Old 05-27-2006, 10:50 AM   #14296
Originally Posted by Leester
I'm running rubber on carpet would HPI arms make a big diffrence with rubber tires? and what will it do? And what HPI arms for which Hpi car are you talking about and where can i order them?
pro 4 arms f/r pro 4 knuckles and caster blocks and pro 4 rear hub carriers 0 degrees i think. You need to check out some of the driver indoor setups on the web
Team driver seem to be faster with it as it run bigger bearings that the LW which allow you to get more corner speed out of the car. also the pivot points are shorter that the Lw by 1mm this mean you have to run wider blocks but helps the car rotate faster in the corners, The evo 5 arm are suppose to stop drivers converting the car to hpi pro 4 arms to make the car work really well indoors.
On tarmac the lw really shines it is one of the easyiest supensions to setup and keep running consistantly. As it is designed for tamac rubber tyres.
Smoking motor.. is offline   Reply With Quote
Old 05-27-2006, 04:57 PM   #14297
Leester's Avatar
Trader Rating: 21 (96%+)
Where can i find 415MSX setup sheets that are running HPI arms? Any websites?
Leester is offline   Reply With Quote
Old 05-27-2006, 08:36 PM   #14298
Burlap's Avatar
Send a message via MSN to Burlap
Originally Posted by Smoking motor..
It's already underweight and there are no hopup that will make a big enough differance to lighten it.
I agree. Nearly all the top line chassis from each RC factory is under the 1500g minimum limit out of the factory. Maybe putting lighter components into the drive train, like the RC Square spur holder (anyone tried one of these?) may make the car run more efficent, but at the end of the day you'll still need those lead weights somewhere on the chassis, especially with a personal transponder.
Burlap is offline   Reply With Quote
Old 05-27-2006, 08:43 PM   #14299
JimmyMac's Avatar
I've ran the Square spur gear adapter. It's a pretty nice unit. I mainly got it since you mount the spur using the "outter" holes for less spur gear warp. Also it's TCS legal as well since it falls under the "any spur gear adapter" rule.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 05-28-2006, 02:43 PM   #14300
Albino2000's Avatar
Default TRF Prototype
You can buy a original trf415 prototype on ww.ebay.de
http://cgi.ebay.de/TAMIYA-TRF-415-Pr...QQcmdZViewItem
Albino2000 is offline   Reply With Quote
Old 05-28-2006, 03:53 PM   #14301
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
this is TRF 415 ms
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 05-28-2006, 05:20 PM   #14302
Originally Posted by Guo Chean
this is TRF 415 ms
Its only a TRF 415 with some blue alloy parts on it.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 05-28-2006, 05:34 PM   #14303
Burlap's Avatar
Originally Posted by Besercoe
Its only a TRF with some blue alloy parts on it.
That is sad that they are trying to sell it off like that.
Old 05-28-2006, 08:35 PM   #14304
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Default TWIN STARS & MARC R. WIN INVITE RROC 2006
Final Results from LiveRC.com:
Invitationals:
1st Marc R. Tamiya TRF415MSX
2nd Hara HotBodies Cyclone Hara Edition
3rd Josh Numan TRF415MSX
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 05-28-2006, 10:42 PM   #14305
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
josh ran a 415msx
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 05-29-2006, 12:14 AM   #14306
Burlap's Avatar
Originally Posted by JasonC
josh ran a 415msx
Good to see another Tamiya up that high
Old 05-29-2006, 12:32 AM   #14307
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Invitationals:
To add to the Hupo Honigl, was 4th, and Rick Howart was 8th or 9th, both driving the MSX
tamiyarcracer is offline   Reply With Quote
Old 05-29-2006, 12:36 AM   #14308
WRXTC's Avatar
Great result for Tamiya.
WRXTC is offline   Reply With Quote
Old 05-29-2006, 01:18 AM   #14309
JRRobiso's Avatar
Arrow
Thanks for bringing that up. I didn't know there were a lot of other drivers in the top 10 using the MSX chassis besides Marc & Josh.
Old 05-29-2006, 01:40 AM   #14310
TryHard's Avatar
this is TRF 415 ms
Actually, if you look closely the shock towers are different to the std 415 ones (less holes on the rear, and more upright at the front), plus some of the X blocks with the sale don't have markings on them. If the car is an exTRF team car, then that does support it. I'm not connected to it in anyway, but I wouldn't be suprised if it was... but proto is probably too strong a term for it.
| THard.co.uk | Xray | MuchMore |
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
