Old 01-25-2009, 01:52 PM   #1
Default Low Grip Setup
I race on an extremely low grip surface.What setup adjustments can I make to improve traction? I drive a Schumacher MI3. I have already lowered my diffs and this has helped a bit, but my car is still has virtually no grip!
Thanks in advance,
nm6978
nm6978 is offline   Reply With Quote
Old 01-25-2009, 01:59 PM   #2
LOSI123's Avatar
Trader Rating: 63 (100%+)
different shock oil/ pistons, different tyres, Higher or lower ride height, run a front spool/Locker., change springs.
Please tell us more about what surface you are running on, bumpy asphelt etc....
And what tyres you are running at the moment
and what setup specs you have now
and what motor
LOSI123 is offline   Reply With Quote
Old 01-25-2009, 02:17 PM   #3
1.The surface is very smooth asphalt indoor,very cold,dusty track
2.I am currently running CS27s but sometimes use CS22s....club rules only allow slicks.
3.front Toe-out:2*
springs:Schumacher white springs front and back
camber(negative):1.5* front and back
diff height:low front and back
shock oil:40w front and back
4. GM 13.5 motor
Any help appreciated
Old 01-25-2009, 02:37 PM   #4
revo523's Avatar
3.front Toe-out:2*
4. GM 13.5 motor
What about ride height, front and rear droop?
Xray T2 009 EU Tekin RS PRO Novak 13.5 SMC 5200
Team Magic G4JS O.S.12 skyline 12plus
Spektrum DX3S
What came first the chicken or the egg?
revo523 is offline   Reply With Quote
Old 01-25-2009, 02:42 PM   #5
RC MARKET's Avatar
Hara last time in HK ,
had used Orion JB foam insert
shock oil lighter or change shock spring .
1ST find which insert have more grip
2nd is shock rolling timing
RC MARKET is offline   Reply With Quote
Old 01-25-2009, 02:50 PM   #6
3.front Toe-out:2*
ride height:5mm front and back
droop:1mm front and back
4. GM 13.5 motor
Old 01-25-2009, 03:01 PM   #7
LOSI123's Avatar
1st try more droop all round (lettting the arms drop down more) and run a front spool.
try stiffer front springs, try cleaning the track, try lowering the rear upper inner camber link, try cs 27 on front & cs 22 on rear, make front toe 0Degrees, lengthen the wheel base of the car
Do most of these one at a time trying the car out in between
Old 01-25-2009, 03:20 PM   #8
RC MARKET's Avatar
3.front Toe-out:2*
4. GM 13.5 motor
Yes choice F spool !
F toe out 0-1
Spring choice HPI F Gold , R Silver .
Oil Asso F 35-40 , R 30-35
Flow F 2mm , R 2.5mm
if not have control insert , can choice JB Foam insert
& use Trinity Tire tweak 2000 & after use Buggy grip in dirty track ,
in clear track use FX 2 !
Old 01-25-2009, 03:31 PM   #9
sosidge's Avatar
Around here we still have a couple of clubs that race on "slippy floor" as we call it in the UK - polished tile/wooden floors in gyms or school halls. Grip is very low - so low that we have to run spiked tyres! Looks very strange to anyone not used to racing in the UK.
We also do our fair share of racing on cold tarmac.
Anyway, what I have found from running on low-grip surfaces is...
- Tyres are crucial - get them right and everything else starts to come together. If the surface is cold, go for a soft compound. If the surface is very dirty, you may even need treads. Additive or even tyre warmers will help to generate a bit more grip at the start of the race, before the tyres get up to their normal working temperature.
- Avoid the temptation to go too soft on the suspension - although in theory it generates more grip, in practice it usually lets the car move around too much, so you get a poor tyre contact patch and poor handling response. A typical medium-grip asphalt setup should be soft enough.
- Run plenty of droop. More wheel travel creates grip for free.
Old 01-25-2009, 03:31 PM   #10
Victor Vector's Avatar
First vacuum the track, then spray with Grape Juice. Let the soda dry and then start on your set up. Dusty black top will have you chasing your tail for ever !!
Where are you by the way ??
Jacko
Jack Balchin.
Timezone Hooligan
IBEW Local 48-retired (Definitely, great pension.)
Victor Vector is offline   Reply With Quote
Old 01-25-2009, 03:39 PM   #11
i race in a place called fermoy in ireland.
thanks to everyone for their help,
nm6978
Old 01-25-2009, 03:43 PM   #12
nm6978
Ireland eh, then try IronBrew !!
Jack Balchin.
Timezone Hooligan
Hot Bodies Cyclone Frank McKinney Electric On-Road 19762 07-26-2017 11:42 PM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 09:06 AM
Team Magic G4RS & G4 Setup Wolf Hobbies Nitro On-Road 12 03-05-2008 05:31 AM
Roll Centres oversquared Electric On-Road 40 08-24-2007 02:39 PM
