Old 06-29-2006, 02:23 AM   #14581
TryHard's Avatar
Originally Posted by Leester
Hello Folks.
is there any place online i can buy the evo V suspension arms and steering arms as well?
Thank you
RC Champ in japan, drop them an email and they should be able to help you out. (they have a sub-forum in the shop section)
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 06-29-2006, 05:26 AM   #14582
Hi,
thank you.
I attached a picture. I just want to be sure that we're talking about the same...
And do you can tell me how thick the rib is where the bearing sits? It would require just a little work to make the thing fit.
Cheers
Chris
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
powered by Nosram/Reedy
speedy-932 is offline   Reply With Quote
Old 06-29-2006, 05:52 AM   #14583
TryHard's Avatar
Originally Posted by speedy-932
Hi,
thank you.
Cheers
Chris
Hi
yup, thats, pretty much where I measured to, but I had the diffring on my outdrive, so you'd need to take that off my measurement.
Not sure about the rib, where the bearing sits is just the outdrive, no extra rib. although I may not quite understand what you mean here.
HiH
Ed
Old 06-29-2006, 05:58 AM   #14584
Hi,
I'm not sure when I look at the pictures of the alloy outdrives. It looks like there is a small rib where the bearing sits.
Or to make it simple: Is the alloy diff exactly the same as the plastic one (51058)?
Perhaps I just don't see it correctly. A picture of the alloy diff would help me aswell.
Thank you
Cheers
Chris
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
Old 06-29-2006, 08:03 AM   #14585
R3.
R3.'s Avatar
I just bought a new MSX and I wanted to see if someone could tell me a good method for sanding and polishing the edges of the chassis and other fiber parts.
R3. is offline   Reply With Quote
Old 06-29-2006, 11:00 AM   #14586
Ballsie's Avatar
Originally Posted by JayL
the MSX rear diff IS alum, so upgrade to it.
http://www.tamiyausa.com/product/ite...oduct-id=53889
But he's got a BD, not a 415 that's why he asked for measurements.
Ballsie is offline   Reply With Quote
Old 06-29-2006, 11:05 AM   #14587
Ballsie's Avatar
Originally Posted by R3.
I just bought a new MSX and I wanted to see if someone could tell me a good method for sanding and polishing the edges of the chassis and other fiber parts. I have been running a TC4 tub chassis so I have never had to do this before.
Clean the edges with a Primer, Yokomo do an excellent one and then apply instant cement and let it run around the edges for a smooth finish. Try and let it run around as much as possible for a good clean finish.
Old 06-29-2006, 11:13 AM   #14588
Ballsie's Avatar
Milky Blue spring are available again from Jason.
Hurry though - there are only 3 sets!
http://cgi.ebay.com/49389-Tamiya-On-...QQcmdZViewItem
Old 06-29-2006, 12:39 PM   #14589
Trader Rating: 27 (100%+)
Just paint them milky white. Easy.
JoeyE is offline   Reply With Quote
Old 06-29-2006, 03:24 PM   #14590
TryHard's Avatar
Hi,
Thank you
Cheers
Chris
from the edge of the rib to the inner face of the outdrive is 15.30mm.
thickness wise its about 1.5 - 2mm.
HiH
Ed
Old 06-29-2006, 03:47 PM   #14591
Trader Rating: 70 (100%+)
Wrong thread but where can i find a asphalt setup for the evo4?thanks
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 06-29-2006, 09:32 PM   #14592
kewdawg's Avatar
Guys,
will the TB EVO IV Stabilizer Rod Set - part# 53722, fit the 415MSX?
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 06-30-2006, 05:39 AM   #14593
Originally Posted by kewdawg
Guys,
TA05 Stabilizer Set Front and Rear #53842 fit on TRF415MSX. Not sure about TB EVO IV stabilizer.
trf_skyline is offline   Reply With Quote
Old 06-30-2006, 05:43 AM   #14594
alan1467's Avatar
The EVOIV fits the front no problems but is a little to wide for the rear but it will fit if you use collars to limit the side movement
Alan
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 06-30-2006, 05:53 AM   #14595
Hi,
thanks Ed. You helped me a lot.
From what I've heard and seen it should fit with a little modification.
Cheers
Chris
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
