lrp spx stock spec
Old 08-09-2009, 08:10 PM
  #586
Trader Rating: 19 (100%+)
Originally Posted by fleetmaster View Post
Ran my SPX with a Trinity Duo 17.5 on friday night and I'm VERY happy with it.
I'm new to stock,but managed to TQ first night with it in my XRAY T2R pro.
It had so much rip out of the turns,I was able to corner very aggressively .
Top speed was similar to the other cars. My roll-out is quite low and motor temp was ridiculously low too.
This week I can bump it up one tooth and see whether the punch drops.
I'm using #8 punch. Zero motor timing. No drag brake.
I also don't use manual brakes either.
Small indoor surfaced concrete on sorex rubber.
Heat sink on esc too.
What was your FDR? I'm assuming your running rubber tire.
zake540 is offline
Old 08-09-2009, 09:42 PM
  #587
fleetmaster's Avatar
Trader Rating: 16 (100%+)
4.43 fdr. I will be up to 4.28 by going up one tooth on the pinion.
Yes,sorex 36 rubber.
fleetmaster is offline
Old 08-10-2009, 05:39 AM
  #588
Brad,
It doesn't sound like you did anything wrong. I had the exact thing happen with my first SPX. After sending it in for repair/replacement, LRP concluded it was a FET failure. They were very nice about replacing it, but it did take a while as these things are in pretty high demand right now. Failures like this are the ugly reality of electronics as they always have a certain failure rate. Sometimes components are just lemons which causes the failure. Sorry about your luck, I know it sucks, but LRP should take care of you.
richard.bratton is offline
Old 08-10-2009, 05:45 AM
  #589
M-Technic's Avatar
Trader Rating: 15 (100%+)
My first SPX died on it's maiden voyage just like the two posters above. Looks 9 weeks to get a replacement from LRP, but the replacement has been doing great.
M-Technic is offline
Old 08-10-2009, 09:31 AM
  #590
JayL's Avatar
same track, same tires same duo 13.5, clean inside,
one car tamiya 415 w/smc 5200 40c
one car cyclone w/ orion 3800 30c
both running profile 8 6.0fdr middle hole on duo
tamiya 150 degrees
cyclone 200 degrees
running same lap times
any ideas why?
we took the cyclone to 5.7 and it went to 215...
JayL is offline
Old 08-11-2009, 08:08 AM
  #591
Default Mode 3+ 4
Hi , Could someone please explain Mode 3 - Innitial brake and Mode 4 Automatic brake on this ESC
I think Mode 4 is the amount of brake when you release throttle and the lever is at neutral - correct ? But Innitial brake ?
gimpex is offline
Old 08-11-2009, 08:10 AM
  #592
M-Technic's Avatar
Mode 4 is "drag brake," the amount of brakes automatically applied when you are in neutral. Mode 3, initial brake is how strong the brakes activate when you move to the braking position on your trigger.
Old 08-11-2009, 08:15 AM
  #593
tomracing's Avatar
tamiya 150 degrees
cyclone 200 degrees
any ideas why?
same driver?
exact same bodyshell?
same bearings/internal resistance ?
same front and rear toe settings?
same traction compound?
anyway going from 6.0 to 5.7 loaded the motor more so temp went up
try going higher in fdr
tomracing is offline
Old 08-11-2009, 08:35 AM
  #594
gimpex is offline
Old 08-12-2009, 07:20 AM
  #595
One more thing. When connecting the ESC to a brushed motor , how important is it to connect the right ESC wires to the + and - of motor. My motor has no indicators for + /- just a yellow and blue wire (no sheet with it).
I would think it can be connected either way and then reverse switched on transmitter if it spins backwards , but ..... ?
gimpex is offline
Old 08-12-2009, 04:48 PM
  #596
AE-Reedy
Yellow should be + and blue is -. It is important for the wires to be attached correctly.
Sean Cochran is offline
Old 08-23-2009, 08:06 AM
  #597
I want to replace my Sphere Competition 2007, what would be best for 7,5T and 8,5T 2wd buggy racing (Li-Po): SPX Stock Spec or SXX?
potloodslijper is offline
Old 08-23-2009, 10:34 AM
  #598
SXX would be perfect for those winds of motors you got.
SPX is basically for the spec racing series, 10.5 or higher.
nitro ho is offline
Old 08-23-2009, 11:09 AM
  #599
adamge's Avatar
pot, I'm in a similar position. I have a SPX and am wondering how much motor it can handle. Lately I've been running a 10.5t on it, and with the heatsink it is showing 110degF (indoor, touring car, rubber tires, carpet). The box says 3.5t and higher, and I am considering trying a faster motor.
adamge is offline
Old 08-23-2009, 12:22 PM
  #600
Tech Legend
Marcos.J's Avatar
Trader Rating: 194 (100%+)
4.0t
Marcos.J is offline
