Old 02-16-2010, 01:33 PM   #1006
I got an SPX and really likes it. So far I have been running 17.5T LRP X11 with it, with an FDR of 4.6 in an Xray T2'009. ESC setup: 1/8/1/2. I wan't to start practicing with an 13.5T SpeedPassion V3. What would be a good starting FDR?
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 02-22-2010, 05:23 PM   #1007
BLUE 2's Avatar
Trader Rating: 23 (100%+)
Unhappy
Hi
Anyone tried the new X12 17.5 on this speedy ?
And has any one tried profile 7 - 8 with this motor ?
I have one fitted & it sounds ok in the car but i have no idea what gearing to run as i am using profile 6 with +5 timing block fitted to motor .
Motor is also really clunky when you push it along the bench & running it with out the pinion the motor sounds like a worn out brushed motor at times ( low down it the motor revs )
Any help
Cars Offroad : TLR 22B - TLR 22B 2.0 - TLR 22T - TLR 22SCT - TLR TEN-SCTE 2.0
Cars Onroad : HB Cyclone TC - TRF 416X - Tamiya TA05 - Serpent s411 eryx 2.0
BLUE 2 is offline   Reply With Quote
Old 02-22-2010, 07:00 PM   #1008
kawirider's Avatar
Trader Rating: 14 (100%+)
my 13.5 does the same thing. dont worry about it. it seems to do it more when there is alot timing in the speedo. i have a spx i run with a 13.5 and i have it turned up to 8 but with lower static timing in the endbell of the motor. just run it and check temp often to make sure you are not overheatin the motor. if you really want that stock motor to rip get a tekin RS. fastest speedo i have ever had period!
Associated T4, CRC Gen XL, Associated 10R5 WGT, jconcepts BJ4
Josh Evans
kawirider is offline   Reply With Quote
Old 02-22-2010, 10:58 PM   #1009
BLUE 2's Avatar
Talking
Hi
Thanks for the input & i think i will try taking timing out of the motor & profile 7 to start with as i have some idea of the gearing needed .
I want to run no hotter than 80 deg , is this a good temp to aim for ?
Old 02-23-2010, 04:19 PM   #1010
ive had to dig up my spx again as i wait for the sxx to come back from germany
what ratio and timing would you guys sugest for the spx with a 13.5 lrp x12 on a 30m x 16m indoor carpet track cheers
Burney is offline   Reply With Quote
Old 03-02-2010, 03:32 PM   #1011
pmc
hello
wish is the best option to run a Spx in mode 8 with a speed passion V3.0 10,5
Run the motor in standard timing or advance the timing in the motor??
thanks in advance.
Best regards:
Pedro Silva
pmc is offline   Reply With Quote
Old 03-03-2010, 11:43 AM   #1012
kuanseng1981's Avatar
Trader Rating: 15 (100%+)
Hi guys need some help here as I got a blown SPX and wonder where do I send it for repair? Thanks
Friends come and go,
who's your friend nobody knows,
till the time than it will show,
who is friend who is foe.
kuanseng1981 is offline   Reply With Quote
Old 03-03-2010, 03:53 PM   #1013
Fast XXXS's Avatar
Trader Rating: 49 (100%+)
Originally Posted by pmc View Post
hello
thanks in advance.
Best regards:
Pedro Silva
I wouldnt run profile 8 with that motor. Guys i know run either profile 6 or 7 with the SP 10.5. Not sure about timing on the motor but in my opinion add timing according to motor temps. Once timing goes up so do temps.
Fast XXXS is offline   Reply With Quote
Old 03-04-2010, 02:27 PM   #1014
pmc
Hello
thanks for the answer.
Best regards:
Pedro Silva
Old 03-05-2010, 12:00 AM   #1015
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Hey guys, I am running a 13.5 on a small track tomorrow and it will be overpowered for the track. It is a small track with tight turns and punchy straights. Should I use the lowest power profile and adjust the EPA in the radio or use a linear or higher profile and adjust the epa in the radio? I am afraid that if I use a lower profile the negative exponential that will occur in the ESC will hurt me on the track. Thanks for any help or advice...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 03-08-2010, 01:36 PM   #1016
ATLASCOPCO's Avatar
Can someone tell me how to test the power cap please
ATLASCOPCO is offline   Reply With Quote
Old 03-08-2010, 02:57 PM   #1017
ATLASCOPCO's Avatar
Old 03-08-2010, 03:51 PM   #1018
Johnny Wishbone's Avatar
Use a multimeter set on resistance, you should be able to read some factor of resistance, but not a open. If your unit has been on, turn it off, disconnect your battery and with your meter set on voltage you should be able to read a voltage across the cap, although this will bleed quickly over the meter and you may not see a reading.
Old 03-08-2010, 06:02 PM   #1019
Danny-b23's Avatar
With the V3, I would start around a 5.0 FDR and add teeth as needed. These motors have gobs of torque, and run really well with max motor timing, and the settings you have listed here.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 03-09-2010, 02:21 PM   #1020
ATLASCOPCO's Avatar
Hi i hope someone can shine some light on this problem for me .
I have been useing the same motor setup gearing batterys for the past 6 meetings but on my last meeting i had a problem where the speed and punch droped off after about 3.5 to 4 minutes the motor is not getting hot either and the speed controller was purchaced at xmas
thanks in advance
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
10.5 Setups matrix101 Australian Racing 14 06-05-2009 03:27 AM
LRP SPX and TC-SPEC Tral Radio and Electronics 15 04-21-2009 06:07 PM
LRP SPX Brushless Competition StockSpec ESC mazmo Australian Racing 10 02-16-2009 12:44 PM
LRP SPX Bullet Revise Burshless/Brush ESC chappi Australia For Sale/Trade 15 12-31-2008 08:29 AM
