Old 08-01-2006, 04:44 PM   #14896
HarshGuy's Avatar
Originally Posted by TryHard
hey guys,
Quick Q for thoose who have an MRE already. What toe blocks does it come with?
from the pics on the Tamiya website, looks like B/A on the front and ?/D on the rear? Any other blocks included?
Ta
Ed
...humm ...hold on ...cut ..cut ..open ..crinkle ...crinkle looks like 1A, 1D, 1XB, 1B (now mind you I don't know what this means as this is my 1st Tamiya, but that's what the blocks say).
...I didn't even realize this, but DHL is 1/2 mile from my office, so I just got back from picking up the kit, it really did take 1 day to get from Hong Kong to me here in Roseville ...insane!!!
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 08-01-2006, 05:03 PM   #14897
TryHard's Avatar
cheers Harsh.
Right... suspension blocks. do two things.
1) allow setting of toe in
2) allow setting of track width
goes (from widest to narrowest)
1E, 1D, 1C, 1B, 1A, 1X, 1XA, 1XB, 1XC, 1XD
there is 0.5deg of toe difference between each block.
For example on the MRE,
1) with B/A on the front (B the front block, A the rear) there is 0.5deg of toe-OUT
On the rear, with XB/D (XB the front, D the rear) that is 3deg of toe-IN
2) For track width change....
XB/D and XB/B both give 3deg of toe-in (on the rear), but the XB/B combination results in a narrower rear track.
Hope that explains it There is a chart on my website with all the combinations of blocks.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 08-01-2006, 07:41 PM   #14898
JimmyMac's Avatar
Originally Posted by Brian Anthony
So to run foam tires you need to use the HPI front steering blocks correct? Do you need to use different axles or driveshafts?
Is there any other parts that would need to be changed to use foams?
Thanks guys.
Brian
Only if you run Jaco tires. You don't need to mod anything for Parma tires. I think I posted this on page 495 near the bottom. Plus I posted some pics up earlier in the year or sometime last year of the HPI knuckle conversion I did. But I used the pro3/4 MIP CVD axles with RDX steel CVD bones. But back then I couldn't get the Cyclone axles to use my Tamiya bones...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 08-01-2006, 07:49 PM   #14899
JimmyMac's Avatar
Here is one of my posts. http://www.rctech.net/forum/showthre...es#post2144234
Here is the page with some pics I posted. http://www.rctech.net/forum/showthre...es#post2087602
And yet another post... and a hint about the pro4 suspension. http://www.rctech.net/forum/showthre...es#post2078544
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 08-01-2006, 08:05 PM   #14900
Default Shocks
Ed, Thank you for the explanation regarding toe plates etc. Building my first set of Tamiya shocks for my 415, have a question regarding rebound!! I have read on a few different set up sheets 3 to 4mm or rebound I can only seem to get full rebound with mine, do you bleed the shocks through the bottom to get the desired rebound? Hope that made sense. Thanks!!
bradley70 is offline   Reply With Quote
Old 08-01-2006, 08:26 PM   #14901
Thanks guys. This is my first Tamiya since I got a MO1 when they first came out.
Brian Anthony is offline   Reply With Quote
Old 08-01-2006, 09:17 PM   #14902
JimmyMac's Avatar
If you are talking about rebound stroke, that refers to droop. Not shock rebound. I wouldn't worry if they rebound all the way. Mine does too. Just besure there is no air bubbles in the oil. etc etc.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 08-01-2006, 09:36 PM   #14903
HarshGuy's Avatar
OK, so I'm happily building away my MRE when all off a sudden
Old 08-01-2006, 09:41 PM   #14904
Burlap's Avatar
Send a message via MSN to Burlap
I have two trillion rear arms. I've even started throwing them out because all I need is the front arms.
Damn you Tamiya, just sell front arms only packs!
Burlap is offline   Reply With Quote
Old 08-01-2006, 09:42 PM   #14905
XrayFK's Avatar
That sucks, should have used titanium studs. I think the best you can try is to make a slot in it so you can use a screwdriver to unscrew it, that way you can avoid stripping out the hole. Or just use another hole.
XrayFK is offline   Reply With Quote
Old 08-01-2006, 09:44 PM   #14906
See what happens when you don't let me use your car for the tamiya nat's.LOL Just kidding. Call me tommorrow, I will see if I've got the part for you.
Juan Aveytia is offline   Reply With Quote
Old 08-01-2006, 10:31 PM   #14907
drew85's Avatar
Where are you guys get the car, I have not seen them anywhere but ebay?
drew85 is offline   Reply With Quote
Old 08-01-2006, 10:36 PM   #14908
That sucked....
Ben.C is offline   Reply With Quote
Old 08-01-2006, 10:38 PM   #14909
Bought it off my local distributor...
Looks sweettt..........
Old 08-01-2006, 10:43 PM   #14910
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
you can try to used 2.5mm drill bit it drill the alum out. i had try it before on my TA05 it works. hope this help you.
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
