Old 05-03-2009, 09:37 PM   #241
Anyone running an spx with single cell lipo 17.5 12th? Findings?
JoelV is offline   Reply With Quote
Old 05-03-2009, 09:38 PM   #242
Trader Rating: 18 (100%+)
Did you guys notice a difference in infield punch when geared 4.8 vs. when geared 5.4? My last run at NorCal I was geared 5.6 with profile 8.
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 05-03-2009, 11:16 PM   #243
Suspended
Trader Rating: 17 (90%+)
Originally Posted by Advil View Post
Did you guys notice a difference in donkey punches when geared 4.8 vs. when geared 5.4? My last run at NorCal I was geared 5.6 with profile 8.
You do some weird testing, bro...
Seriously though, I think gearing substantially lower than 5.6 is the way to go on that track.
StickyFingaz is offline   Reply With Quote
Old 05-03-2009, 11:22 PM   #244
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
Originally Posted by AARON YOUNG View Post
Hi arluck i miss your man boobs!
Hey fat guy, i'll see you at reedy and we can compare cup sizes.
JamesArluck is offline   Reply With Quote
Old 05-03-2009, 11:25 PM   #245
Trader Rating: 28 (100%+)
What he failed to mention is the 10degrees of timing he added on the motor.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-03-2009, 11:25 PM   #246
Jason Turner's Avatar
Trader Rating: 64 (100%+)
Can anyone recomend gearing for my TC5 with a 13.5 with an SPX on power mode 8?
Thanks in advance
Jason Turner is offline   Reply With Quote
Old 05-03-2009, 11:34 PM   #247
STLNLST's Avatar
Trader Rating: 21 (100%+)
Thanks in advance
Depends on what motor you're running and how much timing you're using.
STLNLST is offline   Reply With Quote
Old 05-04-2009, 03:20 AM   #248
Sorry wasn't too specific on that. It's a novak 13.5 with a 13mm rotor never changed the timing on the motor itself.
Old 05-04-2009, 07:05 AM   #249
Some comparative dyno runs.
LRP SPX Stock Spec ESC
LRP X11 10.5t (ceramic bearings, extra cooling front plate)
SMC 5000mAh 28c
The current curves are very interesting (keep in mind the current reading on the Sentry is clamping above ~110A). You can clearly see the punch levels, the profile 1,2,3,4 increase in punch and it looks like (1,2,3) & (4,5,6) & (7,8) have similar timing profiles. You can also see the new Stock Spec profiles 5,6,7,8 increasing in punch, with 5,6 having a similar timing profile as profile 4 and profile 7&8 having large amounts of timing past the power peak. Any wonder you need to be careful on 7&8 with the motor pulling 30A at almost no load.
You can hopefully see why gearing down is good thing on profile 7 & 8.
lrp spx stock spec-lrp_spx_x11_10.5t_all.jpg   lrp spx stock spec-lrp_spx_x11_10.5t_p5678.jpg   lrp spx stock spec-lrp_spx_x11_10.5t_allcurrent.jpg
gameover is offline   Reply With Quote
Old 05-04-2009, 08:21 AM   #250
SMC 5000mAh 28c
Gameover
Now that is some good testing! Thank you.
Jeremy Otis is offline   Reply With Quote
Old 05-04-2009, 08:48 AM   #251
jag88's Avatar
jag88 is offline   Reply With Quote
Old 05-04-2009, 01:16 PM   #252
RocketRacer's Avatar
can someone please explain the graphs a little more??
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 05-04-2009, 02:40 PM   #253
SMC 5000mAh 28c
The cat's out of the bag!! Bearing in mind that power = torque x revs, you can now see why it is so important to gear down. 7 and 8 give you much more revs, but there's no torque. To get more power, you have to gear down so the motor can access the increased revs, otherwise it will be slower, and consume large amounts of energy to generate heat.
Well done gameover - the game's over now!!
SlowerOne is offline   Reply With Quote
Old 05-04-2009, 03:39 PM   #254
so from what i make out from that graph is profile 6 would be a much safer
profile...i havnt run my spx yet on track but is there much in it between say profile 6-8
or is profile 8 the one to be on but just gear down 3 teeth?
mark
mark williams is offline   Reply With Quote
Old 05-04-2009, 03:51 PM   #255
linger's Avatar
Originally Posted by SlowerOne View Post
... 7 and 8 give you much more revs, but there's no torque. To get more power, you have to gear down so the motor can access the increased revs....
"no torque" - I don't think so. From about 0 - 12K RPM, profile 2-8 all have the same power. Therefore for any given RPM, they all output the same torque. Profiles 7, and 8 further extend this by giving MORE torque at any RPM higher than approx 12K.
I think the reason for gearing down is to not overheat the motor.
Well done GameOver. I salute you.
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
10.5 Setups matrix101 Australian Racing 14 06-05-2009 03:27 AM
LRP SPX and TC-SPEC Tral Radio and Electronics 15 04-21-2009 06:07 PM
LRP SPX Brushless Competition StockSpec ESC mazmo Australian Racing 10 02-16-2009 12:44 PM
LRP SPX Bullet Revise Burshless/Brush ESC chappi Australia For Sale/Trade 15 12-31-2008 08:29 AM
