Old 02-08-2009, 02:19 AM   #1
rcdude8's Avatar
Default 48P and 64P
What is the difference between the pitches of the gears? Are there any advantages to using say 48 over 64?
Also if I were to switch from 64P to 48P what would I need to change apart form the gears? Belts? etc
Hot Bodies Cyclone S
LRP A.I. Brushless Reverse Digital
Acoms Technisport 2.4 Ghz Radio System
Mazda/Stratus Cross Body
rcdude8 is offline   Reply With Quote
Old 02-08-2009, 02:31 AM   #2
Drifting101's Avatar
Pinion and spur that is it. No speed advantage either way
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 02-08-2009, 03:46 AM   #3
Foxxrocket's Avatar
64P has a smoother gear mesh, and is more for on-road. The teeth are fragile, and it's vary easy to grind them with bad gear mesh. 48P is more durable and best with trucks and buggies, but they work just as well on-road. 48P has fewer gear options than 64P, but they can take a beating.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 02-08-2009, 03:50 AM   #4
timmay70's Avatar
Racers would argue that 64 pitch is more efficient, and also allows for finer fdr/rollout adjustments. Asphalt/dirt types will argue that 48 pitch is more forgiving to debris.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 02-08-2009, 05:36 AM   #5
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
+1
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 02-08-2009, 06:05 AM   #6
Pit-racer's Avatar
Pit-racer is offline   Reply With Quote
Old 02-08-2009, 07:05 PM   #7
Super Moderator
Grizzbob's Avatar
While I agree that 64 pitch can be a bit smoother, I think its efficiency advantage is too small for most of us to tell the difference(myself included), the main reason why I use 64 pitch is the flexibility in gear ratio options(much easier to get exactly the final drive ratio I want)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 02-08-2009, 07:59 PM   #8
greed4speed's Avatar
Send a message via Skype™ to greed4speed
It is also a good idea to find out what pitch most racers at your club use.
Unless you want to come along with every pinion and spur gear ever made in 64 pitch, you may need to borrow one from a fellow racer to help you out on the day
For what it's worth - the electric guys at your local club all use 48P.
greed4speed is offline   Reply With Quote
Old 02-09-2009, 05:52 AM   #9
Foxxrocket's Avatar
You speak the truth. That's the main reason I use 64P.
Twin Cities Rc Club Winter Carpet Season Mark O'Brien Minnesota and North/South Dakota Racing 5118 12-16-2017 10:22 PM
Tamiya F104 Pro! NT Electric On-Road 9387 10-18-2017 03:12 PM
Tamiya TA05 Touring Sedan kentech Electric On-Road 11403 06-21-2017 04:10 AM
Tub Cyclone `S` MR JOLLY Electric On-Road 1195 10-14-2016 04:44 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
1/10 Formula 1 Car Forums kuanseng1981 Singapore R/C Racers 4449 07-25-2015 12:28 AM
Xray T1FK05 Mdoc Electric On-Road 5433 01-31-2010 06:42 AM
