Old 08-17-2009, 10:57 AM   #211
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Originally Posted by liljohn1064 View Post
Can someone shoot me the latest and greatest schematic for the RS 1S with booster setup?
From what I gather, I want to put the booster leads directly on the +/- leads of the battery and plug the other end into the bat port on the Receiver. From there set the RS up as a 1S unit. I'm not sure where the power switch is supposed to end up as: on or off. I don't want to smoke the new RS in my WGT car.
You've got it right.
With the 1S profile you can leave the switch to on with the RS if you want to use the voltage cut off feature. It works in either position.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 08-17-2009, 10:59 AM   #212
Trader Rating: 21 (100%+)
This is how I have it setup in my oval car: + to +, - to -, on the speedo. Speedo off. I'm using the Novak booster as my on/off switch. I attached the Speedo switch to the speedo wire going to the reciever. this way it can't be turned on by mistake.
Photo below.
Hope this helps.
Tekin RS/RS PRO on 1s Lipo Q&A-dscn1532.jpg
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 08-17-2009, 10:59 AM   #213
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Thanks! I hope to have it well tested by the first Hurricane race.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 08-17-2009, 11:02 AM   #214
I'll see you there
Old 08-17-2009, 11:24 AM   #215
Skiddins's Avatar
I know people have noticed a big difference using this ESC with TC setups etc.
Has anyone tried it with 1s lipo?
Does the extra timing and turbo etc still work well with 1s.
I also have some LRP SPX's but the high profiles don't seem to make any difference with the lower voltage.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-17-2009, 11:25 AM   #216
TQ Booster and SMC on the way. Almost the last parts needed for the CRC. I still need a couple parts from Calandra.
Old 08-17-2009, 07:13 PM   #217
Maybe this has been posted already, but what's a good rollout to start with for: CRC GenX, 1S TP lipo, Tekin 17.5 w/12.5mm rotor, Tekin RS ESC, on a 80X40 carpet track?
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 08-17-2009, 07:59 PM   #218
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I'd start around an 87 mm with 17 turbo, 0 motor timing, and 15*esc timing. .5 delay.
Old 08-17-2009, 07:59 PM   #219
chris moore's Avatar
Trader Rating: 88 (99%+)
If you have 200 start at 80-85mm; if not try 90mm
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 08-17-2009, 08:00 PM   #220
Skiddins
I think the difference is HUGE even on 1c.
Old 08-19-2009, 12:46 PM   #221
JayL's Avatar
anyone have a pic of the crc genx-10 with the esc mounted in the middle using the new 1s esc plate?
JayL is offline   Reply With Quote
Old 08-19-2009, 12:58 PM   #222
1S plate! Where did you find that?
Old 08-19-2009, 02:39 PM   #223
JayL's Avatar
I am talking about this:
http://teamcrc.com/crc/modules.php?n...prodID=7719044
you probably thought I meant for the 1s cell itself that would be cool!
Old 08-21-2009, 12:02 PM   #224
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
For this whole 1S lipo thing in 1/12, I am assuming this one works fine for the RS just the same as the RS Pro. Does anyone got a breakdown of the current accepted method to get all of this work (ie- buy this booster, set this setting in the ESC, hook up this first, etc). Also pics of your setups would be great.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 08-21-2009, 02:32 PM   #225
I was. I almost lost it at work. I was hoping it could be in front of the battery instead of behind it for cooling purposes.
