What's a good brush stock motor? >
Old 02-03-2009, 07:23 PM
JustWill75's Avatar
Default What's a good brush stock motor?
I'm going to run a brush setup to get started. What is the best 27t stock motor out? Any chance of it keeping up with Brushless motors out now?
JustWill75 is offline
Old 02-03-2009, 07:35 PM
Default brushed motors
Just Will,
i have raced both 12th scale brushed as well as brushless, and all i can say is that you are better off running brushless as compared to brushed. i ran brushed with others running brushless and the brushless is a lot faster, but if you want to run brushed I would run a Trinity based co27 stock motor.
Robert
robert s is offline
Old 02-03-2009, 08:11 PM
berserk's Avatar
Default go brushless
go brushless, it is more efficient and easy to use. low maintenance, but if you prefer stock brush motor the one mention above is really a good choice.
berserk is offline
Old 02-03-2009, 08:22 PM
SammyZ's Avatar
Trader Rating: 138 (100%+)
Co27
SammyZ is offline
Old 02-04-2009, 09:55 AM
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
the mystery stock from trinity is also very nice, co27 is always good too of course.
Syber Serulean is offline
Old 02-04-2009, 05:25 PM
tdu verney's Avatar
Default Brushed Motor
EPIC X from Trinity excellent Watt producing motor it's all in the way you tune it.
tdu verney is offline
Old 02-04-2009, 05:40 PM
PutAwayWet's Avatar
The Trinity CO27 is the standard. Kept tuned, it will be fine against brushless 17.5's. Though the move to 6 minute sedan mains, if that's what you'll be running, will make your maintenance cycle shorter.
Have fun. I like brushed motors, myself. And yes, I run plenty of brushless.
PutAwayWet is offline
Old 02-04-2009, 06:06 PM
|JayFlores|'s Avatar
c027
|JayFlores| is offline
Old 02-04-2009, 06:09 PM
Ferrarimk13's Avatar
i was always told to find a good local tuner, based off the CO27. You should be able to find a bunch of different companies. There is brood, fantom, eurotek, EA, and several others that im forgetting.
Ferrarimk13 is offline
Old 02-04-2009, 06:26 PM
mok
mok's Avatar
my vote goes to Epic X or CO27 based motors...
mok is offline
