GM-Racing Genius 95 1/12 Spec
anyone using this esc in 1:12 ?
Is it good? I want do use it with 4 cells and a LRP 9,5 Spec motor. Which rollout should I run? |
We are using the Genius 95 shrink wrap version in my sons CRC Gen-x 1/12th car. Last season we had lots of trouble with the electrics shutting down during every heat or final. We tried changing each component one after the other but did not really solve the problem. For this season we rebuilt all eletronics and replaced the old speedo with the Genius 95. The other stuff on the car is Futaba 9650/Sanwa 2.4Ghz/Corally 5.0T brushless w/o sensor. Caps both on speedo and receiver.
The car has been running just great in two races and we have not had even the smallest problem with the electric components. Also enjoy having less wiring as the speedo functions real well without the sensor. Our speedo setup is the factory settings. The size of this speedo is reasonable but it is quite heavy. Our layout is just like in the picture above and we have extra weight on the receiver side in order to have the car in left/right balance. |
did you try the programming via PC?
Originally Posted by florianlaux
(Post 5372517)
