Old 11-26-2009, 11:26 PM   #871
Fast XXXS's Avatar
Trader Rating: 49 (100%+)
Thanks for your help! Im running SMC 5200 40C Packs so they should go pretty good. Thinking about getting some intellects though. I don't usually go by rollout so you wouldn't know how to convert it to FDR?
Cheers
Fast XXXS is offline   Reply With Quote
Old 11-27-2009, 04:35 AM   #872
Default LRP SPX
Hello All,
I am new with SPX. Can someone tell me what the different profiles of the LRP SPX do ? How they work and what the result is on the motor (10.5). Or where can I find such info on the net ? All help is welcome. Thanks.
Tia.
evolution1 is offline   Reply With Quote
Old 11-27-2009, 05:28 AM   #873
Benzaah's Avatar
Trader Rating: 21 (96%+)
Cheers
Vote 1 SMC. Although i have 3 of these packs they like it when you use only one a day and just thrash the pack and recharge. Ive found rotating packs counter productive and the pack gets better after 2 or 3 runs. Weird
As for FDR and Roll out.
http://www.rcracing.com/Gear_Ratio_Program_1100.cfm
Add your details and 63mm tyre diameter and youll be set.
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 11-27-2009, 08:46 AM   #874
Toh WL's Avatar
Originally Posted by evolution1 View Post
Hello All,
Tia.
The higher the speed profile, more punch more speed. Please check your gearing & best to have motor heat sink with fan.
Toh WL is offline   Reply With Quote
Old 11-27-2009, 04:25 PM   #875
Hello All,
Tia.
i rn indoors with a 10.5 Speed passion 3.0 and the SPX
we have a technical but flowing track with a 30m straight , and i run gearing of 105/37(trf416 with a final drive of 2.0556) on program 7
i added 2 teeth to the pinion to settle the car out of corners instead of going down a program because i still wanted the timing boost of program 7 , it works well for me
Hope this helps a little
sidecarphil1 is offline   Reply With Quote
Old 11-27-2009, 05:05 PM   #876
adamge's Avatar
Those guys who said their SPX lost its boost, how could you tell?
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 11-28-2009, 08:23 AM   #877
Originally Posted by Nilks View Post
As far as I know (new to electric though):
If only the motor is hot, it is undergeared. Put on a bigger pinion or smaller spur.
If the entire system is hot, it is overgeared. Put on a smaller pinion or bigger spur.
Please correct me if I am wrong. I am new to electric - just got told the above mentioned.
Went racing at my local club last night. Ran the car in practice with a ratio of 6 (24/84), came off at 85deegrees, it hit top speed 2/3rd along the straight, catching cars in front but lacking the speed to get past them.
Dropped the ratio down to 5.6, car came off cooler (65 degreesC), quicker down the straight but lacked punch out of the corners. Went to up to 5.8, just as quick down the straight, had way more punch out of the corner, came off at 68degreesC.
Final run I went from setting 7 to 8, came off at 73degrees.
All in all, much better than it was before (90degrees C). Not running a fan. The brakes on the stock spec are immense, making loads of ground down the straight and on the brakes into the tight turn at the end. Shame the tyres have seen there best though.
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 11-28-2009, 12:45 PM   #878
Timing boost : what is it and when works it ?
Thanks.
Old 11-28-2009, 01:02 PM   #879
Thanks.
if your gearing is correct on the straight you will see the car get like a second gear
i just altered the gearing to remove the agression from the motor on throttle out of slower corners
i believe the timing boost is only available in programs 7 and 8 but may be corrected
i find the car is more stable with this setting , i got the gearing spot on and then altered it by 2 teeth higher on the motor to tame it
Old 12-01-2009, 12:22 PM   #880
ali_g's Avatar
Does the timing boost work for brushed motor?
ali_g is offline   Reply With Quote
Old 12-01-2009, 02:20 PM   #881
Hebiki's Avatar
Trader Rating: 26 (100%+)
nope. only brushless.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-03-2009, 04:23 AM   #882
about to install this speedo today hopefully when i run it on sunday someone will have one so i could gauge where i want to be for ratio. running in 13.5 class with an xray
i had the nosram matrix istc before and ran at 4.9 with a novak motor
i want to run on the highest profile 8 at a guesstimate what ratio would you guys suggest for this track ?? thanks
http://www.youtube.com/watch?v=r-FI2...eature=related
Burney is offline   Reply With Quote
Old 12-03-2009, 08:07 PM   #883
Still Bill's Avatar
Burney,
With my SPX on 8 and my Trinity Duo 13.5 set to the center timing, I run a 5.7 rollout on a similar track.
That was a nice race on youtube!
Cheers!
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 12-04-2009, 04:45 AM   #884
Originally Posted by Still Bill View Post
Burney,
Cheers!
Bill
ok cheers i reckon i will start around that myself the tech sheet came out for last months round which was at the same track but with a slightly different layout and the two spx users ran 5.34 and 5.1 glad i know a couple of people are using it now so i can get some tips of them on the weekend but generallly i think i will start 5.7 and see how it goes
http://hrcc.no-ip.com/gallery/albums...d2%2013.5T.jpg
Old 12-04-2009, 12:56 PM   #885
Default LRP SPX with Duo 2 10.5 1S lipo problems
Experiencing problems running a SPX with 1S lipo and DUO 2 10.5 Setup on SPX is 2,8,0,0 After a couploe of laps Esc basically shuts down. It has been suggested the profile 8 is too aggressive .
Tried same setup with Novak and no rpoblems.Anyone else experienced problems with profile 8 and DUO 2 motors.
As an after thought running a Novak booster.
tellan is offline   Reply With Quote
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
10.5 Setups matrix101 Australian Racing 14 06-05-2009 03:27 AM
LRP SPX and TC-SPEC Tral Radio and Electronics 15 04-21-2009 06:07 PM
LRP SPX Brushless Competition StockSpec ESC mazmo Australian Racing 10 02-16-2009 12:44 PM
LRP SPX Bullet Revise Burshless/Brush ESC chappi Australia For Sale/Trade 15 12-31-2008 08:29 AM
