Old 04-30-2009, 05:36 PM   #196
over gear's Avatar
Trader Rating: 15 (100%+)
OK, I'm officially confused. at a simple touch of a button, the magical profile #8 up the gearing from 3.6 to 5.0 ??
sometimes, i don't think i belong to pro stock class.
over gear is offline   Reply With Quote
Old 04-30-2009, 06:19 PM   #197
Skiddins's Avatar
Originally Posted by SlowerOne View Post
Read the posts on here carefully - people are telling you what you are doing wrong! And you have absolutely no chance of me telling you this, for the reasons I gave before.
See Skiddins, people are telling you what you're doing wrong...
...and here's an example of a user who's heading fo a fall because they are not heeding the advice!
Come on guys, read carefully what Reto, EA and others are telling you. These guys know what they are talking about because they are doing their homework. Look carefully at posts and the answers are there.
In profiles 7 and 8 you HAVE to gear down a lot, and then you have to judge the performance on the track every bit as much as on the thermometer. Profiles 7 and 8 are doing things that you could never do with a BR, so much of what we have experienced before isn't valid.
I think this thread has taught me a lot more than I knew before, so roll on more questions, and more help from the likes of Reto and EA and Steve Weiss. Thanks guys, we owe you (if we're listening!! )
The cars were geared down, and the motors being used had fixed timing
Hmm, don't advance the timing...check
Gear down....check.
You've said ignore temps unless it's a very hot day etc...check
So the only thing that has beeen mentioned by the others was the use of advance timing in the motors when the ESC was on the higher profiles. However, as the motors used had fixed timing this shouldn't have been an issue.
So what's left, forgetting to use voodoo before turning the car on.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-30-2009, 06:29 PM   #198
Skiddins's Avatar
Originally Posted by EAMotorsports View Post
Yes and you can see the differences in the timing when dyno'ing BL motors. Some of the sensor boards are moved to the advance side and its pretty obvious on the dyno!
The Novak motors are the easiest to tell which one has the sensor board advanced. You can look at the timing ring from the factory. The more "retarded" the timing ring is the more timing it has in the sensor board. They set all their motors from the factory to a pre-set RPM i believe.
EA
Is there a visual check that can be perofmed to see if the timing has a lot of advance?
How close to the edge of the 'coils' (with regards to their circular position on the sensor board) should the sensors be to be at 0 timing?
Is 0 degree's timing when the sensors are in the dead centre of each coil?
Example, what timing do you think this might be;
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 05-01-2009, 03:43 AM   #199
burito's Avatar
Your understanding is correct, if the sensor sits exactly center of the stack (e.g. centerline with the winding coil) that is the zero timing position. But with any wye wound motor, it would run like a dog at that position...
The timing on the motor in your picture is ~30, which is what many (racers & manufactuers) consider as zero...
If the sensors outer edge lines up with the edge/end of the stack, that is roughly 40 of timing.
Looking into the motor from the front like you do, is indeed the best and only way to check for true timing!
Just to make the confusion complete, on delta wound motors (which are hardly ever seen tough) the timing is an entirely different thing, there you should have the sensors at real zero mechanical timing (e.g. center of stack) or advance it by a maximum of 10.
Reto Koenig
burito is offline   Reply With Quote
Old 05-01-2009, 05:30 AM   #200
Skiddins's Avatar
Thanks once again Burito, great information
If we run the SPX on setting 7 or 8, we know to gear down a lot, but should the timing be retarded or should it still be safe when used on 30deg timing in the motor?
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 05-01-2009, 06:29 AM   #201
Tpg racer's Avatar
Skiddins
One of the best question for SPX users....
Tpg racer is offline   Reply With Quote
Old 05-01-2009, 07:35 AM   #202
burito's Avatar
Having the sensor at 30 should be safe.
Reto Koenig
Old 05-01-2009, 11:24 AM   #203
Skiddins's Avatar
If the motors and speed controllers are not getting very hot (50 degC for example), is there anything else we should keep an eye on?
