Old 02-06-2009, 07:24 PM   #1
Default Shock rebound
Can anyone tell me what shock rebound is?When i compress my shock
(with coil spring off) it slowly extends all the way out,is this rebound?
How do I get no rebound in my shock?
mnscott is offline   Reply With Quote
Old 02-06-2009, 07:30 PM   #2
Trader Rating: 41 (100%+)
to get no rebound you would be looking at a improper oil level in the shock and it will not function properly.
You should have some rebound. Depending on the shock it should be about 1/4 to 1/6th the extended length.
The reason ther is rebound is becasue there is a small pocket of air that is trapped in the end (under the bladder) to allow for the expansion of the oil level as the piston compresses.
Air being Compressable vs oil that is not will give and keep the oil from gettin gair bubbles.
If you did not install the bladder and over filled shock it would not be able to compress properly and risk blowing the cap off the end.
and too little will introduce inconsistant resistance witht he introduction of air bubbles.
I hope this was not too long
jdeadman is offline   Reply With Quote
Old 02-06-2009, 07:50 PM   #3
Thank you jdeadman,
The shocks are on a tc5r,the set up sheet in the back of the instruction
book says no rebound for front and rear shocks.Instructions for building
the shocks tell me to extend the shaft fully before installing the bladder.
If i hold the shaft(piston)half way up the body before installing the bladder
and cap will that change the rebound?
Old 02-06-2009, 08:22 PM   #4
TwoTone's Avatar
Originally Posted by mnscott View Post
Thank you jdeadman,
From what I've read, yes where you have the piston in the cylinder when you put on the bladder and cap is what sets the rebound.
I seen pictures where people use a cut piece of tubing on the shaft to make sure they get the rebound the same on all shocks.
TwoTone is offline   Reply With Quote
Old 02-06-2009, 08:56 PM   #5
Thanks Two Tone,I will give it a try.
Old 02-07-2009, 05:20 AM   #6
trerc's Avatar
Trader Rating: 89 (100%+)
[QUOTE=TwoTone;5398275]From what I've read, yes where you have the piston in the cylinder when you put on the bladder and cap is what sets the rebound.
I seen pictures where people use a cut piece of tubing on the shaft to make sure they get the rebound the same on all shocks.[/QUOTE
The amount of oil in the shock is what sets the rebound, too much and the shock won't bottom out and will rebound to quickly, to little and it won't rebound at all, you looking for a nice slow steady rebound. With that said, It's best to build shock per the manufacturers recommendations as there are many different types of shocks and the companies know there product best.
Fuel tubing is used as a travel limiter. It basically to shortens the shaft by not allowing full down travel which lowers the vehicle. Fuel tubing is about the worst way to do this as it's hard to get fuel tubing cut straight as it is flexible. It's almost impossible to build equal length shocks using fuel tubing as a limiter. It's better to use plastic spacers or o-rings as they are more precise.
trerc is offline   Reply With Quote
Old 02-07-2009, 06:34 AM   #7
Thanks trerc,
When twotone said to use the tubing I think he meant it went on the outside
of the shock(helps hold the pistons at the same positions)and remove the
tubing when the shock finished.
I tried this and now after the shock is compressed and released it extends
out half way,if I pull it out all the way it sucks back in half way.
Is this what they call no rebound?
Old 02-07-2009, 06:54 AM   #8
Regional Moderator
CarbonJoe's Avatar
No, when the shock shaft extends half way after pushing it in all the way is 50% rebound. If the shaft gets sucked back in after you pull it out all the way, you don't have enough oil in the shock (you are basically creating a vacuum that pulls the shaft back in). I generally shoot for 25 - 50% rebound. The most important part is to make them as close to the same as you can.
Here's what works for me:
1) fill the shock body to the top with oil
2) move the shock shaft in and out (with the cap and bladder off) several times. This will cause the trapped air under the piston to be "liberated"
3) let the shocks sit for 5 minutes to allow the air bubbles to escape (with the shock shaft fully extended)
4) place the bladder and cap on
5) bleed the shock to get the desired rebound. I loosen the cap slightly, push the shock shaft in slowly (forcing some oil out), then tighten the cap. Repeat until you get the right rebound, and no shock shaft sucking back in.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 02-07-2009, 06:57 AM   #9
~McSmooth~'s Avatar
Here's a picture of a proper Shock rebound.
DeSoto Racing * Franchise * Pro-One * Team Scream * Power Push * Team Ass
Badly influencing a new generation of racers!
~McSmooth~ is offline   Reply With Quote
Old 02-07-2009, 06:59 AM   #10
TwoTone's Avatar
Thanks trerc,
Yes that's what I meant.
I've always filled the shock to the top.
I'm going to try and find the passage I found about shock building and post it.
Old 02-07-2009, 07:33 AM   #11
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
This is the closest definition that I've read thus far and agree with just about everything mentioned. Great post trerc.
mnscott, check PMs.
RC America - Xray - Hudy - Gravity RC - KO Propo - Super Rad Graphics
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
F. Mendoza is offline   Reply With Quote
Old 02-07-2009, 08:22 AM   #12
OK,now i understand.I have replaced shocks on my snowmobiles,motorcycles
and cars but never rebuilt them.I didn't think the shock should retract on its own.
I didn't know how bleed a shock.
I will use the tubing for constant bleeding,the trick will be to tighten the cap
before the piston tries to change direction and draws air in.
A lot like bleeding brakes on car.
Team Associated TC5 RCknight Electric On-Road 13255 Today 02:22 PM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
New XRAY 808 Philipm Nitro Off-Road 12372 12-08-2015 07:43 AM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 11:26 AM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
I Hate Shocks! Nrctc3 Electric Off-Road 25 03-22-2005 06:41 PM
Making shock absorbers Lung Nitro On-Road 6 09-03-2004 09:33 PM
