Tekin RS/RS PRO on 1s Lipo Q&A
#136
By the way, I put your RS and 17.5T in my sedan and could tell (with the boost) it rips much better than my GTB or Sphere. Now I've switched over my buggy and now my 1/12 and am selling off all my other brands of ESC and motors - I'm sold, a complete convert.
#140
I'll admit that this would be my fault, I'm not trying to claim anything is defective except for possibly my wits, just want to know if this could have caused the booster failure.
Thanks,
Jeff Smith
#141
There should be nothing we can do in any version to harm the booster unit. The error was actually in the hotwire and not the 198 version for the speedo. It simply was not setting the 1S settings correctly. New version should be up today.
Tekin Prez
Tekin Prez
#142
Excelent , any guidence on what we should set the voltage cutoff at?
#143
3V is the standard for 1S. Some set it a little higher for some headroom. Some batteries claim they work lower, but it is never good for the life of the battery to use all the capacity.
#146
i just updated an RS to 198 to use the 1s option on a 1/12 scale.
now i get an ominous message:
"Some of the user values are outside the expected range, your ESC may not be compatible with version of hotwire"
the values i am trying to use are
1s lipo
sensored
drag brake off
rev strength 30
brake strength 100
neutral 14
BL-FW
throttle 3
cutoff 3.350
pushcontrl off
boost 15
currentlimit off
it seems that if i pick 1s lipo, then i get a message
"warning the voltage cutoff has not been set"
no matter what i set the voltage cutoff at. i presume that i should use the 'custom' cutoff option.
are these unimportant nuisance warnings, or do they indicate a problem?
thanks for the help.
1s lipo
sensored
drag brake off
rev strength 30
brake strength 100
neutral 14
BL-FW
throttle 3
cutoff 3.350
pushcontrl off
boost 15
currentlimit off
#147
I have the same warning. The message is received after i installed the new version. When i excute the program i get that message in a green box. "Some of the user values are outside the expected range, your ESC may not be compatible with version of hotwire"
After that hotwire fires up and i can adjust my settings. No idea if it will harm the esc. I am a little wary to try it out. I use 2s lipo.
#148
i still didn't try out the lipo, maybe next week?
#150
software
I have no problem with the old 198, it's the new one that everyone is having.
I installed it on my custom pc and the laptop that was running the old 198 and have a problem. My custom PC (XP) gives me the same problem. My custom has never seen Hotwaire before yesterday.
