Old 10-01-2009, 03:32 PM   #721
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by Owen RaCing View Post
Ill just blame it on the California kid that re wired it
Sawyer? Or Dylan?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 10-01-2009, 03:36 PM   #722
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Originally Posted by BlackedOutREVO View Post
Sawyer? Or Dylan?
Well, Sawyer did touch it.. That's enough to blow anything up
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 10-01-2009, 03:48 PM   #723
JayL's Avatar
motor timing
or
weak batteries
reset the motor timing to zero or whatever it's lowest setting is
then SLOWLY advance it trying to see if the car "spx's" after each setting change
hate to ask but: you are on profile 8 right? or at least 7?
JayL is offline   Reply With Quote
Old 10-01-2009, 04:12 PM   #724
Originally Posted by JayL View Post
motor timing
or
weak batteries
Nah, we hooked my esc up to his motor with his radio and batts and it SPX'd. Tried profile 7 and 8.
Old 10-01-2009, 04:18 PM   #725
motor timing
or
weak batteries
Thanks for trying Jay, but me and Brandon both think the thing just stopped working. Cause it worked fine for awhile, but then it just stopped. So im just gonna go to Tekin.
Old 10-01-2009, 11:32 PM   #726
good luck with th Tekin Thing
hope your good with computers and programming
sidecarphil1 is offline   Reply With Quote
Old 10-02-2009, 10:07 AM   #727
I tried to gear my SPX with an 9.5t stock spec motor.
I used profile 8.
I tried FDR 5,6,7.
At 8 the advanced timing kicked in.
Isn't 8FDR high gear ratio for an lrp 9.5?
The manuakl of the motor says 5.3 for long track, 7 for short track.
-- TA05R Fully Hopped -- SPX Stock Spec -- 9.5T Stock Spec -- Sav÷x Servo -- Spektrum DX3S -- Corally 5000 Li-Po
Alienbliep is offline   Reply With Quote
Old 10-02-2009, 10:10 AM   #728
M-Technic's Avatar
Trader Rating: 15 (100%+)
I used profile 8.
I tried FDR 5,6,7.
That's not really that high of a final for an SPX/9.5t combo. I know some guys running FDR's in the 6's with a 13.5 and in the 7's with a 10.5.
I can guarantee that the advice given in the manual for your motor is given for conventional speed controls that do not have the advanced timing features of the SPX.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 10-02-2009, 10:14 AM   #729
Ok, i see.
explains alot.
I don't really have any idea where to start.
I'm looking for somebody who run's the same parts....
Old 10-02-2009, 10:16 AM   #730
M-Technic's Avatar
Even with the same parts, there are a lot of variables such as what batteries you run and what the weather is like in your region that would make it hard for someone else to help you.
Now that you are seeing the timing advance kick with the new final drive, you should start gearing for motor temperature. i.e. you want your motor to be around 150-160* F after a 6 minute run on the track.
Old 10-02-2009, 10:25 AM   #731
JayL's Avatar
No problem for him, we have team drivers at our track with laptops
Old 10-02-2009, 10:26 AM   #732
I found somebody at youtube with exactly the same set-up
That's really alot alot fast than my car.
Very strange.....
I have seen somebody with an stock spec 9.5 before and it also so much much more powerfuler and faster
.youtube.com/watch?v=ytMQ1joBsF8
Old 10-02-2009, 12:46 PM   #733
To bad I don't live anywhere near speedworld. Haha. I just race there everyonce in awhile.
Old 10-10-2009, 01:49 PM   #734
haywood's Avatar
Trader Rating: 49 (100%+)
Default LRP SPX
Will run the SPX for the first time on Sunday.I run 13.5 foam sedan on a large ozite track.I am in profile 8 with a fdr of 5.5.Is this gearing close or should I be like 6.0?
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 10-11-2009, 08:09 AM   #735
kuanseng1981's Avatar
Hi guys i'm from singapore and need some advice from u. May i know the diff if i use a LRP TC Spec, Spx Comp Spec and SXX which will be better for a 11.5T and is the SPX profile 8 the same as the SXX profile 10? and also is the SPX bullet profile 4 the same as the SPX profile 8?
Thanks in advance.
Friends come and go,
who's your friend nobody knows,
till the time than it will show,
who is friend who is foe.
kuanseng1981 is offline   Reply With Quote
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
10.5 Setups matrix101 Australian Racing 14 06-05-2009 03:27 AM
LRP SPX and TC-SPEC Tral Radio and Electronics 15 04-21-2009 06:07 PM
LRP SPX Brushless Competition StockSpec ESC mazmo Australian Racing 10 02-16-2009 12:44 PM
LRP SPX Bullet Revise Burshless/Brush ESC chappi Australia For Sale/Trade 15 12-31-2008 08:29 AM
