Old 04-23-2009, 02:25 AM   #121
Reto, do I need to install the heatsink and the fan when running 4.5T in a touring car?
For 7.5T 2wd buggy with profile 1-4, will SPX Stock Spec get anywhere close to temp cut during summer time with high air temperature?
billythekid is offline   Reply With Quote
Old 04-23-2009, 03:21 AM   #122
Originally Posted by billythekid View Post
What brand is your 10.5T? I think different motor may react differently with SPX since they have different default hardware timing.
LRP 10.5t/17.5t, i wouldn't expect LRP to post anything regarding other motors
gameover is offline   Reply With Quote
Old 04-23-2009, 04:15 AM   #123
burito's Avatar
Yes for the TC, no matter if used with 5- or 6-cells with 4.5t, you'll need heatsink and most likely fan as well.
For your OffRoad combination you won't need a heatsink.
Reto Koenig
burito is offline   Reply With Quote
Old 04-23-2009, 10:37 AM   #124
hi guys, hopefully you can help me make my mind up..
i run lrp vector x11 10.5 and am looking for a new esc...
im looking at the SXX and the SPX competition
how close are the two? is the sxx the better speedo as latest out?
which one do i buy? is the SPX far better suited for 10.5 profile 7-8
or does the SXX do the same job in profile 9-10
please help as i really want to buy but dont want to buy the wrong one
mark
mark williams is offline   Reply With Quote
Old 04-23-2009, 01:39 PM   #125
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Anyone have an idea on gearing for a rubber sedan 17.5 with an SPX in profiles 6-7-and 8? This is a Novak 17.5 and I was running 3.50-3.75 with a GTB. Track size is 120' x 80'
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 04-23-2009, 02:08 PM   #126
Trader Rating: 62 (100%+)
Running a Duo 17.5, 0 timing i ran a 3.94 fdr profile #7 on a 100 x 60 track motor temp was 146* after 6 min.
The Wease is offline   Reply With Quote
Old 04-23-2009, 05:15 PM   #127
I am trying to setup a new LRP SPX COMPETITION but the mode and set buttons do not work.
when i turn it on the red mode led comes on, and it will power the motor on throttle, but i can not get into the setup or mode programming.
please help
thanks jon
jwilley is offline   Reply With Quote
Old 04-23-2009, 05:24 PM   #128
Skiddins's Avatar
mark
For 10.5 get the SPX Competition and no the higher profiles are not the same.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Old 04-23-2009, 07:08 PM   #129
Do you mean SXX Competition?
Old 04-23-2009, 07:24 PM   #130
Hi Reto,
The SXX is finally out, but in UK only!
http://demonpowerproducts.co.uk/prod...oducts_id=4350
Can you please give us the profile comparison between Sphere TC, SXX Competition and SXX TC?
For 13.5T and 17.5T off road truck and 2wd buggy, would you run SXX TC, SXX Competition or SPX Stock Spec, and which profile would you choose?
Old 04-23-2009, 11:49 PM   #131
Still Bill's Avatar
please help
thanks jon
Hi Jon,
Do you know to initially hold them down for at least 3 seconds to activate their respective modes?
If so, describe in detail what you are doing...
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 04-24-2009, 05:44 AM   #132
Skiddins's Avatar
No, the SPX is the better ESC for 'Stock' motors, the SXX, although it has better voltage drop characteristics etc. is mainly aimed at Mod drivers.
If the other ESC's by LRP are anything to go by (the descriptions of which are in this thread a page or two back) the only difference between the SXX and SXX TC is the heatsink!
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 04-24-2009, 06:25 AM   #133
burito's Avatar
Puuh, too many questions for me already...
Should re-name that thread in "Ask LRP" or something as it's not just SPX StockSpec related anymore.
Will try to answer the questions about SXX vs. SPX vs. SphereComp.
80710 vs. 80700/80750:
- explained in my post #101 in this thread I guess.
80900 vs. 80950 (the two SXX versions):
same internal hardware, difference is only heatsink/fan.
So 80900 is lighter, lower profile and doesn't come with a fan.
80900/80950 stock profiles:
SXX doesn't have "extreme stock profiles".
Nevertheless the SXX's profiles 9+10 will be suited well for stock, but I would suggest #80710 for hardcore stock racers as it has more aggressive timing.
Profile comparison between 80900/80950 (SXX) and 80700/80750 (Sphere):
We do have a nice chart in our SXX manual, which does explain curve, limiter and timing for easier understanding. See attachment under chapter 7. "Mode Programming".
SXX's steps for power profiles are finer then Sphere's and also it starts at slightly lower power in profile 1. What comes now is not 100% precise, as many small things have changed, but give you a good start and help to understand the SXX if you already use a Sphere:
SXX #1 -> slightly lower power then Sphere #1, but close
SXX #2 -> inbetween Sphere's profiles #1 and #2
SXX #3 -> similar to Sphere #2
SXX #4 -> similar to Sphere #3
SXX #5 -> inbetween Sphere's profiles #3 and #4 (that was quite a big step)
SXX #6 -> similar to Sphere #4
SXX #7 -> similar to Sphere #5
SXX #8 -> similar to Sphere #6
SXX #9 -> similar to Sphere #7
SXX #10 -> similar to Sphere #8
As said before, none of the profiles is 100% but this is the closest I can explain it and got all the teamdrivers understanding it as well...
Reto Koenig
Old 04-24-2009, 09:44 AM   #134
Thirtybird's Avatar
If I could sticky an individual post, that would be the one burito - TYVM!
Racing a Kawada SV-10 in 2010
http://omgitsakawada.blogspot.com/
The VTA Photon! (Inactive - back to the Kawada!)
http://vtaphoton.blogspot.com/
Thirtybird is offline   Reply With Quote
Old 04-24-2009, 10:27 AM   #135
Originally Posted by Still Bill View Post
Hi Jon,
Bill
i have been connecting the battery, then i switch on the esc, the red led comes on and then i try and press the set button for over 3 sec's but nothing happens.
Am i doing this right?
Jon
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
10.5 Setups matrix101 Australian Racing 14 06-05-2009 03:27 AM
LRP SPX and TC-SPEC Tral Radio and Electronics 15 04-21-2009 06:07 PM
LRP SPX Brushless Competition StockSpec ESC mazmo Australian Racing 10 02-16-2009 12:44 PM
LRP SPX Bullet Revise Burshless/Brush ESC chappi Australia For Sale/Trade 15 12-31-2008 08:29 AM
