Old 06-05-2006, 12:00 AM   #14401
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
http://www.tamiyausa.com/product/ite...oduct-id=49382
shows as discontinued
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 06-05-2006, 12:20 AM   #14402
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by JasonC
I don't know of them anywhere either, I was told they were a north american market only item
tamiyarcracer is offline   Reply With Quote
Old 06-05-2006, 02:24 AM   #14403
Josh Numan's Avatar
Originally Posted by edracer1
Thanks JayL
Can someone post a link for Josh and Marc's setup to the Tamiya site. I can't seem to find it.
Well i do belive that Marcs set up is on there. Mine is similar,just little differences. Mine also says 40wt. oil instead of the Tamiya style with the 400 and 500 weights.
Josh
Josh Numan is offline   Reply With Quote
Old 06-05-2006, 04:09 AM   #14404
Josh thanks a ton for the setup info, i have had little experience running a spool, and always seem to need a lot more mid corner steering, we are having a meeting at a large sweeping track that i think may lend itself to running a spool, lots of tight corners after long straights.
If your searching for mid corner with a spool what changes would you make?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 06-05-2006, 05:33 AM   #14405
Default toe blocks
hi guys
recently got a standard 415 and im after what toe blocks i would need to run 2 degree rear toe in none to 1 dergree toe for the front at the widests possible
cheers
richard
djrfan is offline   Reply With Quote
Old 06-05-2006, 05:48 AM   #14406
Burlap's Avatar
Send a message via MSN to Burlap
Originally Posted by djrfan
hi guys
cheers
richard
Check Tryhard's 415 page. There is an Excel spreadsheet with what toe blocks do what toe angle here:
http://www.thard.co.uk/
Burlap is offline   Reply With Quote
Old 06-05-2006, 05:49 AM   #14407
bender's Avatar
hi guys
cheers
richard
For the rear, an A-E combo would give 2 degrees toe-in (as long as you are using 0 degree hubs).
For the front do you want toe-in or toe-out? Use a C-E combo for 1degree toe-in, or E-C for 1 degree toe out.
There is a chart on Tryhard's website which gives you the full range.
(Edit: Damn Burlap beat me to it )
Richard, what track is this for?
If it's for Bayside, then I suggest you run the car quite narrow, it will make it quicker through the corners. I would normally run B-XB on the front and XB-B on the rear. You can run A-XB on the front if the car is a little too "twitchy".
I can email you some of my Bayside setups if you want, they're for the 415MSX but I thibk they'd be a good starting point
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 06-05-2006, 06:02 AM   #14408
kewdawg's Avatar
Bender,
Can you tell me what are the stock suspension blocks for the MSX and the stock toe, camber and rebound/droop settings.
thanks.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 06-05-2006, 09:16 AM   #14409
drew85's Avatar
Do you guys ever have a problem with the rims hitting the front arm when there turned and the suspention is compressed?
drew85 is offline   Reply With Quote
Old 06-05-2006, 09:23 AM   #14410
drew85's Avatar
Old 06-05-2006, 10:12 AM   #14411
Eirik's Avatar
Originally Posted by drew85
Stock toe I think it like 0 in the front and -3 in the rear.
Stock blocks are
Rear:
r-1B
f-1xd
Front:
f-1B
r-XB
Front:
f-1B
r-XB
= 2deg
Eirik is offline   Reply With Quote
Old 06-05-2006, 10:16 AM   #14412
JayL's Avatar
Originally Posted by lbckevin
JASON,
do you have a part number on the spring set ?
the part number is:
53440AO
I made the mistake of only buying one set and you'd need two to have four of each...
JayL is offline   Reply With Quote
Old 06-05-2006, 11:33 AM   #14413
TRF415boy's Avatar
yes, asked spashett about it he said he grinds his wishbones...
TRF415boy is offline   Reply With Quote
Old 06-05-2006, 01:03 PM   #14414
Ballsie's Avatar
Hi Guys,
Anyone know what "X-Gear" is that Marc has a decal for on his body?
http://www.pdubracing.com/2006_Reedy_Race%20082.jpg
Thanks.
Ballsie is offline   Reply With Quote
Old 06-05-2006, 01:07 PM   #14415
The Evicerator
I dunno... but TEAM STEVE on his windsheild is AWESOME!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
