Old 06-28-2006, 11:05 AM   #14566
TRF415boy's Avatar
Originally Posted by CarKing
Thanks for all of the help guys! I got a few more question if you don't mind:
1. why does eveyone use yokomo front diffs?
2. what if the FDR on this car? i don't know the Internal ratio
3. what is a typical gearing on this car for 19t motors?
I am going out to run it this weekend and am really getting excited. Got to go buy myself a Mazda 6 shell
1) only people racing foam on carpet uses front diffs, and there isn't any tamiya front diff yet so they make it out of yokomo parts.
2) internal ratio is 2,187, FDR will depend on the pinion you put,
3) there is no typical gearing, it depends on what motor, what track, etc...
TRF415boy is offline   Reply With Quote
Old 06-28-2006, 12:15 PM   #14567
AWK
AWK's Avatar
So what is used on the front end of the car if Tamiya doesn't make a front diff? What comes standard on the car. I think I am getting confused since I always considered it to have a front and rear ball diff.
AWK is offline   Reply With Quote
Old 06-28-2006, 12:20 PM   #14568
lbckevin's Avatar
Trader Rating: 91 (99%+)
for the front you use the included one way or a spool, which is in sense a locked diff.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 06-28-2006, 12:20 PM   #14569
LBSR415's Avatar
the 415 comes standard with a one-way up front, tamiya makes a spool as well, front diff can be assembled from yokomo parts,part #'s are on tamiya's web site under the trf center,
LBSR415 is offline   Reply With Quote
Old 06-28-2006, 12:34 PM   #14570
rtypec's Avatar
Coming Soon: Item No.53921 - TRF415 Front Aluminum Differential Joint
rtypec is offline   Reply With Quote
Old 06-28-2006, 01:27 PM   #14571
AWK
AWK's Avatar
thanks a lot. yeah the car has the spool in it right now. i never even thought about a locked front diff coming from the 04r
Old 06-28-2006, 02:08 PM   #14572
Hi,
thanks for the answers. But unfortunately it didn't really solved my problem.
So... can anyone check wether the Yokomo diff (with the necessary Tamiya parts) fits in the rear aswell?
Cheers
Chris
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
powered by Nosram/Reedy
speedy-932 is offline   Reply With Quote
Old 06-28-2006, 02:34 PM   #14573
Probably not. Yokomo uses the same diff in the front and back. 415 doesn't. Why don't you use a 415 diff in the rear?
DOTMAN is offline   Reply With Quote
Old 06-28-2006, 02:36 PM   #14574
Hi,
thanks. I want to use a 415 diff in the rear. But I want the alloy one.
Cheers
Chris
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
Old 06-28-2006, 02:44 PM   #14575
TryHard's Avatar
Originally Posted by speedy-932
Hi,
Cheers
Chris
Hi,
I doubt the MSX diff will fit in a BD, I don't know for sure (don't have a BD). It's possible that it might work, but you'd need to measure the distance between the bulkhead bearings on the BD to check the distance. IT could be too narrow.
The yokmo diff parts used on the front of the 415 are actually the rear outdrives from the old MR4-TC (the belt version before the SD), and are used simply because it had the pulley central in the car, like the 415 does for its front.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 06-28-2006, 02:48 PM   #14576
Hi,
thanks.
Do you can measure the outdrives of the 415?
I just need 2 sizes. The distance between the bulkheads and on the long half of the outdrives I need the size where the bearing sits looking from the inner site.
I hope you can understand what I mean.
Thanks a lot for your help
Cheers
Chris
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
Old 06-28-2006, 04:36 PM   #14577
Hello everyone,
If anyone is looking for an alum front diff click on the link below.
http://www.rctech.net/forum/showthre...01#post2466701
Obsidian is offline   Reply With Quote
Old 06-28-2006, 04:37 PM   #14578
TryHard's Avatar
Hi,
thanks.
Cheers
Chris
distance between bulkheads = 23.4mm
distance from outter bearing to inner face of diff ring (thought this maybe more useful) = 15.74mm
HiH
Ed
Old 06-28-2006, 05:52 PM   #14579
JayL's Avatar
the MSX rear diff IS alum, so upgrade to it.
http://www.tamiyausa.com/product/ite...oduct-id=53889
JayL is offline   Reply With Quote
Old 06-28-2006, 06:49 PM   #14580
Leester's Avatar
Trader Rating: 21 (96%+)
Hello Folks.
is there any place online i can buy the evo V suspension arms and steering arms as well?
Thank you
Leester is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
