Old 11-09-2003, 08:45 PM   #1
Coney's Avatar
Send a message via ICQ to Coney
Powering a 12V Charger via Computer PSU???
Hi Guys,
First, I'd like to say this is a great forum!!
Im just about to get into RC's, and I am wondering if this is possible?
Someone suggested to me that I should be able to power a 12V Charger using the Power Supply Unit from a Computer.
Would anyone here be able to shed some light on this matter??
Is it possible, and if it is, does anyone have any links/URL's that show the process.
Thanks in advance
Coney
Coney is offline   Reply With Quote
Old 11-09-2003, 09:28 PM   #2
Fire's Avatar
all you need to do is use a 10W 30ohms resistor to short the 5V wires with ground (all the 5V with same number of ground), joint all the 12V+ wires and ground wires as the power output you connect your charger to, then short the power on wire with a ground if you are using ATX power supply
i have done a couple of those but i found that their output voltage is a tad low (11.8x volt) and considering buying a decent 13 - 15volt unit
hope this help
Fire is offline   Reply With Quote
Old 11-09-2003, 10:47 PM   #3
i was gonna do that but i already ordered me a cheap power supply from ebay...but heres the link to where i was gonna copy a computer power supply conversion to use with my chargers..
http://www.magicookie.com/prodigy/psupply6.htm
Los1Fan is offline   Reply With Quote
Old 11-10-2003, 03:04 AM   #4
lee82gx's Avatar
the link is the full monty if u want to do a conversion.
what i(lazy bum) do is just load the 5V output with 10 Ohms 20-50W resistance BEFORE i plug in the charger.
yes,as mentioned mine is also a tad low on voltage,and charging transmitter packs are problematic.
lee82gx is offline   Reply With Quote
Old 11-10-2003, 08:15 AM   #5
This may help too...
Click
ksrcracing is offline   Reply With Quote
Old 11-11-2003, 05:25 AM   #6
Coney's Avatar
Hey Guys,
THANKS FOR THE REPLIES!!
I shall give it a whirl and see how it goes.
Coney
Old 11-11-2003, 06:19 AM   #7
Cole Trickle's Avatar
I did it this way, and it've worked well for a year by now.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 11-11-2003, 09:47 AM   #8
sands's Avatar
I've found that running a fan off of the 5v side will bring the voltage up a bit. Bonus with the fan is you get to cool your batteries too.
sands is offline   Reply With Quote
Old 11-11-2003, 09:54 AM   #9
Coney's Avatar
Hi sands,
Is that with an ATX or an AT PSU?
Coney
Old 08-01-2013, 03:52 PM   #10
Jthorpe's Avatar
Here is the PSU I want to use:
APEVIA See-Through ATX-AS500W-BK 500W ATX12V Power Supply
This is the Charger I am going to be getting soon:
Venom Medion Dual 10 Amp LiPO Battery Charger with Audio Speakers
I am wondering if someone has a parts list that I need to do this conversion?
If so please pm me.
Jthorpe is offline   Reply With Quote
Old 08-01-2013, 04:51 PM   #11
spunkysandoval's Avatar
Trader Rating: 125 (100%+)
do you already own this power supply and did you have to bump so many threads?
Tekno RC - VBC Racing D06 - Axial Rubicon and Wraith - SC10.2 - Hitec - Speed Passion - Werks - lrhhobbies.com
spunkysandoval is offline   Reply With Quote
How to use computer PSU as 12v for DC charger? Morpheus2be Malaysian R/C Racers 7 03-23-2014 12:33 PM
Triton Jr DC Computer Charger(((((PICS)))) hpipro4 R/C Items: For Sale/Trade 9 12-24-2007 07:26 PM
Can I run my DC charger off my Computer? hanknmorgan Electric On-Road 13 09-22-2006 10:01 AM
W.T.B. GM Charger computer cable wehbad2003 R/C Items: Wanted to Buy 1 03-01-2006 01:13 PM
ESC is not powering the car. bvoltz Rookie Zone 4 07-18-2005 08:45 PM