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 05-01-2009, 01:37 PM   #204
Skiddins
First class questions, Skiddins (he said, patronisingly!) that's how we do homework! As you can see, it's just the same as the questions we asked of BR, and the answers give the details you need.
As to your question, the main thing to keep an eye on is the pick-up off the turns. As you get to 7 and 8, my experience is that when the gearing is too high, the car is a slug out of the turns. Get the gearing down to where the car picks up like it does on 5 and 6 (like it did before LRP came out with this 'Stock Spec' profile) and then let the LRP magic do its stuff to get the speed up.
I find that when the pick up is sluggish, you're simply converting battery energy into heat, and hence the problems you have seen. When you get it right, the rip down a reasonable straight is quite impressive!!
Remember that this is all a balance, and what works on one track won't work on another. I've had equal success with a high ratio on profile 6 as I have with a low ratio on profile 7 on different tracks.
At West London, it's debatable whether the rip down the straight is adequate compensation for the lack of speed between corners on a low ratio. Try both, and let the clock be your guide, whatever your head says is fast! HTH
HTH
SlowerOne is offline   Reply With Quote
Old 05-02-2009, 10:38 AM   #205
Hello All,
Im running also a LRP spx Stock spec version since a week. But im searching for the right gearing for my engine. Using Profile 8 of the spx. But now the problem i dont really know what timing i should use.
FDR 4.0 or maybe more to 6.5, Any one has an idea what kind of FDR would be good for my setup?
Xray t2 009
LRP SPX Stock spec
Corally 25c 5000 mah lipo
Speed passion 10.5T brushless
Thanks already
GerwinGood is offline   Reply With Quote
Old 05-02-2009, 03:59 PM   #206
TheCoolCanFanMan's Avatar
Originally Posted by GerwinGood View Post
Hello All,
Xray t2 009
LRP SPX Stock spec
Thanks already
Ask the Slowone, he seems to have all the answers,
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 05-02-2009, 04:14 PM   #207
Here is how i determined a good gearing ..I dropped 3 teeht from the start on my 13.5.THe car jumped off the corners and seemed dead till the last ten feet of the straight so i dropped one more tooth.The changed moved where the car advanced the timing back about 5 feet each time i dropped a tooth.I settled at 5.7 gearing on a long straight and the motor was coming off at 160 degrees.Has anyone noticed that it seems to kill rotors faster even without abusing them with heat.I also had one spx start to stutter like cogging under load but doesnt affect steering like a glitch.
AARON YOUNG is offline   Reply With Quote
Old 05-02-2009, 04:51 PM   #208
Be very careful when you feel/hear the motor cogging, as this is what I felt just as I put my car down and drove it round to the start line, then the car would go no further, took the car back to the pits and not only had the motor blown, but the Nosram esc had gone pop
Cheers TCCFM
Old 05-02-2009, 05:02 PM   #209
LoonyRacing's Avatar
Cool
Teamloonyracing.com
LoonyRacing is offline   Reply With Quote
Old 05-02-2009, 06:10 PM   #210
ok easy question..
with lrp X11 10.5t on my sphere tc spec on a large track (cotswolds) my timing was on full and my FDR was 4.65 and punch setting 6
i now have my SPX comp what FDR should i use for the same large track? as from what ive read the timing will stay on 0 (30 degs)
what is a safe max temp for SPX?
vector X11 10.5t?
thanks in advance
mark
mark williams is offline   Reply With Quote
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
10.5 Setups matrix101 Australian Racing 14 06-05-2009 03:27 AM
LRP SPX and TC-SPEC Tral Radio and Electronics 15 04-21-2009 06:07 PM
LRP SPX Brushless Competition StockSpec ESC mazmo Australian Racing 10 02-16-2009 12:44 PM
LRP SPX Bullet Revise Burshless/Brush ESC chappi Australia For Sale/Trade 15 12-31-2008 08:29 AM
