Old 02-03-2009, 07:38 PM   #1
cheehtae's Avatar
Trader Rating: 15 (100%+)
Default tweak chassis
is there anyway to fix a tweaked chassis? or just throw it away
tnx
cheehtae is offline   Reply With Quote
Old 02-03-2009, 07:57 PM   #2
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Depends on what kinda material, age, and how bad a hit (or hits) it took.
Aluminum chassis are difficult if not almost impossible to untweak. Fiberglass will develop microscopic cracks and weaken over time. A carbon fiber chassis has the best chance of being untweaked. The entire chassis would need to be completely disassembled, laid between two smooth flat surfaces, then weighted down for a couple of days.
Of course even a carbon fiber chassis will not last forever. It does have a memory of sorts, so it can be untweaked. The carbon fiber chassis can also develop microscopic cracks, but over a much, much longer time frame than fiberglass.
A fellow racer had the same 1/12 scale for about 6 years, and started to struggle with setup and performance. His vehicle was well maintained, and properly assembled. Finally he built a new car from the ground up and is doing much better. It was theorized the carbon fiber chassis parts were weakened over time. Causing the handling issues. Hope this helps.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 02-04-2009, 05:03 AM   #3
cheehtae's Avatar
Yes, it helped alot. I have a CF chassis and do what you said.
Thanks.
Old 02-04-2009, 04:05 PM   #4
You're welcome.
Three words...
Old 02-04-2009, 06:13 PM   #5
Teehomo's Avatar
Trader Rating: 24 (100%+)
If you are running a twin deck Carbon Fibre chassis, you could try this:
Remove the wheels and lay the car flat on a set up board.
Loosen the top deck screws and push the car flat.
Whilst holding the car flat, retighten the screws in the correct order (if it is badly tweaked you may need another set of hands to hold it down whilst you tighten).
You should then check regulalrly during the day, particularly after any heavy impacts - front on's seem to be the worst
Teehomo is offline   Reply With Quote
Old 02-04-2009, 08:49 PM   #6
cheehtae's Avatar
I found out what is tweaking my car, it's not my chassis but the bulkhead. One thing I'm not sure is I'm still using a plastic bulkhead, here is the thing; whenever I would tighten the 4 screws (x wise) chassis would tweak, but when I loosened the other two or take it out there would still be some but minimal.I would try running my car with just two screws, just hope it would not mess up my cars handling.
1/12 forum ovalnator Electric On-Road 46191 Today 07:43 AM
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 08:26 PM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Alex Racing Barracuda R2 & R3 SpeedTech Electric On-Road 14383 08-21-2014 07:06 PM
balancing your tc pakk Electric On-Road 12 04-18-2009 07:00 AM
You call it!! BrianH28 Electric On-Road 24 03-25-2006 10:33 PM
