Old 11-10-2003, 08:11 AM   #1
Default 26mm tyres on 24mm wheels
ive got an evo3 and ive got to use 26mm tyres [t27] but 26mm wheels wont fit as it binds on the upper link.
ive tried shimming out the wheel but its not enough.
the best conclusion ive come up with is using 24mm wheels.
ive mounted a set on and tested and it seems to be ok.
the tire is flat and not bulging or anything.
the grip seems so good i can easily keep up with all the cars round the corners.
will this set up give me any disadvantages?
and if so what can i do?
by the way its a control tyre and ive just got sum sponsors for the race and could loose them if i dont race.
thanks
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 11-10-2003, 09:34 AM   #2
popsracer's Avatar
trf racer;
I have done this both ways in the past and never has problems. As long as the insert is the correct width for the Tire you should be fine (and do not break any Track Rules)
24mm is really the standard width these days for TC Rubber anyways.
popsracer is offline   Reply With Quote
Old 11-10-2003, 10:05 AM   #3
newracer's Avatar
R/C Tech Charter Subscriber
could you use a wheel with a different offset? like +2
newracer is offline   Reply With Quote
Old 11-10-2003, 01:37 PM   #4
that would make it too wide.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
Old 11-10-2003, 01:58 PM   #5
stormperson's Avatar
Send a message via AIM to stormperson
It might change the traction a little bit. I know on dirt I sometimes run a narrower wheel with a standard size tire to gain traction... I would assume in TC it would be a much lesser noticable change since the insert could be smaller as well. However, I think it would be something to notice.
R/C Excitement Special Projects Coordinator
Kwik | Speedmerchant | Parma PSE | KO Propo
Team Pickles
stormperson is offline   Reply With Quote
Old 11-10-2003, 03:31 PM   #6
Super Steve's Avatar
Send a message via AIM to Super Steve
so there are no ill affects with this?
Super Steve is offline   Reply With Quote
Old 11-11-2003, 01:51 AM   #7
as long as the grip isnt no less than mounting them on 26mm i dont really care about much else.
this seems to be the only cure.
thanks for all your help.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
Old 11-11-2003, 02:06 AM   #8
Hi trf racer,
Just interested, what race are you running in that uses 26mm control tyres?
Trevor
Trevor is offline   Reply With Quote
Old 11-11-2003, 02:14 AM   #9
Originally posted by Trevor
Hi trf racer,
Trevor
hi,
its carpet wars in the uk.
they are using the t-27 tyre as a control tyre.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
Tamiya 26mm tyres now on ebay YAH Australia For Sale/Trade 0 05-06-2007 10:10 PM
TAMIYA 26mm tyres for sale YAH Australia For Sale/Trade 0 05-01-2007 07:13 AM
24mm or 26mm tire width ? e_lm_70 Electric On-Road 7 11-23-2005 09:39 PM
24mm and 26mm wheels what is the difference? Ginsu Electric On-Road 4 01-30-2005 03:49 PM
26mm tires on 24mm wheels? Inspire Nitro On-Road 2 09-19-2004 12:25 AM
