Old 04-18-2009, 10:41 AM   #76
Skiddins's Avatar
Originally Posted by franc furter View Post
Im thinking of buying an spx. I currently run a losi xcelorin speedo with a 13.5 duo. The losi has adjustable timing so i was wondering if i would see a difference running a spx. Also if i get a spx how should i set timing on motor and spx. My track is 100'-35'. Thanks!
I don't know much about the Losi, but everyone who has an SPX I know loves it.
I would put the the timing back to standard, gear down at least 1 pinion and see what happens
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-19-2009, 05:00 PM   #77
maxepower's Avatar
Exclamation
Originally Posted by Skiddins View Post
I think you've cooked the motors.
Remember, lowering the gear ratio means a higher number FDR, 5.0 is lower than 4.1 etc.
You should have gone down to FDR 4.1 or something if you went up the profiles, not the other way around.
Try a different motor.
Skiddins,
Thanks for the help, I thought I knew what I was doing with the SPX! Obviously not! Hopefully, I can get a couple more motors and try again. I like both Novak and Speedpassion motors for 17.5. One seems to be more torque and the other more RPM. I let you know next week if I get it right this time!
Max
maxepower is offline   Reply With Quote
Old 04-20-2009, 09:36 AM   #78
Thirtybird's Avatar
Default sensor wire?
I'm thinking about getting this ESC - can anyone who bought one let me know if it came with a sensor wire?
Racing a Kawada SV-10 in 2010
http://omgitsakawada.blogspot.com/
The VTA Photon! (Inactive - back to the Kawada!)
http://vtaphoton.blogspot.com/
Thirtybird is offline   Reply With Quote
Old 04-20-2009, 09:46 AM   #79
Trader Rating: 62 (100%+)
yes it does come with a sensor wire
The Wease is offline   Reply With Quote
Old 04-20-2009, 11:01 AM   #80
mickrcarver's Avatar
Trader Rating: 98 (99%+)
dunno about Lrp,sent a lrp sphere tc edition back over a month ago for warranty work ,I bought this brand new and it did not work out of the package,sent it back w/track and confirmation signiture,says it got there,signed for it, they cant find it so they said they would ship me another new one ,well 2 weeks nothing still,they say there back ordered,So 1 month and no racing oh well ill wait more I guess
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is online now   Reply With Quote
Old 04-20-2009, 01:40 PM   #81
In Europe, the motors come with the sensor lead, but the speedos don't. Best to double check, since I think the packaging and product are the same the World over. HTH
SlowerOne is offline   Reply With Quote
Old 04-20-2009, 02:09 PM   #82
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
These speed controls are so fast they should be outlawed!!
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 04-20-2009, 04:10 PM   #83
Default Fan
I just jumped all in on this Speedo. I bought three of them. After reading some of the instructions there is an option for the fan. I will mainly run 8.5 to 21.5. I am in Cali so it does get hot when running on asphalt. Does any one recommend it? I have a LRP TC and it looks like the fan is soldered on the board how does the optional fan work? Thx for your help.
hacker1 is offline   Reply With Quote
Old 04-20-2009, 06:32 PM   #84
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
up to 8.5T the heatsink is more than enough
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 04-20-2009, 07:17 PM   #85
maxepower's Avatar
Cool
I tried using another motor and no change, then I checked the profile and it was on #3 not #6 to my amazment the car came back to life. I have no idea how I put it on #3 but I did. I think if you get out of the set-up mode by shutting the ESC off. It doesn't save you settings! I feel like such a newbie!
Old 04-20-2009, 10:08 PM   #86
DriftDreamer06's Avatar
i love the SPX - started with 4-cell gtb then to sphere comp 07 and now SPX. in my 1/12 it is .....
i am learning how to drive again!
Racin'4-fun --- kicking some a$$ on the way
DriftDreamer06 is offline   Reply With Quote
Old 04-21-2009, 06:56 AM   #87
Skiddins's Avatar
Yep, that's standard on all the LRP/Nosram ESC's, you must go through all the settings and back out to the solid red LED, anything else and the settings aren't changed.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 04-21-2009, 10:43 AM   #88
Does anyone knows if the heat sink is needed to be attached to SPX Stock Spec when running it with a 10.5T touring car?
How about 7.5T in a off road truck or 2wd buggy?
billythekid is offline   Reply With Quote
Old 04-21-2009, 10:49 AM   #89
From my understanding, switching from Sphere TC to SPX Stock Spec, I suppose to lower 2-3 tooth on the pinion when running profile 5-8 with a stock motor.
Do I have to lower 2-3 tooth on the pinion if I am running a modified motor with Profile 2 or 3?
Old 04-21-2009, 12:57 PM   #90
Trader Rating: 16 (94%+)
I think with a 7.5 in Off-Road or a 10.5 in a TC would run ok, but you would be pushing the thermal limit depending on traction and outside temperature. Good thing is that it will thermal shutdown if it gets too hot. To be safe, put the heatsink on it.
kn7671 is offline   Reply With Quote
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
10.5 Setups matrix101 Australian Racing 14 06-05-2009 03:27 AM
LRP SPX and TC-SPEC Tral Radio and Electronics 15 04-21-2009 06:07 PM
LRP SPX Brushless Competition StockSpec ESC mazmo Australian Racing 10 02-16-2009 12:44 PM
LRP SPX Bullet Revise Burshless/Brush ESC chappi Australia For Sale/Trade 15 12-31-2008 08:29 AM
