lrp spx stock spec
#661
Hey guys,
Has anyone got any experience gearing a Tekin 10.5 with an SPX.
Ive been playing around with gearing/timing and struggling to find a sweet spot with it.
Im currently on a 6.7FDR on profile 8 and Ive added a little timing on the motor which gave me more speed, came off at around 179.6 degree F.
Im running on asphalt/rubber M/grip, medium to long track.
Any help with gearing/timing/profiles with this motor would be appreciated.
#662
Hey guys,
#664
Gearing
Hey guys,
Very confused in the end.
Ben
#665
I tried 6.2 +5.95 with a Duo 10.5 on 7+8 and it didn't get hot at all.
The lower ratio made the motor sound like it was hitting the sweet spot.
With a Duo 17.5 on #8 , 4.33 works for me. I wouldn't go below 4.
I run zero on the motor.
Regards,
Fleety.
Regards,
Fleety.
#666
Hi yes i have been alot lower in my gearing but it didnt go well at all and run other motors lower gearing to but always seem to be back at this gearing of 5.30 been as low as 7.22 fdr but timing came in to fast didnt like it i run a lrp heat sink as well.Most of the guys run here about 5.1fdr.
#667
Everyone here with a spx and a 10.5 is running around 6.5fdr with profile 7. I run a Fantom Ion2 17.5 with middle hole timing and 4.2fdr(30 tooth) profile 7 and its awesome. I really need a heat sink for my motor and i would get away with another tooth or 2 with temps around 60c all day. If your struggling with gearing, try something crazy. Crank the timing up and drop heaps of teeth and see how it goes. It cant hurt if your sensible IMO. I have run this duo combo with every pinion i have between 25t and 34t and although some gears are faster straight line having heaps of grunt down low and running out of steam at the 3/4 mark of the straight isnt a bad thing especially when the Spx can out brake just about anything.
#668
I tried middle hole ,but didn't gain speed,just heat. But I use #8 profile !
#674
With Tekin 10.5, i run 6.1 - 6.3, program 7, and 8º timming, for long tracks (50m straight (160 - 170 ft), rubber tyres, temps around 75ºC (167ºF), without heatsink.
Setup of the car, is very important.
Greetings, Luis C.
Greetings, Luis C.
#675
That's what I wanted to know. I left my 17.5 in the first hole and experimented with profiles and gearing and didn't see any improvement. It's a new car and I'm still working on the handling. My local track closed and there's no where to practice.
Oh, I really like the lipo weights.
