Old 01-25-2009, 12:52 AM   #1
05forfun's Avatar
Trader Rating: 81 (100%+)
Default How you guys setup anti-dive/squat??
I recently run Cyclone on the track (carpet and rubber tire) and feel like the front end was so soft that the rear end lifted up during hard brake before turning in and caused the car spinning in the turns. I tried the hardest spring that included in the box but the front still felt quite soft, and I also had quite long droop on the back, which I thought might cure the instability but I failed. I have another TA05R which has relatively harder spring at the front and it runs great on the track. Before I use other harder springs, I would like to know how to setup anti-dive/squat for my Cyclone, which I think may help a bit. I have some suspension pivot plates in the box but don't know if that is the guy for setting up anti features.
05forfun is offline   Reply With Quote
Old 01-25-2009, 01:00 AM   #2
Best place to start would be to reduce the droop in the rear, then harder front springs. If the front arms are level, you should be fine -- don't know that I'd go with anti-dive.
meinie is offline   Reply With Quote
Old 01-25-2009, 01:00 PM   #3
05forfun's Avatar
the only car I know which can directly adjust anti features is Xray T2 008. Any body knows how to have anti-dive/squat in your Cyclone or other TCs?
Old 01-25-2009, 01:16 PM   #4
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
You would add shims underneath the hinge pin mounts...
I don't know about the cyclone or any other TC besides the losi type R though, because the type R has ball ends on the hing pin, therefore the pin can be angled effectively without any stress on the pin or the pin mount.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 01-25-2009, 06:05 PM   #5
rc pete's Avatar
The Cyclone inboard hingepins slide into pivots and then into the mounting blocks, so you can adjust anti-squat/dive and it won't bind like a pivotless system would.
To add anti-dive to the front of the car, shim the rear block higher than the front. To add anti-squat in the rear of the car, shim the front block higher than the rear.
But I wouldn't recommend either as the first resort to curing a handling problem, but instead as a minor adjustment to an already descently running car.
Check out some of the Cyclone setups on www.hotbodiesonline.com as a starting point, if your car is way out to lunch, and start tuning from there.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 01-25-2009, 11:02 PM   #6
05forfun's Avatar
That is what I thought to have anti feature, but the pivot plates look only fit front block (front end), the rear block is too wide to use the plates (or there is actually longer pivot plate for longer displacement?). I think alum spacers will do but worry the reliability issue
Old 01-25-2009, 11:20 PM   #7
Korey Harbke's Avatar
Everyone on the team just uses the aluminum round spacers. The suspension blocks are strong enough to withstand plenty of abuse. I use the spacers everywhere, not just the longer blocks.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-25-2009, 11:45 PM   #8
05forfun's Avatar
-Korey
Thanks Korey. I think I will start from 0.75 spacers to have some anti dive (maybe a little anti squat on the rear if I want to use soft spring). Although you recommend some other setups instead, I will try to experiment anti feature to see if it can improve handling instead of changing to harder spring at the front.
Old 01-27-2009, 03:02 AM   #9
Lonestar's Avatar
As mentionned above, if your car is way out of whack then antidive/squat will be like a bandaid on a wooden leg...
Dissassemble the car, check for anything broken or binding, axles, bearings, shock shafts, CVD's, tweak, plastic parts can sometimes be cracked and look fine but "open" themselves under stress and cause erratic behaviour and so on so forth. The stock cyclone setup is already 90% there, it should feel more than ok. This is the car with the largest sweetest spot I've ever tried, so if it feels truly "wrong" then it isn't a setup issue, most likely a maintenance one. But the cyclone is also a proper double-decked, lightweight racecar that doesn't like approximation.
Things to check before everything else:
- tires - they must be glued PERFECTLY. put 100% new tires on if needed to make sure. there is no point doing anything on the car if tires aren't at least in 99% ok shape. no cracked rims either.
- diff - especially if you run the older diff.
Good luck,
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
TRF414M, 404x, 414, 414X TRF-Powered Electric On-Road 3600 11-01-2017 07:19 AM
TC3 Forum Lowrider Electric On-Road 12196 10-13-2017 09:47 PM
SH Z CAR easyryder Nitro Off-Road 4909 07-28-2017 09:22 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 08:58 AM
XX-4 Forum knucklebusta Electric Off-Road 4036 06-10-2016 06:15 PM
1/8th scale Motonica smac Nitro On-Road 1830 01-16-2012 10:34 PM
Any Tips for Jammin Mike.CL Electric Off-Road 13 03-15-2007 06:44 AM
