Old 09-04-2010, 06:59 AM   #1066
eichkay's Avatar
Originally Posted by peter george View Post
Last week I ran in a 17.5 class and I was using the SPX on profile 7 but down the straight away I was getting killed.Every body had some kind of boost /timing advance speedo like the tekin.I don't think that I can compete with them can I? So the question would be LRP or tekin? almost every body tells me .....''if you wanna go fast ,you need a tekin'' any opinions?thanks
Rules are changing next year aren't they ? Id avoid buying a new esc so late in the year until you know the rules of the class your going to run in.
2011 AARCMCC National Titles 2wd Stock #1 -- 2011 AARCMCC National Titles SC Truck #2 -- 2010 WA AARCMCC State Titles, SC Truck #1
Offroad Schumacher Catsx & Cougar SV, X-Factory SCX60 Onroad Yokomo R12
www.stanbridges.com.au -- www.upgrade-rc.com
eichkay is offline   Reply With Quote
Old 09-04-2010, 07:42 AM   #1067
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Lightbulb From LRP forums
http://www.lrp.cc/forum/viewtopic.php?f=4&t=6883
I have a problème, i want to buy a LRP speedo for my Yokomo R12 to race in stock class (10.5), in a one Hand i want to buy a SXX SS and on the other hand i very interested with the SXX version 2
Any advice ?
For 1/12 10,5T I would highly recommend using a SXX Stock Spec. This will give you the power that you need and is way better suited then a normal SXX.
The hardware difference between the normal SXX and the SXX SS is very big and I am sure, even if it would possible to swap the different softwares, that a SXX will never have the same performance the SXX SS has.
Best regards
Mirco
Ok, so to me this sounds like the SXXv2 does not have the same boost capabilities as the SXX SS has.
On a side note.
One can find very good deals on previously driven Tekin and LRP speedos here at RCTech
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-04-2010, 07:53 AM   #1068
V2 does have boost.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 09-04-2010, 09:57 AM   #1069
peter george's Avatar
Trader Rating: 353 (100%+)
Originally Posted by Nilks View Post
The SPX can't keep up anymore. You either need a LRP SXX SS / LRP SXX V2, Hobbywing or Tekin to keep up.
I thought so, will it help if advance the timing on the motor ,and what roll out do you recommend for 17.5? Thank you again for your help.
Team Underdog - Team UPURZ -
peter george is offline   Reply With Quote
Old 09-04-2010, 09:58 AM   #1070
Wow I was not aware of that ...definitely good advise, thanks.
Old 09-06-2010, 08:05 PM   #1071
V2 does have boost.
is that you looking for an SPX? in the wanted threads?
Old 09-06-2010, 09:40 PM   #1072
tc3 racer sc's Avatar
Default how to gear a hotbodies cyclone
hi im still trying to get the gearing down for my hotbodies cyclone i have tried every thing from diffrent fdr /spurs but mostly used a 100 spur where i need to gear it AS for my cyclone tc i have a speed passion pro 2.0 with boost/ timing np there plse help
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 09-07-2010, 02:08 PM   #1073
No - I just sold my SPX. Looking to get a Tekin RS Pro or HW Extreme Stock.
Niklas Hansen
Old 09-07-2010, 02:29 PM   #1074
andrew-01's Avatar
Trader Rating: 22 (100%+)
On a side note.
So I wonder if they will be coming out with a SXX SS Ver2?
ANDRXW.com
andrew-01 is offline   Reply With Quote
Old 09-08-2010, 09:35 AM   #1075
Originally Posted by adam lancia View Post
I've got an SPX coming in the mail shortly, I'll be running 1s 12th scale. Can I wire in a 2s LiPo pack inline with the ESC switch and use the BEC regulator to regulate the Rx pack? Or does anyone know what the max BEC input on the ESC is? Thanks!
You can do this with a small 1C pack as long as you wire the correct polarity. Using the main ESC switch the ESC will then send 6.0 VDC to the receiver. The receiver will then feed the servo and transponder 6.0 VDC.
You will prossibly have problems wiring in a 2C pack as the BEC of the speedcontrol might have a hard time handling the 7.4 VDC from the 2C pack added to the main 1C pack that runs the car. That means the speed control will need to be able to handle 11.1 VDC (12.6VDC total) and I dont think it can do that. I think it has a limit of 9.6 VDC for 8 NmHD cells. Those 8 cells may peak at around 12 VDC, but I am not sure on this.
I ran the 1C battery (450mah) in this configuration for a couple years and had zero trouble. It was the fastest combination I had with the SPX Stock Spec speed control.
davidl is offline   Reply With Quote
Old 09-08-2010, 09:37 AM   #1076
The SXX SS is already in Version 3.
Old 09-08-2010, 09:38 AM   #1077
morgy's Avatar
i've just bought an spx stock spec and could do with some help gearing it, i'm running a 13.5 motor in a t/c on a tight carpet track
morgy is offline   Reply With Quote
Old 09-08-2010, 12:04 PM   #1078
No. The software is in version 3, but the unit itself is "only" version 1. As far as I know, they will put a SS V2 on the market.
Niklas Hansen
Old 09-08-2010, 03:01 PM   #1079
Thanks for the info David, I had read that in the Tekin thread about running a small 1s Rx pack along with the main 1s pack and was going to try it out once the ESC gets here. Would I wire it up the same as the attached picture in place of the 2s Rx pack?
adam lancia is offline   Reply With Quote
Old 09-09-2010, 07:37 AM   #1080
I had never seen the picture you provided. It is very interesting that the Tekin application used the 2C pack in that circuit. By the way, I interpret the drawing to show the 2C pack in the existing switch circuit of the speed control. Is that correct? I know some people that have connected receiver packs to the Tekin speed controls and their motor would run without a main battery connected to the speed control. I never knew how they connected it, but this looks like a candidate. Sort of makes me think that this type of connection in that speed control will provide more voltage to the motor than the main battery supplies. I have seen several people blow up their receiver packs when connected to the Tekin speed controls, also indicating something funny was going on.
Now to the LRP speed control. I have done this with a Sphere and an SPX Stock Speck version. The 1C battery goes in the switch wiring of the speed control. I didn't explain that in my earlier description because that was mentioned in the comment I quoted. So, now the thing to do is figure out which wire, both are black, comes directly from the big battery, through the speed control to the switch. It can be done with a volt meter. Disconnect that wire from the switch and connect it to the negative side of the small 1C battery. Then connect the positive side of the battery to the switch and you are ready to mount it in the car. You will now measure 6.0 VDC to the receiver from the connection from the speed control, indicating that the BEC of the speed control is functioning properly. That will enhance the operation of your radio system, too. By the way, my battery was a 145 mah 1C lipoly for small helicopters. It was very light and easily mounted in the car.
I put a small JST connector on the two outputs of the small 1C battery for charging. This circuitry has been verified with Reto, but I don't think they will honor warranties if you blow it up while wired this way. They will have to answer that.
Hope this helps. Good luck.
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
10.5 Setups matrix101 Australian Racing 14 06-05-2009 03:27 AM
LRP SPX and TC-SPEC Tral Radio and Electronics 15 04-21-2009 06:07 PM
LRP SPX Brushless Competition StockSpec ESC mazmo Australian Racing 10 02-16-2009 12:44 PM
LRP SPX Bullet Revise Burshless/Brush ESC chappi Australia For Sale/Trade 15 12-31-2008 08:29 AM
