lrp spx stock spec
#211
ok easy question..
with lrp X11 10.5t on my sphere tc spec on a large track (cotswolds) my timing was on full and my FDR was 4.65 and punch setting 6
i now have my SPX comp what FDR should i use for the same large track? as from what ive read the timing will stay on 0 (30 degs)
what is a safe max temp for SPX?
vector X11 10.5t?
thanks in advance
mark
vector X11 10.5t?
thanks in advance
mark
Keep the timing on 0 for the motor and go down at least a couple of pinions.
There is no actual mention of the temperature the ESC can take, but it's temp memory function tells you how close to shutdown it is. Mine usually ends up with 15 flashes of the blue LED.
Skiddins
#212
Here is how i determined a good gearing ..I dropped 3 teeht from the start on my 13.5.THe car jumped off the corners and seemed dead till the last ten feet of the straight so i dropped one more tooth.The changed moved where the car advanced the timing back about 5 feet each time i dropped a tooth.I settled at 5.7 gearing on a long straight and the motor was coming off at 160 degrees.Has anyone noticed that it seems to kill rotors faster even without abusing them with heat.I also had one spx start to stutter like cogging under load but doesnt affect steering like a glitch.
#213
I've been running my 13.5 duo motor at a 5 flat final with the punch at 8 and break at 3 and drag at 3 and running for about 8 minutes. The motor temp is about 150 when I come off...still have not had a problem and we run on a small track.
#214
Have gone from from 4.8 to 5.2 to 5.4 gearing over the past ten days. Today, at my 5.2 and 5.4 gearing, speedy John Hicks went the same speed on the NorCal back straight using about 1-3 pinion teeth more with his SPX???
My "had" Duo motor now seems to be slower during the second half of a 6 minute run. Even though the motor temp for the run still stays below 165 degrees.
Have not run on a warm day yet this season.
Bill
#215
Have ceased using Launch Control and drag brake is now set at 3 or 4. More experimenting with John Hicks tomorrow.
Bill
#216
launch
I have no idea about the launch part, never tried it.... I rarely try to hole shot anyone because it usually just causes a accident or you need to just get back on break..
But I have power drop off with any speedo or motor I use..
#217
gearing down
Hi all,
I just want to share my testing results with SPX and 13.5 (LRP and Orion on default timing). We have e a very large track in Heemstede (Netherlands). Reto, you must know this track.
I don't agree on dropping pinions when using setting 8 on SPX. I went from FDR 4.5 down to 3.6 and was going faster with better lap times, motor temp never went above 61C deg.
If anyone is interested my test session can be found here on Mylaps http://www.mylaps.com/practice/showL...67&subm=Search
Session 1 was FDR 4.5, gearing up every session with last session (7) at 3.6.
Next week I'm taking this to even lower FDR (3.5 to 2.9). The only thing I'm monitoring is motor temp.
Z
Z
#218
Hello All,
Im running also a LRP spx Stock spec version since a week. But im searching for the right gearing for my engine. Using Profile 8 of the spx. But now the problem i dont really know what timing i should use.
FDR 4.0 or maybe more to 6.5, Any one has an idea what kind of FDR would be good for my setup?
Xray t2 009
LRP SPX Stock spec
Corally 25c 5000 mah lipo
Speed passion 10.5T brushless
Thanks already
Xray t2 009
LRP SPX Stock spec
Thanks already
Gearing only really has to change down for profile 7 & 8 on the SPX.
Skiddins
Skiddins
Hi all,
Z
Z
HTH
#219
I don't run TC, so can't give you an exact ratio. However, the rule of thumb is to go waaaaaay down on ratio and then come back up. Check the clock every time you change gearing, and see how fast teh whole race is, and how consistent your lap times are. Go for the fastest, most consistent lap times first, and temp second.
Good advice when using 7 and 8 - follow it!
Take all the drag brake off! Drag brake is achieved by firing the coils, so it uses battery and that means it increases heat. You'll not be able to take full advantage of settings 7 and 8 if you have drag brake on.
Heemstede is huge, and it doesn't have too many slow corners. I find this situation unusual, and I would not advise that you follow these settings.
HTH
HTH
SlowerOne
I have watched you race your 1/12 scale car before. Are you sure you are qualified to be giving advice to everyone...
#220
Those who aren't very good at something (playing football, soccer, athletics or racing cars, as above) spend a long time trying to find out why. That's what makes them so good at understanding their sport, designing their cars and coaching their teams and athletes.
In my case, it isn't my driving that people admire, it's the fact that I crash at a higher speed than anyone else they know!!
#222
Ditto with the SPX on 8! When using the Duo 13.5, my temps have never exceeded 165 degrees. Current problem is that replacement rotors for the Duo are not available from Trinity.
Bill
Bill
How do the profiles on the SPX line up with the profiles on the TC Spec? I think I'm done with this timing nonsense until it's figured out, I'm tired of all my motors going soft.
#223
At John Tag's suggestion (Express Motorsports) , I changed my SPX's punch setting to #7 today and geared at 5.0. I ended up with 4.8 gearing by the end of the testing and the motor didn't seem to be going soft during a 6 minute run.
I probably need to try a new motor to see if the setting #7 is going to save me from having it go soft.
Setting #8 certainly was fun though.
Syndrome: At least you don't have a non-TC racer telling you not to use any drag brake...
Bill
Bill
#224
Team EAM
Bill
Bill
Also as for "it going soft" you might need to call a Doctor about that!!!
EA
#225
I didn't pay much attention when you said that you had not run a 13.5 on rubber yet. Good reckoning though...
