Old 06-29-2009, 12:40 AM   #451
Timmie's Avatar
Originally Posted by mrrcguy View Post
I have ran it in both #7 and #8 geared from 5.0 - 5.8
Today I ran mainly around 5.5 on #8. The track is fast and flowing. The straight is 140 feet. Air temps were in the mid 90's with track temps at 140.
With a Novak the temps were only around 135. With a Hacker it was 160.
When you are on profile 7 or 8, do you actually see or hear the advanced timing come on while you are going down the straight away? Maybe your ESC is defective One of the tracks I race at is similar is size with a very fast layout with a couple of tight sections. The FDR you are running is close to what I use, and it is very visible and audible when the timing advance kicks in. If its not obvious to you, then I would go down on pinion size until you can see it kick in at the half way point of your straight away. My car has good low end torque and nice top end with the SPX. But when running high FDR I have noticed you don't want to let it stay on the advanced timing for too long, or you really start to heat the motor quick because of all the revs. Hope this helps
:: Serpent America ::Desoto Racing :: Track Star Racer Services ::Skyrocket Racing::TOP::
Timmie is offline   Reply With Quote
Old 06-29-2009, 10:02 AM   #452
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
I am going to run some more today. I will try some really crazy gearing just to see what I get.
mrrcguy is offline   Reply With Quote
Old 07-01-2009, 10:01 AM   #453
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally Posted by Jason Turner View Post
What ratio are you guys running with spx and a 10.5 on med sized track?
Also what motor brand seems to be working good with this speedo 13.5 and 10.5?
+1
Old 07-01-2009, 01:13 PM   #454
mutley001's Avatar
I'm running 10.5 indoors on carpet on a medium sized track (35m straight)
Been running an FDR of 5.95 with a Novak motor on profiel 8 and love it - its ballistic at reasonable temps but I am using an LRP heatsink/fan too.
Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 07-02-2009, 09:14 AM   #455
Benzaah's Avatar
Trader Rating: 21 (96%+)
Guys, Will i do damage to my motor if i gear it too high to begin with? Im thinking of starting at around 6.0 as we usually gear it around 5.1 for 10.5 at my track. Or should i be thinking higher like 6.5 maybe? I dont want to cook my new motor straight up. Cheers Benzaah
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 07-06-2009, 09:21 AM   #456
jammincrtjames's Avatar
Does anyone have a recommendation for profile 7 or 8 on a large track running a 13.5 DUO? The straightaway is probably around 70 feet.
NEXUS RACING www.nexusracing.com | FANTOM RACING www.fantomracing.com
ORCA www.orcarc.com | TURTLE TRAX / www.turtletraxraceway.com
"If you're not first...you're last!"
jammincrtjames is offline   Reply With Quote
Old 07-06-2009, 09:25 AM   #457
Suspended
Trader Rating: 28 (100%+)
rubber tire?
5.7 profile 7 is a good starting point.70ft is pretty short.
racenut123 is offline   Reply With Quote
Old 07-06-2009, 09:58 AM   #458
Rubber. My mistake...around 120 foot straight
Old 07-06-2009, 12:23 PM   #459
Suspended
Ah.go same FDR,but bump the profile to 8.Should work well.
Old 07-06-2009, 03:30 PM   #460
isnt that a bit too high ??
we have a 40m straight and i use 45 to 4.6
still messing with the gearing but i never went that high ??
an i too low ?? my motor temps are about 70 degrees C ??
sidecarphil1 is offline   Reply With Quote
Old 07-06-2009, 05:00 PM   #461
All I know is on a straight approx 120 feet, Im getting passed like I am standing still by a KO BMC. I was running 5.4 on profile 8 with a DUO on middle timing.
Old 07-06-2009, 09:31 PM   #462
Suspended
Main thing is try different gearing.Don't be afraid to try something that sounds a little too safe.Motor to motor of the same motor design,gearing is a little different for every one.I run on a track with a 135 back straight.My gearing is what I suggested.I also run with guys who ran the recent REEDY race.The guy who won made the suggestion to me for this particular gearing and I am not giving up anything to anyone there.You have to undergear before you can find out your overgeared.
Old 07-07-2009, 10:56 PM   #463
Default gearing
just bought new spx
i was tolled to drop 4 teeth on pinon,but i run 64 pitch so not sure???
And put on profile 8 and never change??
I run 10.5 novak most times,outdoors tracks,medium size,fdr 5.27
onroad with lrp tc spec.
Any advice would be great.
THANKS
ghost rider is offline   Reply With Quote
Old 07-07-2009, 11:10 PM   #464
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
I need a gearing base line to start for my Cyclone with a SPX, Novak 13.5 at SWR.
Any ideas?
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 07-08-2009, 01:56 AM   #465
Originally Posted by ghost rider View Post
just bought new spx
THANKS
i was told the same thing ,
mine is quicker but i think there is more to come
i want from around the 4.0 mark to 4.55 and it's quick but from what i read here i will try between 5 and 5.5 when i get home from holiday
also i would try program 7 and 8 with nothing else on
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
10.5 Setups matrix101 Australian Racing 14 06-05-2009 03:27 AM
LRP SPX and TC-SPEC Tral Radio and Electronics 15 04-21-2009 06:07 PM
LRP SPX Brushless Competition StockSpec ESC mazmo Australian Racing 10 02-16-2009 12:44 PM
LRP SPX Bullet Revise Burshless/Brush ESC chappi Australia For Sale/Trade 15 12-31-2008 08:29 AM
