Old 01-24-2009, 10:47 AM   #1
Send a message via AIM to TomElEctric!
Default IM screwed! NEED help stripped screw!
I was building my car and stripped a screw and no clue how to get it out!
Tc4 Stock / 1/12 pan car! /
Selling tc4 160!
Tom :D
TomElEctric! is offline   Reply With Quote
Old 01-24-2009, 10:54 AM   #2
Regional Moderator
CarbonJoe's Avatar
See my response to your other post in the 1/12 scale thread.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is online now   Reply With Quote
Old 01-24-2009, 11:58 AM   #3
SammyZ's Avatar
Trader Rating: 138 (100%+)
it sucks, it seems everytime i buy a used car its froma retard who lock tited the screw in place or used the incorrect wrench on it. It ends up stripping.
So i break out my dremel with cutoff wheel and cut a "flat blade slit" into the screw head. This allows me to use a flat blade screw driver to extract the screw.
SammyZ is offline   Reply With Quote
Old 01-24-2009, 02:28 PM   #4
Default 23
Ye i got it out im going to buy a screw set tomm and i finished my car Ill post pics
Selling tc4 160!
Tom :D
Old 01-24-2009, 04:45 PM   #5
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
call tony at tony's screws. DO NOT BUY STAINLESS!!!! If u do, u will be posting again how ur 'screwed'
R
UltegraSTI is offline   Reply With Quote
Old 01-24-2009, 05:48 PM   #6
Default The best thing ..
I learned this trick from another experienced racer. Use the heat of the tip of your sodering iron on the head of the srcew. With enough heat you should be able to get it right out stripped or not using the allen, it will work even when there is locktight in the equation.
Id say next time you have a another stubborn one, if it takes alot of force and it dosent break loose ( on the verge of stripping) just use the heat of the iron.. you will be happy you did. I dont know why but I aways seem to overtighten the screws especially on my 12th scales...two much grip I guess ..DOH!
simulatedwood is offline   Reply With Quote
Old 01-24-2009, 05:51 PM   #7
nexxus's Avatar
Trader Rating: 302 (100%+)
I usually get a cheapy Allen key, JB weld it to the screw head and then once thats set it can usually be wrenched out, also keep a butane torch handy if you need to heat it up to get rid of some loctite, especially if some idiot has used red loctite on the thing
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 01-24-2009, 07:20 PM   #8
gashuffer's Avatar
Trader Rating: 48 (100%+)
Stop over torquing your screws. Purchase allen drivers with small handles, this will help. Your not building a real car.
gashuffer is offline   Reply With Quote
Old 01-24-2009, 07:31 PM   #9
Trader Rating: 23 (100%+)
on my old tamiya my integy wrenches didnt work too well on those screws. i stripped numbers of them. it will take some time but since you were building your car it wont take as long (this is why im saying this) unscrew the part that the stripped screw is in, from any other parts it is attached to. then when the part is free from touching any other parts on the car, simply rotate the part and the screw will come lose instantly. hope this makes sense lol.
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 01-24-2009, 10:00 PM   #10
Yeti35's Avatar
R
I use Stainless all the time and have no issues with them.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 01-25-2009, 02:46 AM   #11
Trader Rating: 9 (91%+)
Good tools... Losi's are my favorite along with the hudy's. Also, when your tips start to get old. If your tip is fairly long, you can dremel it down and get a fresh new tip.
Theslowguy is offline   Reply With Quote
Old 01-25-2009, 09:55 AM   #12
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
+1 on the stainless. If I strip a screw head, it's from not inserting the tool deep enough into the screw head. Insert joke here. This can happen with standard steel or stainless.
As far as hex drivers go. MIP all the way. I own the complete set. The owner of my LHS showed me his original Thorpe drivers from 20 yrs ago, and the tips show no signs of wear.
To remove a stripped screw, try this.
http://www.sears.com/shc/s/p_10153_1...0P?vName=Tools
I've used these with great results. Just carefully follow the supplied instructions. Hope this helps.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 01-25-2009, 11:03 AM   #13
gashuffer's Avatar
Extractors! which bit fits 1.5-3mm?
Old 01-25-2009, 04:58 PM   #14
I believe the smallest of the extractors in the Sears set can do a 3mm screw according to the site.
Three words...
Buying a losi 8ight rtr DonnieNitro Nitro Off-Road 13 09-09-2010 04:06 PM
