
GWH74 is offline
Old 09-15-2009, 07:01 AM
  #288
Moderator
Clegg's Avatar
Very interesting! Where is the cap for your ESC? (trying to place where I want to put mine when I get the ESC in) I Am digging how small the RS is from seeing that pic!
Clegg is offline
Old 09-15-2009, 07:11 AM
  #289
nitrobeast's Avatar
Trader Rating: 44 (100%+)
Very nice working installing everything
nitrobeast is offline
Old 09-15-2009, 07:12 AM
  #290
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Over the 'S' on the 'RS' for mine. There are no obstructions to wiring with that placement. There are some small plastic tubes that go over the cap leads to prevent shorting that come with the RS. The posts have a convenient 'V' groove in the top. It holds solder well and allows the cap leads to be put in and the posts to be tinned well before attaching the +/- wires.
liljohn1064 is offline
Old 09-15-2009, 07:36 AM
  #291
H I
H I's Avatar
Trader Rating: 18 (100%+)
Very nice GWH74.
What sort of ESC set up and roll out are you running?
I just got RS pro and I have no idea what to do with boost set up.
I'm going to run novak 5.5L motor with 1 cell.
H I is offline
Old 09-16-2009, 01:43 AM
  #292
GWH74's Avatar
Here are two more pictures of my set-up.
One is of the booster and the 'monster' switch (at least a marshell won't miss it). You will also see a small 6.3V 1000uf cap between the receiver and servo mount.
The close-up of the ESC shows how i have mounted the cap. The black connector onto of the ESC where you would normally mount the cap is the power connector to the booster (via the switch).
I have wired it so there is the least amount of drag on the motor wires and the battery wires are neat.
You can take the booster or switch assembly out without de-soldering wires.
This set-up has only seen limited track time. I still need to do more bench testing on the Lipo cut-out and the booster.
I am running one of the US$4.95 hobbycity specials and i will be testing output current and ripple voltage.
I will post the results later in the week.
I have around a 50mm roll-out with the 5.5L. This needs to fine tune for our large outdoor track. I am a bit concerned about runtime and dumping. I think i will be OK with the lite but i wouldn't like to push a normal 5.5 until i do more testing.
Attached Thumbnails Tekin RS/RS PRO on 1s Lipo Q&A-booster.jpg   Tekin RS/RS PRO on 1s Lipo Q&A-close-up-esc.jpg
GWH74 is offline
Old 09-16-2009, 01:56 AM
  #293
GWH74's Avatar
Here is another trick.
I am using the non-Lipo BMI RR chassis so to locate the battery.
Cut some .30 lexan strips (4 off them per battery) so they fits snuggly in the battery cut-outs. Stick two of them together so now you should have 2 x 2 strips.
Mount your battery in the car where you would like it (easy with the BMI and O-ring), now stick the strips to the underside of the battery through the battery cut-outs.
Now the battery will go back in the same spot every time and will not move around.
Attached Thumbnails Tekin RS/RS PRO on 1s Lipo Q&A-battery-strips.jpg
GWH74 is offline
Old 09-16-2009, 02:03 AM
  #294
mangoman's Avatar
Does that switch sticking out ever get knocked and turn things off?
mangoman is offline
Old 09-16-2009, 02:12 AM
  #295
GWH74's Avatar
I would say it will.
I haven't run it in a race yet. It was just a switch i had lying around at work. Hard to track down a nice little switch like they use on the ESCs.
It will be swapped out by the weekend if i can find one.
GWH74 is offline
Old 09-16-2009, 03:17 PM
  #296
Moderator
Clegg's Avatar
So I am thinking... Just got my RS in hand today (waiting on Randy's email with v200 firmware goodness) and I am looking at the wiring aspects of this.
Could I just cut the Power switch from the Tekin, solder it closed (so the ESC is always on when the battery is plugged in) and only have switch for the booster?
I have a DSM radio, so if there is no signal, no big deal not like it will start glitching all over. You guys think that would be an issue? does the booster need to be powered on before the ESC? or can the ESC be switched on before the booster is turned on?
Only having one switch would be nice and still having the LiPo cut off.
Clegg is offline
Old 09-16-2009, 04:30 PM
  #297
mangoman's Avatar
The booster is meant to go on before the esc does, so dont solder the switch in the on/closed position.
mangoman is offline
Old 09-16-2009, 05:47 PM
  #298
Team Tekin
Randy_Pike's Avatar
Vegas setups for 1s:
Attached Thumbnails Tekin RS/RS PRO on 1s Lipo Q&A-kennylamberts1-12-13.5iic.jpg   Tekin RS/RS PRO on 1s Lipo Q&A-kennylamberts1-12-13.5wgtiic.jpg   Tekin RS/RS PRO on 1s Lipo Q&A-mikedumas1-12modiic.jpg   Tekin RS/RS PRO on 1s Lipo Q&A-donnylias1-12modiic.jpg
Randy_Pike is offline
Old 09-16-2009, 06:07 PM
  #299
Moderator
Clegg's Avatar
Randy, Any chance we'll get access to those low turbo boost delays?
Clegg is offline
Old 09-16-2009, 11:30 PM
  #300
mangoman's Avatar
Thanks for the setups Randy!
Any idea what approximate gearing they were using with the mod setups?
Also i just noticed they are using the dual mode, is there any particular reason for that?
mangoman is offline
