Old 07-26-2006, 06:14 PM   #14836
m3ndo5a's Avatar
Default Set up
Originally Posted by bradNZ13
Hey guys, quick question regarding the stock manual set up of an MS. Ive had my MS about 1year and want to revert back to the stock set up as when first built but there are a few issues..
when it says to set the droop screws 1.5mm through the lower arm once the shocks are on the are to short to connect to the lower mounting point making the droop setting useless.
You may say to lengthen the shocks... i did but to keep ride height at the stock height by setting shock collars to 1.5mm and 2mm respectively and lengthening the shocks to fit the slop between the spring and shock cover is now way to much as the perfect amount of play was when shocks were at previous length..
so basically when you all built your car what did you do? am i missing something? as there is no set shock length or droop measurement in the manual and what the manual says wont physically work im a bit stuck. i guess i need to know what you guys did and the measurements you used to set up your car in STOCK mode.
cheers
Go to TeamXray.com it will help you with basic setups. Find the link to the setup manual,,,, On a "droop gauge" play around 6mm front 4/5mm rear...ride height 5mm front 5/5.5 rear. Basic....setup. "Center Lift" 1.5mm Front no more than 3mm rear.....it will change depending on what axle your are running.
m3ndo5a is offline   Reply With Quote
Old 07-26-2006, 06:20 PM   #14837
I know how to play around with that stuff thats not really what im after... im after the STANDARD set up from the manual.. thats what im trying to do but what the manual says isnt possible due to reasons stated. i know all the theory and i have many set ups.. i just want to go back to the standard one
bradNZ13 is offline   Reply With Quote
Old 07-26-2006, 06:48 PM   #14838
Ok so does the MRE car come with a ball diff as well as the spool?
If not can you still make a ball diff for the MRE car like the MSX?
Can the Graphite top deck from the MSX fit the MRE?
And Rick or Martin might beable to answer this one better, What all would you need to get to run the car on carpet with foam?
Thanks guys.
Brian
Brian Anthony is offline   Reply With Quote
Old 07-26-2006, 07:17 PM   #14839
dodo's Avatar
Send a message via Yahoo to dodo
hmm not sure but i got a strong feeling it will be spool only
i believe so, they are still using the same frontend
nope, the steering posts locations are different from msx
dodo is offline   Reply With Quote
Old 07-26-2006, 08:05 PM   #14840
Martin Crisp's Avatar
hey rod
i dont think i will be going to the past chumps this year.
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 07-26-2006, 08:33 PM   #14841
veecee's Avatar
Trader Rating: 34 (100%+)
No need to "make" one as Tamiya has released one. Check the RC Champ thread for details.
veecee is offline   Reply With Quote
Old 07-26-2006, 09:23 PM   #14842
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
yup, as noted above, the car only comes with a locked center, and spool front.
and i read where the alloy front diff has been released in japan, and due here any time.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 07-27-2006, 01:22 AM   #14843
C van der Hagen's Avatar
For carpet racing (rubber tires) buy a regular 415 or the 415 msx.
The MRE is for asphalt racing.
http://www.facebook.com/SepesRacingProducts
C van der Hagen is offline   Reply With Quote
Old 07-27-2006, 02:23 AM   #14844
cheers
droop is 5mm at front 4 mm at rear
this is also the best starting point for tarmac racing
run with out the roll bars to make sure your droop is set up correctly though.
If the tyres are over heating due to the track temperature go to hard springs hpi blues or xray light blues which are 20lbs. As this will Reduce mechanical grip.
Also this setup work well with a spool on a tight track.
the LWT dosen't ork on carpet the best rubber setup is spassetts rubber setup which is on tryhards website.
If you use the old supension rhinehards lrp carpet setup is the best to use but don't run a spool in it as there is no front toe out.
Smoking motor.. is offline   Reply With Quote
Old 07-27-2006, 11:37 AM   #14845
dawgmeat's Avatar
Originally Posted by Carl Giordano
Does anyone know if Tamiya has released the alum front diff halves for the 415...unable to locate the release / part number on the website
www.rc-champ.co.jp
To order: [email protected]
For all you 415 carpet muncher
dawgmeat is offline   Reply With Quote
Old 07-27-2006, 01:26 PM   #14846
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
MSX/MRE on carpet with foams.
Can the 4mm chassis be modified to accept the new steering rack from the mre?
Are guys running the lw suspension, standard suspension or short evo 5 arms on carpet with foams.
Are any mods to steering knuckles etc needed to accept standard 28mm jaco or parma foam tires?
What the deal with the standard steering rack on the msx is it really sloppy?
Did anyone post a setup from the carpet nats for the msx?
J.Gonzalez is offline   Reply With Quote
Old 07-27-2006, 11:35 PM   #14847
You can try the TamiyaUSA website for Marc's carpet setup or look for a setup on tryhard's website.
Ben.C is offline   Reply With Quote
Old 07-28-2006, 09:37 AM   #14848
dawgmeat's Avatar
hey Alex slow down
LW suspension will require the Pro4/cyclone steering knuckles to clear the foam tire, new steering rack will work on the 4mm chassis
Old 07-28-2006, 09:50 AM   #14849
Turbonium's Avatar
i dont think the 4mm chassis will take the new steering without modification, as i hear the posts are mounted farther back... wont know till it gets here for sure...
i see where Hobbymania posted they have them in stock now...
Wes
Team Novak
Old 07-28-2006, 04:59 PM   #14850
JimmyMac's Avatar
Originally Posted by dawgmeat
hey Alex slow down
Only if you want to run Jaco's. You can run the stock LW suspension with 6mm silver wheel hexes and a red 1mm hex shim for Parma tires. But you must use the A blocks to meet 190mm. Otherwise you'll be too wide.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
