Old 02-07-2009, 05:24 AM   #1
Default LRP TC Special 2 Motor slipping
Hi there,
Forgive me if I am repeating a question, but I have searched for a solution to the problem I'm having with no result
My motor's drive shaft seems to have come apart from the commutator assembly. The drive shaft can be pulled out of the motor housing. I investigated the issue after having a perfectly normal run when all of a sudden the motor seemed to be revving to maximum speed with little acceleration being reflected in the car.
Is the drive shaft within the motor meant to be, in fact, part of the commutator unit? (By commutator I mean the entire piece which fits inside the motor can.)
Does that make sense?
Any help would be appreciated.
vexersa is offline   Reply With Quote
Old 02-07-2009, 05:39 AM   #2
TRF415boy's Avatar
common problem with the LRP/Nosram motors.
You need a new rotor.
TRF415boy is offline   Reply With Quote
Old 02-07-2009, 05:54 AM   #3
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
common with the x11s.. the new x12s look very promising in the rotor department
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 02-07-2009, 06:20 AM   #4
Can the issue be prevented in any way?
Old 02-07-2009, 09:14 AM   #5
UK.hardcore's Avatar
His motor isn't a X11 or X12, its a brushed.
Maybe if all is still strait you can green loctite the shaft in the bobine?
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
