Old 01-30-2009, 12:35 AM   #1
Default sidewinder esc "stutters"
my son just got a new sidewinder esc.
trying to set it up for him. i went thru the steps in the supplied booklet.
i believe it to be set up for forward, reverse and neutral.
problem is, when i try to either go forward or backward, the motor "pulses" or "stutters"
any thoughts? ive tried multiple motors so i know its not a motor problem.
thank you
c
macscac is offline   Reply With Quote
Old 01-30-2009, 02:47 AM   #2
thank you
c
if any of the motors are high turn wye motors 10.5 up it will do this, really no way around it with that speedy.
if it is castle motors, turn down the timing and gear lower
e-team hobby: www.eteamhobbyplex.com
Fort Collins Colorado
Gorilla Boy Racing
mxzhonkey is offline   Reply With Quote
Old 01-30-2009, 04:11 AM   #3
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
if ur tryin a sensored motor. unless its a low turn 'mod' motor. it will cog.
edit: previous poster got it.
R
UltegraSTI is offline   Reply With Quote
Old 01-30-2009, 11:09 AM   #4
sorry. confused...
i put a 17t double in it and it did the same.
are you saying that i need a lower turned motor in there?
this is a drifter car. i was under the impression this esc would run any motor. brushed or not.
Old 01-30-2009, 11:50 AM   #5
Dark_gouki's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to Dark_gouki Send a message via Yahoo to Dark_gouki Send a message via Skype™ to Dark_gouki
hook the sidewinder esc up to the cpu and turn the motor timing down also it could be your batteries
My Nitro Assassins
S2D= Novak 8.5T
M18= Tekin 9200kv
All My Whips Are SBD (Silent But Deadly)
Dark_gouki is offline   Reply With Quote
Old 01-30-2009, 12:39 PM   #6
he is using venom 3300 nihm stickpacks
Old 01-30-2009, 02:03 PM   #7
ok. just got off the phone with castle.
apparently the esc comes set up for brushless.
and needs to be setup for brushed or it will do what it is currently doing.
now i dont have a link to set it up via the computer.
need to do it manually.
lol not sure how to do that
Old 01-30-2009, 02:27 PM   #8
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
not really sure if you can do it manually, but if you could it would be in the manual im sure. If not, im pretty sure you would be stuck buying this http://www.castlecreations.com/produ...stle_link.html
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
Old 01-30-2009, 03:15 PM   #9
hmm sounds like it may be 24 dollars well spent.
ill see if LHS has one in stock
Old 01-30-2009, 03:26 PM   #10
Old 01-30-2009, 04:11 PM   #11
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Last time I saw someone hook up a brushed motor to a Sidewinder in brushless mode, he ended up sending the Sidewinder back to have all the smoke put back in. Consider yourself lucky. The Castle Link is the way to go for sure.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 01-30-2009, 04:56 PM   #12
I had the same problem w/ my sidewinder and a Team Orion 27 turn core stock motor. The esc DOES come preset to brushless. The castle link is a great purchase and it takes like 2 seconds to switch to brushed mode plus you can make all types of adjustments w/ it. GET IT
rogueldr is offline   Reply With Quote
Old 01-30-2009, 06:33 PM   #13
Trips's Avatar
Trader Rating: 16 (100%+)
macsac,
I have a castle link here that I don't use any more. It'sd yours if you want. Just PM your address and it'll be on its way.
You'll need to download the software and manual from castle, and you'll be good to go.
Let me know...
MARSHAL!!
Trips is offline   Reply With Quote
Old 01-30-2009, 07:33 PM   #14
geeunit1014's Avatar
Just for the record...
You CAN switch it over to brushed mode without the castle link.. its just a pita. If you dont mind getting one, or since trips is offering one, id get it.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 01-30-2009, 10:47 PM   #15
Originally Posted by Trips View Post
macsac,
Let me know...
pm sent trips
thank you for the kind offer
