Like Tree2Likes
Tamiya TRF415
Old 03-20-2004, 05:02 PM
  #1426
Also, what do you guys use to cut the teeth from the belt?
g4t2 is offline
Old 03-20-2004, 05:14 PM
  #1427
JimmyMac's Avatar
I'm just gonna use a pair of Dikes....
JimmyMac is offline
Old 03-20-2004, 05:20 PM
  #1428
sorry, please excuse my ignorance, but what are Dikes?
g4t2 is offline
Old 03-20-2004, 05:25 PM
  #1429
JimmyMac's Avatar
Why Diagnol Cutters of Course!! Wire cutters... whatever you want to call them...
JimmyMac is offline
Old 03-20-2004, 05:42 PM
  #1430
You can also use finger nail clippers on the belt.
trf415 is offline
Old 03-20-2004, 07:04 PM
  #1431
Hebiki's Avatar
Trader Rating: 26 (100%+)
Kilruf
YGPM
Hebiki is offline
Old 03-20-2004, 09:07 PM
  #1432
JimmyMac's Avatar
Back at ya Hebiki.
JimmyMac is offline
Old 03-21-2004, 04:35 AM
  #1433
Regional Moderator
I thouhgt it diidnt come out even on the belts as far has doing every other tooth. or are you guys doing the pully?
Ko Racer is offline
Old 03-21-2004, 05:12 AM
  #1434
badboy's Avatar
Trader Rating: 14 (100%+)
OFF TOPIC NEWBIE QUESTION
I think most of you guys have driven a TRF 414m, so I just wanted to find out if I can use the 414m lower deck for my TA04 TRF? If yes, do i need to modify something?
Posted here coz I couldn't find the TA04 topic. Thanks in advance.
badboy is offline
Old 03-21-2004, 08:38 AM
  #1435
rtypec's Avatar
badboy, the holes are way different on the 414 compared with the 04. Tamiya does have a carbon fiber saddle pack lower deck for the 04 and it makes it look very similar to a 414 but I do not have the part number on me. Be careful not to confuse it with the corbon fiber "stick pack" lower deck for the 04
Why are you guys cutting every other tooth? No faith that Tamiya did their homework on the belts and belt tensioners and reshaped pulley/belt teeth? You know the belt tensioner cam works both ways...you can also go looser lol
rtypec is offline
Old 03-21-2004, 08:47 AM
  #1436
KREATOR1's Avatar
The 04 have alot different lower deck from the 414m2.
the 414m2 bulkhead mount have no holes for the 04's bulkheads.
i sugguest you take the whole 414m2.
KREATOR1 is offline
Old 03-21-2004, 09:54 AM
  #1437
Rod did you run at TA yesyerday or did you run the SE3?
I gave mine a shakedown in the neighborhood and the car felt real good, hopfully I'll be running next weekend.
Less teeth better effiency and more attractive to your sister. Works on a Losi most work on a Tamiya
Difuser is offline
Old 03-21-2004, 10:12 AM
  #1438
eeyan's Avatar
Originally posted by rtypec
[B]badboy, the holes are way different on the 414 compared with the 04. Tamiya does have a carbon fiber saddle pack lower deck for the 04 and it makes it look very similar to a 414 but I do not have the part number on me.
Here are samples of the 04 saddle conversion and 414 chassis. I did an article for an R/C magazine a while back comparing the 2 chassis. Handling wise, we found both are almost similar, but have their own strength and weaknesses. But both are capable cars at the highest level... but then again, we have the 415 which should provide even higher performance...
By the way, the 04 saddle chassis was discontinued last year. Tamiya USA might have some floating around though. So if you ever get the chance to see these, grab them before they are gone forever! Mine's all locked up in a glass cabinet somewhere in cali...
eeyan is offline
Old 03-21-2004, 01:09 PM
  #1439
rtypec's Avatar
Dan, I ran the EvoS yesterday and couldn't quite get it to handle right with a mod. I killed a diff and after rebuilding it, the car felt better. I played around with cutting down the mazda 6 wing and I found out that it lost a lot of stability. But in the end, the car was just not right because of the experiment, wish there was an "undo" for scissors.
Fred tried an off shoot of Satoshi's cold weather setup and it was a lot better but in the end, I think I won two throwdowns and Beale won the other...both with Evo3's. Next week, I'll have the 415 running but for now, I gotta go to the lhs to get some paint and stuff. ttyl
rtypec is offline
Old 03-21-2004, 03:47 PM
  #1440
JimmyMac's Avatar
Here's my 415 setup.
Frontend:
400 oil 2hole piston
Yellow Spring
Yellow Swaybar
1 Toe-in
-1.5 Camber
4mm shim under camber link (inner)
Shock 1 in from outside on tower
Shock outside hole on arm
Arm spacing 2mm shim in the rear
Belt 2clicks tight
Droop 5.5mm under the arm
Silver shim on wheel hex
4~4.5mm Ride height
L C2 R C1 spindles
4 Caster Block
Rearend:
Yellow Spring
Yellow Swaybar
2 Toe-in (OP687 1 rear hubs with A front block and C rear block)
Rear Blocks raised 1mm front and rear
-1 Camber
No shims under camber link (inner)
Middle hole on rear hub .7mm shim under ball stud (outter camber link)
Shock farthest out on tower
Arm spacing 2mm shim in the front
Belt 3clicks tight
Droop 6mm under the arm
4.5~5mm Ride height (.5mm difference between front and rear)
Other:
104/32 for Binary
104/33 for Monster Stock (tuned for 1/12th)
CS22 premounted
Proto Alfa 2.0
Best Lap: 18.16sec
Air temp was high of 68
I forgot to measure track temp
Smooth Asphalt
Medium Traction
145x97ish track size
TQ and win.
I'm gonna try other things next weekend like 3 hole pistons, springs, and different body.
JimmyMac is offline
