Old 10-12-2009, 09:07 PM   #751
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
In my case I ran at 7 because it was a parking lot race. It was loose out and I was starting to feel like the drift king Had to smooth it out a bit.
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 10-12-2009, 09:10 PM   #752
Still Bill's Avatar
Originally Posted by RAL View Post
In my case it I ran a 7 because it was a parking lot race. It was loose out and I was starting to feel like the drift king Had to smooth it out a bit.
RAL,
Ah ha! That explains the Profile 7 you used. Sorry, but I'm been spoiled in NorCal and shy away from tracks that don't offer good to excellent traction conditions.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 10-12-2009, 09:24 PM   #753
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
One of my buddies had a stuttering problem when he ran also on the back straight. It ended up being his spektrum. He swapped to crystals and it stopped.
Dont know if thats your problem. But something to look into
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 10-12-2009, 11:03 PM   #754
RAL
RAL's Avatar
I am running a spektrum module. I wonder if its a voltage thing or some sort of freq. emitted from the spx?
Old 10-13-2009, 01:39 AM   #755
Benzaah's Avatar
Trader Rating: 21 (96%+)
Originally Posted by Still Bill View Post
RAL,
Bill
I guess us mere mortals can only dream of such perfect racing conditions.
I run 7 because i find it nicer to drive and im a bit of a hack I think the average racer does not need these extra profiles to keep up and we have a fast guy at the track who runs profile 6 and keeps up fine. CAN YOU BELIEVE IT! Profile 6 for goodness sake
Adelaide RC - XRAY Xb2’16de & Xb4’16
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 10-13-2009, 02:43 AM   #756
CanyonCarverR1's Avatar
Can I assume that in my 1/12 running LiPo 1S with a 17.5, I'm going to go with profile 8?
CanyonCarverR1 is offline   Reply With Quote
Old 10-13-2009, 09:12 AM   #757
ASM
ASM's Avatar
Trader Rating: 21 (100%+)
I was running a 13.5 @ 6.24 at Superior Hobbies with real good traction. This was the first time on the DUO 2 motor but it was also the first time with this chassis/car and all the electronics were set up much differently as compared to my cyclone. I have since re-installed everything to new positions and moved the receiver quite a bit further away from the motor. I'm hoping this will help but won't know until the next race.
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 10-13-2009, 12:18 PM   #758
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
That is correct.
Kevin Van Ert | MFR | CRC Racing | Team Scream Racing | Hobbywing | Xenon USA | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 10-13-2009, 01:27 PM   #759
Trader Rating: 18 (100%+)
Anyone know what causes the esc to stutter/ cut out 3/4 of the way down the straight? It didn't happen every lap but more often then not. I've heard I might need to replace the sensor wire. Anyone had this problem and found a solution?
TC Asphalt
13.5 Duo 10 deg timing. motor temp 150 deg
Level 7
SMC 5200mah 2s 40c
120 ft straight
FDR 6.6
*I also tried and FDR of 6.49 and 6.21
I had the same problem and after a lot of trouble shooting I threw away my spectum module and reciever and installed a Futaba FASST system. This solved my problem. I did everything else before resorting to this, Stutter stopper cap, reciever pack, motor change, battery change, and a reciever change. It was only when I tried a new SPX and still had the problem that I realized I had a radio problem.
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 10-13-2009, 02:59 PM   #760
I have no idea. But like Art we tried EVERYTHING you could think of to get it to stop. He swapped to crystals and bam it worked. I run FASST, never had any issues.
Old 10-13-2009, 03:44 PM   #761
RAL
RAL's Avatar
thanks guys... Let me look into it.
Old 10-14-2009, 01:47 PM   #762
Stephtruc's Avatar
Hi guys,
witch ratio can i use with 13.5 speedpassion V3 / 7.4v lipo on hight grip indoor carpet ?
usual spx set up: 1 8 1 1
Thx...
Stephtruc is offline   Reply With Quote
Old 10-14-2009, 06:52 PM   #763
sonic31's Avatar
hello everyone, need some help on gearing for my 416we, i just bought an spx speedo and i know they say gearing is different from what i used on my tc spec but a ballpark figure would be helpful... im using a 92 tooth 64p spur.
thanks for any info
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 10-14-2009, 07:24 PM   #764
Trader Rating: 5 (86%+)
Default 10r5 help
does anyone have an idea of a good rollout for the 10r5 with the one cell lipo setup...i will be running an spx with an orion 13.5 motor...can someone help me out...track is 75x35 carpet
obi wun is offline   Reply With Quote
Old 10-14-2009, 08:16 PM   #765
DaSkills's Avatar
Hey Sonic, I run the SPX in my 416. I have been trying different ratios, I'm running a 17.5 motor. I have run 4.3 to a 5.12 using a 100 spur using profile 7 or 8. So it also depends on what motor you are going to run and how much timing you are going to run. The 100 spur is a good start to see which way to go with your profile and ratio. Another guy at my track likes to run a 104 spur on his 416, he said that it give it more mechanical torq. I haven't tried it yet but his car is fast. I did try a 98 spur my last race and like it running a 4.5 with the timing turned up 10,000 on the motor running profile 8. The motor came off about 150-155*, but the weather was cooler than normal so I think that might had something to do with it. I will be trying a 95 spur my next run with the timing set at 0* on the motor to start with. Just find a safe ratio to start with then figure out which way to go.
TRF416 - Tamiya 801X - Xray XII - 4PK - Fantom Racing - Reedy - SMC - Jaco -LRP - Sorex -Tekin -Orion - Thunder Power
AKA: "No Limitz"
DaSkills is offline   Reply With Quote
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
10.5 Setups matrix101 Australian Racing 14 06-05-2009 03:27 AM
LRP SPX and TC-SPEC Tral Radio and Electronics 15 04-21-2009 06:07 PM
LRP SPX Brushless Competition StockSpec ESC mazmo Australian Racing 10 02-16-2009 12:44 PM
LRP SPX Bullet Revise Burshless/Brush ESC chappi Australia For Sale/Trade 15 12-31-2008 08:29 AM
