Old 05-24-2006, 09:53 PM   #14266
viet_mafia's Avatar
Some pics of my MSX:
I used the same notch on BOTH sides for the front one-way...
viet_mafia is offline   Reply With Quote
Old 05-24-2006, 10:25 PM   #14267
Leester's Avatar
Trader Rating: 21 (96%+)
Originally Posted by Difuser
Lee make sure the teeth are lined up in the gear notches so that the belt is travelling around a smaller diameter. When you adjust the belt tension it should be in the last 2-3 adjustment notches. Make sure you are loosening the tension also not tightening it. It will just fit. My cars are ar the track so I cannot post pics.
The teeth on the pully are lined up just fine but i can't even get the pully in the gear notches because the belt won't allow me to do that. what do i do next?
Leester is offline   Reply With Quote
Old 05-25-2006, 04:57 AM   #14268
Dan415ms's Avatar
Talking Something special for sale
You all need to check this out:
http://www.rctech.net/forum/showthread.php?t=115343
Dan415ms is offline   Reply With Quote
Old 05-25-2006, 11:28 AM   #14269
Leester's Avatar
Originally Posted by Hebiki
Lee
per Dan Garber's instructions in using the TA05 pulleys on the MSX. loosen the bulkheads, slide the front oneway or diff in... then slowly tighten down the bulkheads again using a star pattern. then secure the top portion using the same star pattern. its a snug fit, but it works.
- Chris
ok I finally got the TA05 pully in the frotn gear box. but the problem is that when i try to tighten up the top half it's wobbling all over the place and i can't seem to get it to fit. Any suggestions?
-Lee
Old 05-25-2006, 11:48 AM   #14270
TryHard's Avatar
-Lee
few questions....
have you removed any material from the one-way pulley to get the thing to fit? The pulley is wider in the centre than the 415 one (it's been mentioned on here before), so needs a little material removed, or take a little off one of the bearing holder.
For getting the pulley in, if the belt is new, you need to run the tensioners really quite loose (about 1 click off max loose) to get correct tension, due to the pulley being 1 tooth larger.
For getting the bulkheads in... not sure why it's doing that Maybe you want to try and remove some material from the bearing holder..
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 05-25-2006, 02:22 PM   #14271
Leester's Avatar
Originally Posted by TryHard
few questions....
HiH
Ed
it's not the bulk heads (lower part) it's the top part where the shock tower and the top part connect with the lower bulk heads. When i try to screw in the top part it tips to one side and then when i take the crews out to try it again i try to srew in the other side it tips to the other side. i'm not using the right words to discribe this but. i can't screw on the top bulkhead that connects with the lower bulk head with the one waypuley inside. i gt the pulley to fit inside the bulkhead but it's screwing it in that's giving me problems. What can i do?
-lee
Old 05-25-2006, 02:25 PM   #14272
Leester's Avatar
few questions....
HiH
Ed
no i have not. i and i don't know what type of tool or type of technique to use to remove the material from the one way. Stien mnetioned a lathe. but i don't know waht type of lathe it is and i don't know what type of tool he's talking about.
Old 05-25-2006, 04:55 PM   #14273
Leester's Avatar
well looks like a shocking turn of events has occured.
I acataully got the bulk heads on the front to work after loosing up the shock tower and i got it to fit just right i put the diff in and that worked as well.
Thank you for everything but i'm not done yet i still have a few questions to ask you.
What are some good aftermarket hop up options that i can put on my 415 that reduces weight? waht type of aftermarket parts can i buy that will enhance the cornering speed of the car and make it more snappy through the infield
in other words. what are the best aftermarket upgrade parts for the Tamiya 415MSX? any suggestions?
-Lee
Old 05-25-2006, 07:26 PM   #14274
tony q's Avatar
-Lee
are you using the TA05 plastic pulleys in the center shaft too?
tony q is offline   Reply With Quote
Old 05-25-2006, 07:28 PM   #14275
Leester's Avatar
No i'm not. should I? how do i get the TA05 pulleys in the 415MSX?
Old 05-26-2006, 12:08 AM   #14276
tony q's Avatar
i saw the picture at world's warm-up marc rheinard was using it, but if you are not using it. what is your final ratio? is it still the same 2.187.
Old 05-26-2006, 12:29 AM   #14277
drew85's Avatar
Its diffrent, it was posted a few pages back, it would be the same at the ta05 as the whole drivetriain is ta05 parts, I am assuming.
drew85 is offline   Reply With Quote
Old 05-26-2006, 01:48 AM   #14278
Eirik's Avatar
-Lee
The best and cheapest part you can get for the MSX to make it lighter and more responsive is a Protoform Mazda 6 Light Weight bodyshell
Eirik is offline   Reply With Quote
Old 05-26-2006, 04:18 AM   #14279
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to HotrodHopkins
does anyone know if this will fit on the orignal? It's made for the MS.
SHAUN HOPKINS a.k.a NoRod Hopkins
-1990 Chevrolet K1500 Silverado TBI350 "Heavy Half". 1971 Chevrolet Nova
-My lug nuts require more Torque than your Honda makes.
HotrodHopkins is offline   Reply With Quote
Old 05-26-2006, 04:22 AM   #14280
alan1467's Avatar
Yes it fits both the 415 and 415MS but not the MSX
Alan
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
