Old 01-20-2010, 12:43 AM   #961
Benzaah's Avatar
Trader Rating: 21 (96%+)
I must have a freak motor as my17.5 Fantom Duo 1 has run at around 185f all the time with no fade. Something else must be up as I would be gearing up if i was coming off at 165.
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 01-20-2010, 01:53 AM   #962
Originally Posted by Benzaah View Post
You must be living in a fish bowl not to know the new SXX Stock Spec is days away. Give it 2 weeks and Tekin will be behind the ball park AGAIN
I'm aware of the SXX Stock Spec. I don't think it will have much of a chance if you can't update it with new software like the Tekin. I hope you're right....
Obsidian is offline   Reply With Quote
Old 01-20-2010, 06:04 AM   #963
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
At some point the motors will be at the physical limits of what they can do, regardless what the speedo says. Don't know how close we are to that for say 17.5 but update or no this cycle is finite. From what I am hearing the battle will be on at the Birds we shall see.
Rod
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 01-21-2010, 11:06 AM   #964
RKeasler's Avatar
ClemsonTigers
USVTA # 224
ERC
Old 01-22-2010, 02:15 PM   #965
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
I just got a spx esc, I plan on running it in a Kyosho rb5 geared 31-72 for a 90x40 medium traction layout with a Orion 17.5 v2 motor and 35c lipo.....what would be good profile settings to start with? Thanks for any help!
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 01-22-2010, 05:26 PM   #966
I don't run 17.5 but, if I remember correctly, a good starting point is:
1,7,1,1.
Be sure to pay close attention to your motor temp by checking it every two minutes or so to keep it below 165F.
I'm sure someone else will chime in with a similar or better profile.
Cheerz
Old 01-22-2010, 11:05 PM   #967
Tpg racer's Avatar
If i were to remember correctly Kyosho RB5 is an electric offroad machine right? If that is true, i think its better for you to stay away from profile 7 and 8... Try something lower with more linear feel and less aggressive power....
Maybe profile 4-6 perhaps....
Tpg racer is offline   Reply With Quote
Old 01-23-2010, 12:43 AM   #968
Opps...yes you are right. I was thinking on road.
Old 01-23-2010, 07:51 PM   #969
Default LOSI TYPE R
What gear ratio are you guys running ON A LOSI TYPE R car with a 17.5 , my track lane is 97 in the staight way. I run the SPX speed control and duo 2 17.5 osmesis 13.5, what spear and pinion or roll out on this car would be recomended.asphalt where can I find a good asphalt setup and carpet. What Profile you guys recommend?for spx
thanks alot
losiracin
losiracin is offline   Reply With Quote
Old 01-23-2010, 07:54 PM   #970
Danny-b23's Avatar
thanks alot
losiracin
As a starting point I would go with profile 8 on the ESC with a 4.5 FDR for the 17.5, and a 5.5 FDR for the 13.5. Just adjust gearing based on your motor temps from there.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 01-24-2010, 12:01 AM   #971
Trader Rating: 8 (90%+)
[QUOTE=RKeasler;6880021]At some point the motors will be at the physical limits of what they can do, regardless what the speedo says. Don't know how close we are to that for say 17.5 but update or no this cycle is finite. From what I am hearing the battle will be on at the Birds we shall see.
Its funny that you mention motor limitations.. With no mention of what electronics were being used. I heard a motor BLOW tonight at our track....poor kid. When they took it apart it the magnets were in small pieces. This happened when the car was not on the track right after it was soldered up and the motor he was running before he could not get it it run below 220 not matter what he did. All and all it was a crazy night for elctronics at our track as that wasnt the only ghost that decided to show up
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris [email protected]
Tha Skinny is offline   Reply With Quote
Old 01-25-2010, 12:28 AM   #972
Jamesalex's Avatar
Hi,
I am looking for some help with this stock spec lrp.
I have installed it in my GT car with a 3.7v lipo and 10.5 motor LRP x11 and reciever pack and the thing just seems slow as.
My tires are 56mm with a 96 spur and I was running about 56/58mmr, tire diamiter is 56mm
I was wondering if you can point me towards
What settings people are running on the speed controller
What timing on the motor
What roll out people are running
and any other tips to make this thing quick
Thanks in advance
James
Jamesalex is offline   Reply With Quote
Old 01-25-2010, 05:31 AM   #973
fleetmaster's Avatar
Trader Rating: 16 (100%+)
Knowing your current settings for profile/motor timing will help.
I personally would try profile 8 and try 5 deg. motor timing at first.
Gear it for temp. then try 10 deg.
My theory is that lower V=lower amps= lower temp=more timing allowed.???
fleetmaster is offline   Reply With Quote
Old 01-25-2010, 05:46 AM   #974
Jamesalex's Avatar
sorry fleetmaster, I was driving to work and realised i forgot to put that info on lol.
currently run 2/6/0/0 but also tried 2/8/0/0 in the last final
In terms of motor timing I have never really played with that as I am not sure what way to move the timing ring on the x11 I believe it is fully rotated to the left
Old 01-25-2010, 06:09 PM   #975
Still Bill's Avatar
James,
First off...Most using 1-cell lipos use the Nimh (1) setting; so, we don't come up against the lipo cutoff. Would say that this is most important if you are using an LRP X11 10.5.
My settings on my WGT were set 1-8-1-1 with a Duo 13.5 on a medium sized carpet track.
Because you are talking about an all LRP setup (ESC and motor), I suggest that you contact "Burrito" on this website for the best answers. Burrito (Reto) works for LRP and only addresses issues their equipment. His answers are really insightful.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
10.5 Setups matrix101 Australian Racing 14 06-05-2009 03:27 AM
LRP SPX and TC-SPEC Tral Radio and Electronics 15 04-21-2009 06:07 PM
LRP SPX Brushless Competition StockSpec ESC mazmo Australian Racing 10 02-16-2009 12:44 PM
LRP SPX Bullet Revise Burshless/Brush ESC chappi Australia For Sale/Trade 15 12-31-2008 08:29 AM
