Old 11-09-2003, 02:46 AM   #1
Carbon_Fibre3's Avatar
Default Guage Wire used on Speedo
Hello, I am wondering whether or not there is any merit in running larger wires on the esc to the motor, and to the batteries... or should i already have 12 guage on there?
i am using a nosram dominator power, and lrp quantum comp..
i use the nosram in touring car stock (one day mod.. one day.. .. .. ) and the LRP in 12th scale 4 cell mod... they both currently have the standard 16guage.. ( i think) wire on them..
shoudl i go bigger? or no?
thanks
Rob Storey
Carbon_Fibre3 is offline   Reply With Quote
Old 11-09-2003, 06:45 AM   #2
i had a lrp v7.1 and it had 16 guage on it...when i re wire it my LHS told me to use 12 guage...i didn't really see or felt any difference...or maybe there is but can hardly notice it...but they said less resistance...
Los1Fan is offline   Reply With Quote
Old 11-09-2003, 10:50 AM   #3
On your TC you can if you feel it is necessary...but on the 1/12th keep the smaller wires, thicker wires can actually bind the suspension and cause handling issues.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 11-09-2003, 11:21 AM   #4
pro3racer's Avatar
smaller wire does have less resistance, but you must not go too small, otherwise power will be lost. Also, choosing a smaller wire is just neater, as in it gives your car a cleaner look, and gives you more room to work. A larger wire also has a better chance of touching something hot, or moving. I had big wires on my old pro3, and they were rubbing on a metal rod. The insulation burnt through, and it shorted out my battery. With a smaller wire, i could find a nice little place to zipp tie it.
pro3racer is offline   Reply With Quote
Old 11-09-2003, 11:57 AM   #5
dpaton's Avatar
Send a message via AIM to dpaton
Um..no. Smaller wire has more resistance.The reality of it is that with the voltage levels seen in RC cars, 14-16AWG is just fine for almost every use. The difference between 16awg and 12awg is so small it gets lost when compared to the inefficiency of 540 motors (50% if you're lucky) or imperfect driving (a few inches off the ideal line).
-dave
dpaton is offline   Reply With Quote
Old 11-09-2003, 12:15 PM   #6
Regional Moderator
disaster999's Avatar
i personally like smaller wires cuz they look a lot better on a 12th car, i see a lot of really good drivers at my track uses small wires. i was thinking its because for lightweight.
where could you find 16awg wires? i smallist i could find is 14
disaster999 is offline   Reply With Quote
Old 11-09-2003, 12:20 PM   #7
dpaton's Avatar
The difference in weight between 16 and 14 will amount to a few grams. Most of the 1/12 cars I see have lead on them to make weight
You should be able to get 16 at your LHS. Novak sells it, as do a bunch of others. You might have to order it if they don't have very deep stock.
-dave
Old 11-09-2003, 12:36 PM   #8
pro3racer's Avatar
dpaton- oops, sorry, i'm trying to remember 9th grade science. The bigger the wire the more "stuff" there is for the power to travel through. Which is resistance. The thing is you have to find the equal medium between losing power with small wire, or gaining resistance with big wire.
Old 11-09-2003, 03:52 PM   #9
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
A wire is like a hose, the bigger the wire is, the more freely the electrons flow.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 11-09-2003, 04:10 PM   #10
university_dave's Avatar
Ah yes, but it is lower than it would have been if contained in a wire. Plus you can move it around the chassis to alter the lateral and longitudinal weight distribution, and therefore the handling.
university_dave is offline   Reply With Quote
Old 11-09-2003, 05:42 PM   #11
stormperson's Avatar
Send a message via AIM to stormperson
The reason 12th scales run small wires is not to save weight (although it is a nice thought! lol)
Its because the wire will act as a spring since it spans over the chassis to the rear pod. On a sedan this is not an issue since the wire does not connect over to a pivoting part of the car.
Normally I run 16 guage on my 12th scale and 12 or 14 on my sedan.
R/C Excitement Special Projects Coordinator
Kwik | Speedmerchant | Parma PSE | KO Propo
Team Pickles
stormperson is offline   Reply With Quote
Old 11-09-2003, 11:08 PM   #12
Regional Moderator
-dave
which site sells 16awg wires? does tower have them?
Old 11-09-2003, 11:32 PM   #13
Send a message via AIM to ZER01
disaster, you can find 16AWG wire at tower from team associated, it only comes in orange and black though...
ZER01 is offline   Reply With Quote
Old 11-10-2003, 12:21 AM   #14
Regional Moderator
not really my kind of color...hhmmm...know any other places where i could find those wires?
Old 11-10-2003, 09:49 AM   #15
popsracer's Avatar
Default Gauge Wire used on Speedo
AND like water in a hose, smaller wire (too small) will increase pressure (resistance) and reduce flow (current). If you go TOO big, then you just add bulk and weight to the Car with no performance advantage.
Guys;
This is a REALLY good method to help someone get a better understanding of Electricity flowing in circuits.
I was contemplating increasing the Wire size on my new LRP-v7.1, but decided against it when told the Factory drivers run them with the 16ga wire and Mod's. Good enought for me then.
popsracer is offline   Reply With Quote
Hudy droop guage, ae droop guage, ae ride height guage Midnight R/C Items: For Sale/Trade 7 09-02-2008 09:43 AM
Which guage wire for battery? RoostAZ Electric Off-Road 3 09-04-2006 04:05 AM
12 Guage Racing Wire Silver Tinned 660+ fat500 R/C Items: For Sale/Trade 3 04-25-2006 05:49 AM
Looking for 16 guage wire for Speedcontroller noline Electric On-Road 9 12-26-2005 12:14 AM
12 Guage General Silicone Wire Ric R/C Items: For Sale/Trade 6 03-26-2002 07:21 AM
