Old 06-09-2006, 12:46 AM   #14446
Eirik's Avatar
Hey Charles,
I usually run 5-6mm droop up front and in hole #3 on the arm so I do not have that problem....
You should just unscrew the shock end 1-2 turns to make you shock longer.
Question:
Why are you running your shocks all the way out on the arm??
Running them out there would give you allot less steering and "Kill" your front tires in no time I assume.....
Eirik is offline   Reply With Quote
Old 06-09-2006, 01:40 AM   #14447
despite making track width narrower or wider,
what is the effect of :
- front inboard toe-n vs inboard toe-out?
- rear inboard toe-in vs inboard toe out?
thanks,
Faiz is offline   Reply With Quote
Old 06-09-2006, 12:02 PM   #14448
Charles Godwin's Avatar
Cheer Eirik. I am running them in that hole as it was on the Marc Reinhard (spelling?) starter set-up which i have been runnin for a few weeks now but i've always been taught that a more leaned shock is softer than a more up-right shock so it gives you more grip at that end or have i been told 'porky-pies' ?
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 06-09-2006, 12:10 PM   #14449
Kenneth Tan's Avatar
Josh Numan's setup posted:
http://www.tamiyausa.com/articles/fe...?article-id=79
Kenneth Tan is offline   Reply With Quote
Old 06-09-2006, 12:12 PM   #14450
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Set ups...
anyone notice the rear toe in for Numan's and Rheinard's set ups from Reedy?
Numan had -4.0 deg of rear toe in.
http://www.tamiyausa.com/articles/ln...dy06_setup.pdf
Rheinard had -3.0 of rear toe in (and +1.5 of toe out on the front)
EDIT: im all confused now.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-09-2006, 12:50 PM   #14451
Eirik's Avatar
Marc has 3.0deg and Josh has 4.0deg !!
I assume that it is a typo in Josh's setup, should be 1XB instead of 1XD
Old 06-09-2006, 12:55 PM   #14452
over gear's Avatar
Trader Rating: 15 (100%+)
Numan had -4.5 deg of rear toe in.
Rheinard had -3.5 of rear toe in (and +1.5 of toe out on the front)
-4.5 deg rear toe?! is that a typo? how much rear toe can u go?
over gear is offline   Reply With Quote
Old 06-09-2006, 12:59 PM   #14453
Eirik's Avatar
Charles
A more leaned shock will be softer initially and more progressive than an upright shock.
But as you move your shocks out on the arm, it will make the suspension stiffer, less steering and it will let the tires work harder....
Leaning the shock on the tower is a different story, normally more steering as you lean them inn more!!
I think Marc's setup was in the #2 hole on the arm, not sure, but I suggest you try it in the middle, #3
Old 06-09-2006, 01:04 PM   #14454
Hebiki's Avatar
i edited my post. im all confused now..
Hebiki Design Works
Old 06-09-2006, 01:16 PM   #14455
how did Marc use a ko reciever with a m11 radio?
HEWITT is offline   Reply With Quote
Old 06-09-2006, 01:43 PM   #14456
Probably because he is using 27mHz.
trf_racer is offline   Reply With Quote
Old 06-09-2006, 02:30 PM   #14457
moshmike's Avatar
Originally Posted by Nexus Racing
I forgot that I snapped a pic while he was running those springs.
Are those the TA05 pulleys on there? O r have I just not seen white pulleys for the MSX?
My most high tech car is a TA-03.
moshmike is offline   Reply With Quote
Old 06-09-2006, 02:46 PM   #14458
dynoman007's Avatar
Send a message via MSN to dynoman007 Send a message via Skype™ to dynoman007
Talking lol
most of the guys are running ta05 pullys on the msx to get the internal ratio to 2.25 and they are white and look cool
dynoman007 is offline   Reply With Quote
Old 06-09-2006, 03:08 PM   #14459
I'll try that this Sunday then
Cheers, Charles
Old 06-09-2006, 04:49 PM   #14460
tony q's Avatar
any info on what to do to fit the TA05 one way diff on the MSX?
tony q is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
