Veteran TAMIYA TA03 fans!
#1111
ball diff
i try to rebuild ball diff for my ta03f dj. have any one tried tamiya 1/10 touring car aluminum ressure plate set (item #53219 or op219)? is it lighter then ta03 perssure plates? also anyone knows that where i can buy ceramic ball thrust bearings. i want to get 3mm ceramic balls and ceramic ball thrust beraings, but i can't find ceramic ball thrust beraings.
#1112
I was more interested in whether or not the changed shock angle etc made a significant difference... things like that
#1113
They are much smoother and dont feel lumpy. You can also set the diff looser than the stock 03 balldiff.
#1114
Tech Legend
Trader Rating: 51 (100%+)
Not with lipo... running it with a Yeah racing or Orion 3200 and its actually underweight... by about 100 grams.... even with my MaxAmps 5000 pack it was still about 30 grams underweight...
It shouldn't change the shock angles at all from looking at them. Most of the aftermarket arms I have seen are just copies of the stock ones with no angle changes.
#1116
Tech Legend
The aluminum ones I had where directly like the stock plastic ones. The pic of the one you posted do have some angle. I actually like the setup you posted. I like that little bit of extra angle. Would be fun to try a set of those sometime.
#1117
TA03 that still runs well on carpet racetrack
#1119
Lipo: SMC 4000
Motor: SP 4.5
Spur: 65
Pinion: 16
A car ran over it during a test run on the street.
#1120
#1121
Converting an 'R' to an 'F'
Back in the day, My father and I had TA03's. I had an R and he had an F. I just recently found 2 NIB TA03-r's and bought them both. But what I can't find to save my life is an F.
So, I got to thinking. A buddy of mine has a crap ton of old Tamiya parts, and I thought, 'aren't most of the parts interchangable?' If anyone could help me out on the parts list that I need, I would appreciate it very much. His B-day is coming up soon and I want to surprise him with it.
#1122
#1123
anyways, the R's are easy to convert, you just need the rear 03F gearcase (B Parts #50699) to convert it. just move the TA03R's rear gearcase to the front, make sure you have the motor guard (A Part (#50698) No.3 in the tree).
the Reinforced Damper Stay (Low Mount Type - Part #53337) isnt really a necesity. i think rcmart still has them on stock, they have the rear gearcase too last i checked ... in gray though.
hth!
#1124
btw, i just rebuilt my runner ... a good friend bought it recently.
Front Gearcase
Rear Gearcase
front and rear top angled shots
thanks for looking!
Front Gearcase
Rear Gearcase
thanks for looking!
