Old 01-07-2010, 09:34 AM   #931
Originally Posted by Drillit View Post
Sorry to say, but the Tekin with the 203 program is that good, at least this week it is.
The guy I pit for made the switch, but I'm sure he'll be back to Blue when they are the fast-one-of-the-week again. He's just that competitve.
dude i pitted with five teken drivers last weekend. in practice i was on the pace they got the update before round 1 and absolutely creamed me i coudlnt compete i did find a few quick set ups but they all was running way too hot to stay on
Burney is offline   Reply With Quote
Old 01-07-2010, 09:48 AM   #932
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
I'm praying that they won't be able to handle the speed and crash, it's the only way that I am going to pass them.......or pony-up for "speedo" of the week.
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline   Reply With Quote
Old 01-07-2010, 09:50 AM   #933
Drillit's Avatar
Now if I could find a place to get some trailer parts.........
Mark Tilley
Old 01-07-2010, 09:51 AM   #934
gashuffer's Avatar
Trader Rating: 48 (100%+)
Originally Posted by Damnit Man View Post
Sorry to sound stupid, but how do you set these up for 1S. I just connected mine to a receiver, plugged in a servo to the receiver, and then plugged in a receiver pack. I performed a radio check, throttle worked fine, steering worked alright, but then when I switched off the speed control smoke poured from it. Now it will only power up when the receiver pack is plugged into the receiver. I think I broke it...
Did you disable your cut off? Also when using a rx pack I believe you need to disconnect one of the wires(not sure which one though) so you can bypass the esc. I think you just fried it with too many amps. Sorry to hear that. Again i'm not sure if i'm correct with my statement.
T-Sal
gashuffer is offline   Reply With Quote
Old 01-07-2010, 10:01 AM   #935
Drillit's Avatar
I have wired these for 1s with rec pack in 12th and wgt, you have to pull the red wire out of the connector at the receiver. In some cases you cannot have power going in from 2 sources or the above happens
Take a look into the single cell/1s threads for more on this including the use of a 'booster' instead of a nimh/lipo rec pack.
Mark Tilley
Old 01-07-2010, 10:58 AM   #936
Tpg racer's Avatar
Originally Posted by Burney View Post
yeah so i got absolutely smoked this weekeend by all the tekens some even running the same motor.
anyone run this motor and have a sweet spot they can reccomened i tried most things coudlnt get it anywhere near them is this Teken set up that good.
it was indoor carpet on a very basic layout 4 corners if that 70m stright including sweeper
profiel 8
i was 45 timing
8.2 gear ratio on an xray
got smoked on straight and not much punch in the infield helppppp
cheers
8.2 FDR with a 13.5 motor? is it just me or is that ratio too high for 13.5 motor? i thought it should be in the range of 6-ish ?
Even with 11.5 we were already running in the mid 5 to 6 FDR
Sorry if my post sounds ridiculous coz ive never run 13.5 before
Tpg racer is offline   Reply With Quote
Old 01-07-2010, 11:24 AM   #937
no your post isnt ridiculus it is an unusual one for 13.5 but with all these different power options and timing everyone seems to be on diffeent ratios
me and my pals run full timing on the motor and to combat the heat and get punch we run high ratios in the 8's
so far its the only way to we can get the best speed out of this esc and motor package. for me if i run no timing and keep the car around the standard 5's it just gets absolutely smoked down the straight
Old 01-07-2010, 12:50 PM   #938
Stein Tumert's Avatar
One of the guys here is also running FDR 8.2 with SPX and SP V3 13.5T motor. He smokes all the other guys...
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 01-07-2010, 07:22 PM   #939
ChadRacing's Avatar
Can someone help me find a FDR to run for a Foam 13.5 TC?
I am running a SPX on profile 7 with a Nemesis 13.5 on a xray 009 US Spec. Trying to set it up for a 100ft straight on a high bit carpet track.
Thanks in advance
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
Old 01-12-2010, 09:14 AM   #940
M-Technic's Avatar
Trader Rating: 15 (100%+)
Has anyone had any luck combating the new Tekin RS software with their SPX? I have been running Profile 7 with my Duo2 13.5 with almost full timing (half a tick from full), and a 6.9 FDR. It was previously one of the fastest cars on the track. Now the Tekin RS v203 firmware has a lot more rip out of the corner, although the straight-away speeds are similar.
I am thinking about switching to Profile 8, lowering the timing down to 1 or 2 ticks past 0, and gearing down to a 6.0 or so. Yay or nay?
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 01-12-2010, 12:22 PM   #941
gashuffer's Avatar
Go low 5's for FDR.
T-Sal
Old 01-12-2010, 01:10 PM   #942
M-Technic's Avatar
Go low 5's for FDR.
With what timing? What profile? And what do you base that on? I thought you were running a black can motor.
Not trying to hassle you, I'm just trying to gather the best knowledge now that I am getting motored by the Tekins.
Old 01-12-2010, 02:12 PM   #943
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
If anyone is interested, I have a NIP SPX for sale...
http://www.rctech.net/forum/r-c-item...w-package.html
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 01-12-2010, 03:42 PM   #944
gashuffer's Avatar
that's just from what I have been reading, but I will be running 13.5 in my X. See you out there one day I tried to come up on Sunday to race but I got a flat on the 95 about 20 miles to short and my doughnut was flat I took me forever to get home and I didn't get a chance to run.
T-Sal
Old 01-12-2010, 03:46 PM   #945
HI_808's Avatar
Supposedly Jon Tag said that true 0 degree timing is actually three marks advanced past the long line on the Duo2. With that motor timing, I tried profile 8 at 6.3 FDR with my 13.5 Duo2 and it is fast, but not nearly as fast as the RS with a Duo2.
The new software took the Tekin to another level. Version 203 brought about the first time I felt truly out powered by the RS when using the SPX. 13.5 is no longer like super stock; it's like mod.
HI_808 is offline   Reply With Quote
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
10.5 Setups matrix101 Australian Racing 14 06-05-2009 03:27 AM
LRP SPX and TC-SPEC Tral Radio and Electronics 15 04-21-2009 06:07 PM
LRP SPX Brushless Competition StockSpec ESC mazmo Australian Racing 10 02-16-2009 12:44 PM
LRP SPX Bullet Revise Burshless/Brush ESC chappi Australia For Sale/Trade 15 12-31-2008 08:29 AM
